Rear control arms
Old May 8, 2023 | 11:58 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Rear control arms
Hi all,
The rear has gotten very noisy, I suspect the bushings have aged out so I've been shopping around for control arms. I'll take a look under the car, but I'm preparing to just change everything.
Strange thing is, the AMG-specific part numbers for control arms cost ~3x of the normal W211 set, there are 8 in total to change.
For anyone who's seen both kinds, do you know if there is an actual difference in dimensions between the two types, or is it something else like bushing stiffness or other less-consequential design change?
Old May 8, 2023 | 06:29 PM
eightysixtuned's Avatar
W211 E63 AMG
Chinese brand aftermarket arms are very cheap if you don't care much. i'd just recommend keeping your factory arms around just in case those bushings are made available for purchase.
Old May 8, 2023 | 07:17 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I know from experience how expensive AMG specific rear control arms are. I did a complete suspension replacement last year.
I thought that I was getting a bargain buying rear suspension parts from Rock Auto. But they didn't fit, although they were labeled for an E63.
But when you compared apples to apples, they weren't the same. So, I had to buy all of the rear control arms from Mercedes.
Old May 8, 2023 | 07:32 PM
mekantor's Avatar
Appreciate the feedback, this seems to confirm they have different sizes for the lower AMG ride height.
Old May 8, 2023 | 08:23 PM
Yuille36's Avatar
Do yourself a favor and order your suspension parts from a reputable source, like FCP Euro, Pelican Parts, AutohausAZ.
But if they don't have the parts you need, then get them from Mercedes. Not only did I replaced every control arm, ball joint, bushing and wheel bearing.
I also replaced all my air suspension components as well. I wasn't cheap
Attached Thumbnails Rear control arms-rear-suspension-components.jpg   Rear control arms-wheel-bearings-f-r-tie-rods.jpg
Old May 8, 2023 | 08:30 PM
mekantor's Avatar
I can get 8 control arms from benzpartshq.com, a FL dealership, for ~1500. Fcpeuro charges 1800 for the same set.
Not bad when amortized over the 20y age of the car! All my airmatic has been arnott for a while, with the fronts warranty-swapped a few times each.
Old May 9, 2023 | 08:30 AM
Yuille36's Avatar
The benefit that you get from FCP Euro is that your components are warrantied for life. So, say your ball joints fail in the future, FCP Euro has you covered.
But I get where you're coming from, since these components should last for another 10-12 years.
Old May 9, 2023 | 04:41 PM
E55Greasemonkey's Avatar
This place is a joke.
E55/E63 use larger bolts than the non AMG cars where the arms connect to the spindles. Just FYI why the parts are different.
Old Aug 14, 2023 | 10:08 AM
mekantor's Avatar
Based on the noises, I speculated that the only bad parts were swaybar links, and it turns out I was right. Got away cheap and quick.
Its just amazing how many bushings are back there, plus all the bushings of the rear subframe.
Old Aug 14, 2023 | 01:07 PM
W211 E63 AMG
yeah...i've spent roughly 6k in parts and labor in replacing of bushings/arms with new OEM as well as going with K-Mac parts. also all creative steel products.
not fun, but these cars are up in age at this point and need it done.
Old Aug 8, 2025 | 11:16 AM
mekantor's Avatar
A few years later I finally completed this work. 10 new control arms, new subframe bushings, new flex disks, new struts, and had the axles rebuilt. Many new bolts and nuts all over.
I did order a few incorrect parts and had extra orders to make while the subframe was out. Indeed the AMG bolts are thicker, but all the control arms seem identical otherwise.
To press the subframe bushings out/in I built a tool using a generic U-bolt, a thick piece of metal, and a large eye bolt. The fronts a liquid-filled which was a surprise, and separated from their metal sleeve during removal. I later cut the sleeve out with a dremel. There is a proper toolkit for this from KTC, specifically to handle the 211/219/230 subframe. $500 if you can find it.
Couldn't press out the 4 bushings holding the diff to the subframe, just left them alone, no play. Same with the two large bushings which connect the subframe to the lower control arms.
Everything is good except the rear toe is so bad its like 4-wheel steering. Not a DIY item so getting that handled today.
Old Aug 8, 2025 | 11:48 AM
al00sh's Avatar
2004 W211 E55 AMG
If you have a list of the part numbers including the various hardware that would be very much appreciated as I am in the process of doing the same thing here soon
Old Aug 8, 2025 | 11:51 AM
mekantor's Avatar
Yeah I have a spreadsheet and it includes some aftermarket cross-reference numbers. I also put together a single page document of all relevant tightening torques.
I have a few meetings to get through, but later today I'll bundle it all together and post here, along with a better process which takes into account my various mistakes and regrets along the way.
Old Aug 8, 2025 | 11:57 AM
al00sh's Avatar
2004 W211 E55 AMG
THAT SIR, would be extremely appreciated! Thank you
Old Aug 8, 2025 | 06:22 PM
mekantor's Avatar
First draft, will revise if I find errors or omissions
Preparation:
  • All the typical tools to work on your MB
  • 12-point triple square socket set (I got https://www.fcpeuro.com/products/10-...t-set-cta-3038)
  • Larger than normal torx sockets such as T55, T60, E16, E18
  • 12mm hex bit socket
  • 32mm 12-point socket for axle nuts (if removing axles)
  • Dremel with cutting wheels
  • Set of large ratcheting wrenches, 21/22/23/24mm. These are excellent, I got a 4-pack which doesn't seem to exist anymore but individual sizes are available (
    Amazon Amazon
  • If removing axles: chisel to crimp new axle nuts
Other items:
  • MB lubricant (long-life grease) for axle spindles: 001989885112
  • Threadlocker, I'm a big fan of Loctite 248, which is like a chapstick applicator, better than the drippy kind
  • Penetrating spray for rusty exhaust components, axle spindles, etc
Lifting:
  • I had the car on a QuickJack, and used a transmission jack to lower/raise/roll the subframe+diff assembly.
  • IMPORTANT: Place extra support at the front, the car can tip over when the subframe is removed. I anticipated this and it did happen.
Work Process:
  • Make sure to have as little fuel as possible in the tank, less than 1/4 for sure.
  • Remove the outer rear underbody panels before lifting the car, some of the 10mm nuts may be unaccessible later. Leaving these on makes it difficult to access the front subframe bolts.
  • Break the wheel bolts
  • If you are removing axles:
    • Find a local shop to rebuild your axles, it is best done with specialized equipment. I got Febi 49889 boot kits but the diameter was slightly too large even though the part numbers matched, best to just let the rebuilder use generic boots.
    • If you have the older axle style (like my '03) which bolts to a flange, break those bolts first by jacking up each side of the car independently. Doing this later is extremely difficult because the entire assembly will rotate.
    • Remove wheels
    • The axle nut at the wheel carrier is crimped in. Cut it with a dremel.
    • Break axle nuts with an impact wrench OR remove center caps, put wheels back on, lower car, break nuts manually
    • Removing the axle from the wheel carrier requires a puller tool, usually rentable, I had a kit for axle & ball joint separation which worked great. Helps to spray some penetrating lubricant first.
  • If you have air suspension:
    • Drain air from the rear springs using DAS
  • Lift the car
  • Remove the exhaust, it is very heavy so be prepared to support it or have a helper on hand. I found it easier to remove the hanger nuts than to separate it from the hangers.
  • Label the position of the transaxle at both ends and in the middle where the halfs connect. MB says that vibration is possible if not installed in the same position. I failed to do this, but so far no vibration thankfully.
  • Put the car in Neutral. Don't do this with the key, instead lift the shifter panel, press the small lever at the back to unlock it, and shift it to Neutral.
  • Removing transaxle:
    • Remove shielding which protects the transaxle center bracket
    • Remove the nuts and bolts holding the diff-side flex disk to the transaxle, keep one inserted so that it doesn't fall
    • Unbolt the center bracket and remove the rear half of the transaxle
    • If replacing the front flex disk:
      • Support the transmission
      • Remove the transmission mount with support bracket
      • Remove the front half of the transaxle same way as the rear half
      • Place the transmission mount and support bracket back for safety, no need to torque until full assembly
  • Lowering subframe:
    • Remove wheels
    • Remove wheel well liners
    • Deactivate SBC with DAS
    • Remove calipers; MB says to remove them entirely, but they can be left to hang with a ziptie on one of the studs which hold the liner
      • Remove brake wear sensor from caliper
    • Unclip electrical connectors at the front of the wheel well on both sides (left: airmatic, speed sensor; right: airmatic, brake sensor, speed sensor)
    • Remove rubber hose between the fuel filler neck and the gas tank, seal the gas tank with something appropriate
    • Remove side paneling in the trunk
    • Remove upper nuts of rear struts
    • Disconnect air and electric lines from air springs
    • Unbolt and remove struts
    • Unbolt and remove air springs
    • At the rear of the subframe:
      • Remove the air line at the splitter
      • Disconnect the 6-pin harness for air springs
    • Remove shielding to reveal the parking brake connector
    • Remove parking brake cables from the connector
    • Support the subframe & differential
    • Remove the 4 bolts holding the subframe to the body
    • Lower and remove the subframe carefully, move slowly and don't let it tip over
    • Set the entire assembly on stable supports, such as jack stands under the four large bushings
At this point everything is accessible to service. Assembly is the reverse of what's above.
A few other notes:
  • All components should only be torqued when the axle is horizontal, you can get a magnetic level to attach to the axle and jack up each wheel carrier to level it.
  • Try to mark the rear track rod position prior to replacing it, this might help preserve rear toe alignment, but most likely this is pointless and you'll want an alignment anyway.
  • The E55 rear sway bar is discontinued, the E63 version is 2mm thicker and can be found new or used. The bushings are not servicable as far as I can tell.
  • All nuts should be replaced on the control arms, sway bar and links, struts and springs, flex disk. Depending on where you get it, flex disk may come with new nuts and bolts.
  • Subframe-Body bushings:
    • There is a special toolkit for these monsters, expensive and difficult to find. I built a tool using a U-Bolt, and Eye Bolt, and drilled a thick piece of metal to fit them. This let me turn the Eye Bolt and slowly have it shove the bushing towards the U-Bolt.
    • I applied the same MB long-life grease on new bushings to make installation easier.
    • The front bushings are liquid-filled and have a metal sleeve. Mine separated when getting pressed out and made a mess, the sleeves could then be removed by cutting with a dremel.
    • Front Subframe Body bolts have a washer which should specifically align with the shape of the bushing, check during installation
  • The level sensor link is probably rotten and falling apart, plan to replace it
  • These are metal on metal bushings, and for me could not be budged. Unless you can arrange for a shop with hydraulic equipment and proper adapters to swap these for you, don't bother. I have them all, PM me if you want to buy the set:
    • 2 holding the diff to the subframe
    • 2 holding the diff carrier to the subframe
    • 2 holding the control arm to the subframe
    • 2 holding the wheel carrier to the thrust arm
Parts (check your car in EPC as needed, these were applicable to my 2003 E55):
  • 2x Flex disk (if replacing): A0004110600, Vaico V3018140
  • 2x Subframe to floor bushing, front: A2113511442, Vaico V307349
  • 2x Subframe to floor bushing, rear: A2303511642 (all aftermarket versions are out of stock, don't bother)
  • 2x Subframe to diff bushing: A2113511142, Vaico V307472
  • 2x Subframe to diff carrier bushing: A2303511442, Vaico V300010
  • 2x Subframe to control arm bushing: A2223520865, Febi 22446
  • 4x Subframe to body bolts: A0029907422
  • 2x Thrust arm (bottom front): A2113502606
  • 2x Control arm / Handle bar (bottom center): A2113500306
  • 1x Track rod left (bottom rear): A2303500329
  • 1x Track rod right (bottom rear): A2303500429
  • 1x Tension rod left (top front): A2113503106
  • 1x Tension rod right (top front): A2113503206
  • 1x Camber arm left (top rear): A2113502906
  • 1x Camber arm right (top rear): A2113503006
  • 1x Sway bar (21mm version): A2113202911
  • 1x Level sensor link: A2113203289
  • 14x m14x1.5 nuts: N913023014003
  • 6x m12x1.5 nuts: N000000003276
  • 2x axle collar nuts: A0003531373
  • 1x exhuast sealing ring: A2114920181 (discontinued, found at alleuro.com)
  • 1x exhaust sealing ring: A2084920081
  • If replacing sway bar links:
    • 2x Sway bar links: A2113203389
    • 2x upper nuts: A1409900651
    • 2x lower nuts: N913023010002
  • If removing the flange-style axles:
    • 12x axle bolts: A0029901003
Old Aug 8, 2025 | 08:17 PM
al00sh's Avatar
2004 W211 E55 AMG
This is gold!! Thank you!
Old Jan 26, 2026 | 12:02 AM
Roberte01's Avatar
2008 CLK 550 Convertible
This is gold indeed, thanks for posting all the detail! I am in the middle of doing the same refresh, and have run into a couple of snags. First, in the rear subframe, the front bushing hole is roughly 67 mm.. It has these strange steel tangs that hold the bushing in, that got pushed up when I extracted the bushing. (Bought the Freedom Racing W211 bushing tool set)
The old bushing when pushed out did deform enough and spewed some espresso-colored fluid. The old bushing has an OD of roughly 67 mm and has these indents in its sides.
So here's the issue: EPC, FCP Euro, Pelican parts, all list these bushings as 211 351 14 42, made by Hutchinson. The ones I bought came from a local wholesale parts supplier, here are pics of the new bushing, which is 77 mm in OD at the midpoint of the bushing where it sits in the subframe.
Old vs new vary in OD by 10 mm:
I spent an hour or so trying to get the new one to start in the subframe, kept going cockeyed and would not start. I think I bent one internally as it got ovalled a bit. So for anyone who's replace these, where'd you get your forward subframe bushings, and how hard were they to install? (The rear bushings, the expensive ones, went in easily.)
Old Jan 26, 2026 | 12:13 AM
mekantor's Avatar
You're on the right track, but you only extracted part of the old bushing because it came apart.
That metal liner is a component of it. I cut it diagonally with a dremel and that gave it enough play to bend inward and come out.
Old Jan 26, 2026 | 12:20 AM
Roberte01's Avatar
Or am I missing the possibility that the old bushing left a metal sleeve behind and that needs to be pushed/cut out of the subframe opening? Don't see any reference to this in any other post on subframe bushings.....
Old Jan 26, 2026 | 12:27 AM
mekantor's Avatar
Yep:
Old Jan 26, 2026 | 12:54 AM
Roberte01's Avatar
@mekantor- Got it, thanks! I should have figured that out. Made quite a mess as it separated:
Realization #2 today was that the Vaico set of rear control arms (V30-7630-1) do NOT fit the E63, despite the local parts house's website listing that they do. All the arms are dimensionally the same but the bushings' holes are M10 on this set, vs. M12 on the E63 arms.
Realization #3: All the original control arms' bushings are really in pretty good shape, so I'm not sure they need replacing after all. However, the lower 'V' control arm that captures the wheel carrier, airbag, and lower shock mount's outer bushing is shot. As best I can tell this bushing is not available separately, correct?
Realization #4. Both sides' axle boots are split and spraying on the bag reservoirs. I ordered a pair of new replacement axles (211-350-08-02), one from BuyMercedesParrtsNow and one from Mercedes of Laredo. One was correct, one was incorrect despite both coming in a tube with the correct part number on it. Sigh. One's gotta go back. I am going to take the old axle's to my Porsche shop's rebuilder in Westminster CA to see if they can rebuild (or at least re-boot) these.
Attached Thumbnails Rear control arms-old-vs-correct-vs-incorrect-e63-axles-1-25-26.psd
Old Jan 26, 2026 | 03:14 PM
al00sh's Avatar
2004 W211 E55 AMG
https://www.youtube.com/watch?v=kPqYyW0lG3I
Theres an axle shop I used in Garden Grove, ATDK PARTS
10462 Trask Ave A, Garden Grove, CA 92843, United States
They’re good quality, great price and if you have issues they’ll remedy no problem
Old Jan 26, 2026 | 03:21 PM
Roberte01's Avatar
LOL, I literally dropped an axle off at ATDK 30 minutes ago to see if they would re-boot it. I'm a long time Porsche guy and have used their rebuilds in the past. From all the talk online I didn't think anyone was able to rebuild the E63 axles but the guy at ATDK didn't bat an eyelash at it.
Old Jan 26, 2026 | 03:22 PM
al00sh's Avatar
2004 W211 E55 AMG
I had to ask him 4 times just to be sure but they did take care of both my rear axles and haven’t had any issues since
Old Jan 26, 2026 | 04:33 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
"Realization #3: All the original control arms' bushings are really in pretty good shape, so I'm not sure they need replacing after all. However, the lower 'V' control arm that captures the wheel carrier, airbag, and lower shock mount's outer bushing is shot. As best I can tell this bushing is not available separately, correct"
You are correct. It is pressed into the aluminum control arms.
If the rear lower control arms arrive appearing "bent" or not aligned, the two pieces pivot around the outboard bushing. Just rotate until the bolt holes line up.
Also, there is a press bushing in the rear hub where the rear lower control arm outboard bolt goes through. That press bushing clamps on the control arm flexible bushing when you tighten the bolt. It is possible that the new control arm outboard bushing will not fit into the hub until you "pull" that hub bushing out a few thousandths of an inch. Just something to be aware of as I found it frustrating trying to figure out why my new control arms would not fit into the hub.
