E55 AMG 8 pistons caliper torque spec
I need help from you guys. It's been awhile now that I am hunting for torque spec data for those caliper and I can't find anything online on google. I installed those 8 pistons caliper on my 1990 Supra and I want to properly torque them. For my car, I have the full shop repair manual so it's super easy but for the MB it seem to be quite hard to find anything, im I crazy? hehe
I need to find the torque spec for :
1. Caliper to bracket (10mm allen bolt)
2. Bracket to hub (M14x1.5 bolt)
3. Brake hose fitting to caliper
Thank you very much for help!
i see they strictly say to not remove the caliper from the bracket. But I reslly
had to so I hope it doesn’t cause any problem. It confirm me that I really need to find the torque spec. I will put locktite on them before torquing them down.
---Front bolts A001-990-08-14 (~$12 for a pair); torque to 180 Nm (133 ft-lbs). You'll need a 14mm x 1.5mm tap for these threads.
---Rear bolts A211-423-00-71 (~ $10 for a pair); torque to 115 Nm (85 ft-lbs). You'll need a 12mm x 1.5mm "plug" tap for these threads. This type of tap has a short nose. A "taper" tap will hit the brake shield before cleaning the threads.
Info is in the WIS (Workshop Information System). If you have STAR/Xentry, you should have WIS on your computer as well.
I did bought new hardware in grade 10.9. I will put locktite on the thread to be sure. I still need to find brake hose to caliper and the 10mm allen bolt that hold the caliper to the bracket.
Caliper to steering knuckle = 180nm
Caliper to bracket retainer = 120nm ( Part number A0039907905 )
Caliper brake hose = 18nm
