Supercharger pulley bolt
Old Sep 16, 2023 | 02:54 PM
cannawhat's Avatar
E55 AMG
Have been trying to get the supercharger pulley bolt off so I can replace the bearing, however the bolt just wont come off.
I used the hose clamp method but under the torque, the clips on both the hose clamps simply squeezed through the metal prortusion they were supposed to provide leverage with .
Any suggestions? Would penetrating oil help here?
Old Sep 16, 2023 | 07:12 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
I used an impact gun, simply by lifting the fan enough so I could stick it through the fan housing. I use a Dewalt DCF899NT which has 950Nm max torque
Old Sep 17, 2023 | 02:07 AM
cannawhat's Avatar
E55 AMG
@nd-photo.nl did you use an extension? I removed the entire fan shroud but there still isnt space for an impact there.
Old Sep 17, 2023 | 06:18 AM
Yes with an extension indeed. I remember it was a pretty straight shot. If you have ample room, your engine mounts might probably be shot...(your engine will be sitting lower then)
You can lift the engine a bit with a jack beneath it.
Old Sep 17, 2023 | 10:39 AM
SICAMG's Avatar
2005 e55 AMG
A little heat will help too.
Old Sep 17, 2023 | 04:29 PM
cannawhat's Avatar
E55 AMG
@nd-photo.nl thank you for suggesting the dewalt. I went got the dewalt dcf 900 and omg, that thing is a real beast. I had been trying the harbor freight bauer earlier without success. I would have gone with heat next like @SICAMG suggested.
Couple of further questions
1. unfortunately, that black piece is all scratched up, I hope that does not have any functional implications.
2. Am planning on using this kit to remove the bearing -> https://www.harborfreight.com/bearin...maddox+bearing
Old Sep 17, 2023 | 07:16 PM
@cannawhat no worries, I also got stuck with a bolt and after investigating I also bought the DeWalt and I was able to get a stubborn bolt loose haha. Listen too my reactions in this video (first time I started using it)
1) You should be ok as far as I know. I believe the whole thing is magnetized when its engaged.
2) Use a workshop press or the hot/cold method. I used the hot/cold method
Old Sep 19, 2023 | 01:02 AM
cannawhat's Avatar
E55 AMG
So I was able to push out the old bearing by simply using two 4X4's and a hammer and a bearing and race tool. However there is a white portion in the inside of the pulley. Is this normal?
Old Sep 19, 2023 | 07:35 AM
I cant remember that being part of the pulley
Old Sep 23, 2023 | 02:38 AM
cannawhat's Avatar
E55 AMG
Hey guys, thanks for all your help ( especially @nd-photo.nl and @SICAMG ). Everything is back on and seems to be working well so far,( at the very least I was able to start the engine)
I did the following on the car since I got it a couple of weeks ago.
1. Transmission fluid flush
2. Engine oil
3. Differential oil
4. Supercharger pulley bearing replacement
5. cabin air filter.
I cant wait to get it off the jack stands and see whether I need to additional transmission fluid. Once that is good I need to give it a bath and go for a nice ride.
Next ill start looking into fixing the dents and fixing the scratched up paint.
Anything else I should take care of on a 160K 2006 e55
Old Sep 23, 2023 | 08:12 AM
machild's Avatar
Top Answer: 1
2006 CLS55 AMG, 2005 SLK 350 AMG
2. Engine oil
3. Differential oil
Full coolant change and supercharger oil change. Lot's of info here on both, so let search be your friend.
Old Sep 23, 2023 | 01:51 PM
Even further, change out the waterpump if it hasnt been changed. Same with all pulleys, especially the double idler pulley.
Also check out my build thread, hopefully it might inspire you > https://mbworld.org/forums/c219/8443...ld-thread.html
Supercharger oil, I got you covered Check my Youtube channel, I got mode vids there
