Shift to Neutral or Park HELP!
Old Jul 22, 2024 | 11:37 AM
Saurabh914's Avatar
E63 AMG 2009 E55 AMG 2005 E63 AMG Wagon 2007
Got this in my e55. Won't start even in park or neutral. Have to play with it then it starts up. Sometimes it'll start and the dash will still say "p" and the tranny will clunk into gear so I restart it and it's fine again. Is it the shifter link bushings? It does make a metal clicking sound when I shift from park>drive or vise versa.
Old Jul 22, 2024 | 12:23 PM
machild's Avatar
Top Answer: 1
2006 CLS55 AMG, 2005 SLK 350 AMG
The shifter is electronic and must report the current selection. Your best bet, as a starting point, should be to pull all the codes using MB Star or something equal to see what is reported.
Old Jul 22, 2024 | 08:39 PM
SICAMG's Avatar
2005 e55 AMG
Or at least look under the car at the shift rod bushing.
Old Jul 22, 2024 | 08:45 PM
Saurabh914's Avatar
Scanned it and got P240C code and another code that read “Selector lever position detection has failed.” So safe to say I may need an electronic shifter module. I saw one on eBay which offers a rebuilt module that works on w211’s. So I may go that route with new shifter link bushings while I’m in there. https://www.ebay.com/itm/11546213314...mis&media=COPY
Old Jul 22, 2024 | 09:05 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
https://mbworld.org/forums/w211-amg/...5-19-32-a.html
Old Jul 22, 2024 | 09:13 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Shifter has failed. Happened to me in my E55.
$18 shifter pulled from a 2006 CLS in the local junk yard and it was fixed. New part at dealer was $750.
Old Jul 22, 2024 | 09:31 PM
Saurabh914's Avatar
does your paddle shifters and C/S/M buttons work? Someone told me they won’t work if you swap modules.
Old Jul 23, 2024 | 02:15 AM
ls1_mast's Avatar
w220 S55 AMG 2004
if i remember correctly the new shifter needs to be codded but it is an easy job with DAS (MB star)
Old Jul 23, 2024 | 08:54 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Everything works.
From what I found in WIS, a "brand new in the box" from the dealer must be coded upon initial install. Once coded, however, it can be pulled and will work in any other model that uses the same shifter.
Old Jul 25, 2024 | 09:40 PM
Saurabh914's Avatar
Update: replaced the ESM and all is well. Thanks for the help
