Odd shifter/trans problem
1999 C43 AMG, 2005 E55 Wagon
2005 E55. Out of nowhere, car was in limp mode, stuck in 2nd gear. "Great" I think as I get ready to order another conductor plate kit.
However, I noticed the dashboard didn't know what the gear selector was doing. It had blanks where it normally has P/R/N/D or S/C/M. It also wouldn't shift past neutral so I couldn't put it in Park. I fiddled around with it and noticed it would allow me to go into park SOMETIMES after briefly releasing the brake pedal, and sometimes not.
I read online it could be battery issues, as the car did sit for a while and the batteries were dead last week. I had jumped it off and left it on a tender until full, but was getting the red battery warning. I replaced both batteries and reset all codes for trans controller, gear selector, and ESP.
Next day, after being on the tender all night: problem remains. I start the car and still see blanks on the cluster instead of P and S. I'm getting codes for brake light switch, shifter module, and ALL FOUR wheel speed sensors (highly improbable).
Any tips?
Any tips?
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
'99 and '05 E55 AMG
Possible ESM failure. Code P1856. That was the issue in my car. See attached. Be advised it will show as a failure in Xentry.
The following 2 users liked this post by bbirdwell:
nd-photo.nl (08-24-2023),
Sulaco (08-23-2023)
P1856
P1861
P1860
P1876
P2012
6210
6230
C215c
C249e
C261e
C259d
2005 CLS55 AMG W219 C219
Awesome documentation as usual @bbirdwell
Well, dealer doesn't sell the ESM, you have to buy the entire shifter assembly and there are only 2 left in the warehouse. $750 each.
I went to the scrapyard today and every 211 I could find was missing the whole shifter assembly. However, I spotted a 2006 CLS500 that hadn't had its shifter assembly harvested yet. So I got the entire shifter assembly for $18.
Swapped it for the assembly in my E55 and it worked fine. Problem is resolved! Thanks for the heads up @bbirdwell
nd-photo.nl (09-02-2023)
Sulaco (09-02-2023)
