New Headlights!!
Old Dec 12, 2023 | 11:22 PM
pantyshanker55's Avatar
Mercedes E55 AMG
New Headlights!!
Hey y’all, these beauties came in the mail today, suuuper excited to throw them in, but I fear that I might be missing something or not as knowledgeable on the process. I was wanting to know if there’s anyone that’s done a job like this to their E55? I want to make sure I have absolutely everything I need for the whole thing so nothing breaks, or if I’m missing anything, fragile spots or screws, etc. I’ve watched some YouTube vids on the process and everything but I know the forum is where the real experts reside
Old Dec 12, 2023 | 11:51 PM
black06c230's Avatar
mgLipGD
I mean unless you’re opening them up there isn’t too much to it.
Old Dec 13, 2023 | 06:18 AM
C_Note's Avatar
2005 e55
What brand did you get?
Old Dec 13, 2023 | 10:40 AM
MR. BLACK's Avatar
HPF M3
Well.... they're either plug and play or they're not? 🤷🏻‍♂️
Old Dec 13, 2023 | 12:02 PM
Mercedes E55 AMG
I got them from top gear auto but the company that made them was Spyder
Old Dec 13, 2023 | 12:04 PM
Mercedes E55 AMG
You’re gonna love this one… I go to put them in and everything is going exactly as planned so smooth but there’s one problem. The connections for one of the ballasts were different… I call the support line from whom I got them from, they said “oh you have the TOP of the line E-class Mercedes” I said “yeah I guess” he said “the thing you’re looking at that’s wrong is the ballast for the motor that moves the headlight bulb up and down, left and right, unfortunately those headlights you got do not have that, you can still use them but the bulb won’t move up and down and such and it’ll also throw an error code on your dash telling you that motor is out because it can’t find it.” And let me tell you man that broke my heart just absolutely shattered it.
Old Dec 13, 2023 | 12:06 PM
Mercedes E55 AMG
then they told me “we don’t sell those ones and idk of any other company that does”
Old Dec 13, 2023 | 12:26 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
As soon as you posted that picture I knew those wouldn't work but you were too pumped. I ran into the same problem when I replaced my lights (I bought different lights than you) and found out the connectors were wrong. I ended up ordering these:
https://www.uniquestyleracingstore.c...ctor-headlight
R.K.
Old Dec 13, 2023 | 01:08 PM
Mercedes E55 AMG
R.K.
thanks for reaching out. The link you sent me were headlights without the AFS function I was needing them with AFS.
Old Dec 13, 2023 | 01:18 PM
radride's Avatar
sorry, what does afs stand for?
R.K.
Old Dec 13, 2023 | 01:26 PM
Mercedes E55 AMG
R.K.
“The Adaptive Front-lighting System (AFS) optimizes distribution of light from the headlights according to driving circumstances. Depending on vehicle speed and steering input, the system points the low-beams headlights in the direction the driver intends to travel” -google
It moved the bulb in the direction the steering wheel turns I’m pretty sure. When I bought the car it was my first time hearing about them too.
Old Dec 13, 2023 | 02:00 PM
radride's Avatar
I believe my car came with them originally but I never saw them work. I bought this set because outside of this option is the OEM option.
R.K.
Old Dec 13, 2023 | 03:31 PM
Mercedes E55 AMG
R.K.
does it throw a code on the dash about it, Saying that it isn’t available or something?
Old Dec 13, 2023 | 04:22 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Active headlights are code 615. Code them out as "Not installed" using STAR/Xentry. If an error, you will receive an error message on the instrument cluster referencing the failing/failed headlight.
Old Dec 13, 2023 | 04:27 PM
Mercedes E55 AMG
So I can just use a OBD2 scanner and code them out and it won’t give me a message on the cluster anymore? I also don’t have the correct ballast for it. The ballast that moves the motor in my current ones have a different connection than these, idk if it’s NEEDED or if it can stay unplugged.
Old Dec 13, 2023 | 05:46 PM
radride's Avatar
No.
R.K.
Old Dec 13, 2023 | 08:13 PM
mgLipGD
Go here to put your VIN in to see if your lights are active.
lastvin.com
code 615
if you need active lights you either have to buy OEM or get reg HID headlights and code them out using STAR
Old Dec 13, 2023 | 09:49 PM
tlambert's Avatar
2005 E55 AMG
Check FCPeuro.com
Old Dec 14, 2023 | 12:44 AM
radride's Avatar
lastvin.com
code 615
I checked and I don’t have 615 option on my car.
R.K.
Old Dec 14, 2023 | 08:40 PM
mgLipGD
R.K.
so then just reg xenon/HID units are needed
you can open them up and make them even better if your wanted to
Old Jan 26, 2024 | 02:28 AM
E55chuck's Avatar
2006 E55 AMG
R.K.
I recently bought these. They are very decent (7/10) but not OEM at all. I am going to swap all my OEM internals into them to make them better.
Old Jan 26, 2024 | 02:40 PM
Fountain35's Avatar
R.K.
Do those replace the halogen lights or is it only for the cars that came with the upgraded xenon lights?
Old Jan 29, 2024 | 12:23 PM
radride's Avatar
These are only for the xenon light cars. You can't upgrade to these.
R.K.
Old Jan 29, 2024 | 12:24 PM
radride's Avatar
Correct. OEM was around 1800 per light so I opted for the cheaper route after talking to my buddy who works in the autobody industry. No point buying OEM because in a accident, the insurance company will replace with aftermarket anyways.
R.K.
