Will these fit
Old Feb 13, 2024 | 04:07 PM
Griley's Avatar
C43
Will these fit
I check and based on what I look up it appears it will, but the E55 is not listed as one of the vehicles that will fit, but it says that it will fit E63.
I was under the impression that what wheels fit the E63 will fit the E55. I’m I wrong?
I have attached the specs for the rims in question
Old Feb 13, 2024 | 04:32 PM
cdk4219's Avatar
95 SL600
Depends on the clearance for the front brakes. That’s a large factor . I have purchased wheels that interfere with the brakes.
Old Feb 13, 2024 | 04:53 PM
Griley's Avatar
C43
The wheels are the OEM 5 stars, but it says it fits the E63 not the 55
Old Feb 13, 2024 | 07:14 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
They will probably fit then. The E63 has 6 pot calipers (360mm discs) vs the 8 pot calipers (360mm discs) on the E55.
E55
E63
Old Feb 14, 2024 | 07:14 AM
Griley's Avatar
C43
Ahh..I was always under the impression that both cars use the same brakes. Thanks for the explanation
Old Feb 14, 2024 | 11:20 AM
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
E55
E63
That white W211 E55 on the picture has 6 piston calipers from the W212 E63/ W204 C63 Black Series though
Old Feb 14, 2024 | 01:43 PM
Ow crap, those are 390mm discs instead of 360mm right?
[edit]
I believe I used a picture of the E55 from @UncleBenz55 withouth me realising it hahah
Old Feb 14, 2024 | 03:30 PM
