Should be some already known advice but......
Old Jul 3, 2025 | 12:24 PM
al00sh's Avatar
2004 W211 E55 AMG
Don't run wheel spacers, I'm lucky I didn't see one of my front wheels just roll right beside my driver widow.
Old Jul 3, 2025 | 02:12 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
And don't put W211 wheels on a W210...14mm bolts versus 12mm bolts. A member of this sub-forum discovered this the hard way.
Old Jul 3, 2025 | 02:13 PM
al00sh's Avatar
2004 W211 E55 AMG
Ah yes, that too. Big no no
Old Jul 3, 2025 | 02:45 PM
05-E55's Avatar
2005 E55 AMG
Well, that answers my question about using different wheels with spacers!
Old Jul 3, 2025 | 04:19 PM
bobgodd's Avatar
2004 E55
Maybe someone can correct me on this but hub-centric spacers should be fine. The wheel sits on the hub not the wheel lugs, so you need a spacer that also sits on the hub, and also has it's own lip for the wheel to sit on to make sure it's like-for-like.
Old Jul 3, 2025 | 04:20 PM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
What's the issue with using a spacer? Years ago with my first MB, a W126 SEL500, I made 5mm spacers and upgraded from the stock 14" wheels to 16" from a SL. Spacer was sandwiched between the wheel and the hub/rotor with lug bolts torqued as always. Completely chaged the handling of the car in a positive way and never had any issues.
Old Jul 3, 2025 | 04:30 PM
al00sh's Avatar
2004 W211 E55 AMG
Well I just went through 3 or 4 different hub centric spacers and they all caused different variations of vibration, the last one felt like i was driving a Jeep with the death wobble I work in the tire/wheel/automotive industry and a lot of these spacers now are junk even if they're hub centric. Once I took them off, vibration/shakiness went away.
Old Jul 5, 2025 | 05:33 PM
SICAMG's Avatar
2005 e55 AMG
I always used hub centric billet spacers and never an issue. The cheaper cast versions are a no no for sure
Old Jul 5, 2025 | 07:08 PM
al00sh's Avatar
2004 W211 E55 AMG
I don’t even know why I had them on, the offset on my wheels is perfect and there was no need for them.
only thing is I still have a vibration sometimes at 90+ and I’m not sure if maybe my drive shaft needs to be rebalanced or what
sometimes it happens sometimes it doesn’t but most of the time it does
Old Jul 6, 2025 | 08:11 AM
SICAMG's Avatar
2005 e55 AMG
Check the center bearing on the shaft. You can get in there and give it a shove to see how much it moves and inspect the bearing bushing.
Old Jul 6, 2025 | 08:31 AM
machild's Avatar
Are there brand's you prefer?
Old Jul 6, 2025 | 08:41 AM
streborx's Avatar
Top Answer: 1
G550
Folks who are preoccupied with "looks" are too often unaware that spacers require longer bolts and compatible seat geometry in addition to the correct bolt diameter. IMO, too much $$ and risk just to hurl stones out of your tires at the windshields of others.
Old Jul 6, 2025 | 12:48 PM
cdk4219's Avatar
95 SL600
H&R hubcentric spacers with correct bolts. There aren’t many w211 spacer options because of the way the front hub is designed. The rear is no problem.
Old Jul 7, 2025 | 07:08 AM
SICAMG's Avatar
2005 e55 AMG
H&R like CDK stated....always worked well for me a couple times and others I know but the correct bolt IS VERY IMPORTANT like streborx said as well.
Old Jul 7, 2025 | 09:36 AM
streborx's Avatar
Top Answer: 1
G550
Here's what can happen with short lug bolts.
Old Jul 7, 2025 | 04:26 PM
SICAMG's Avatar
2005 e55 AMG
Wow what a wild ride that was !!!!
Old Jul 7, 2025 | 11:32 PM
al00sh's Avatar
2004 W211 E55 AMG
I had the correct length lug bolts on and still had the vibration, I used to own a wheel and tire shop for years so I’m pretty sure about correct lugs I just took them off and decided to stay away from spacers
Old Jul 8, 2025 | 09:53 AM
kiluminati616's Avatar
2004 E55 AMG / 2019 Audi Q7 / 1991 300TE
+1 for h&r hubcentric spacers with correct length lug bolts. been running 10mm in the rear for a few years now with no issue
Old Jul 8, 2025 | 11:16 AM
streborx's Avatar
Top Answer: 1
G550
I recall reading another thread where someone experienced wobble and it was due to an incompatible lug bolt conical seat with wheels designed for ball seats. I thought about using a set of wheels and tires with my G550 that would have required bolt pattern adapters that needed to be 3/4" thick, but decided against it because of the change in offset.
Old Jul 8, 2025 | 11:44 AM
al00sh's Avatar
2004 W211 E55 AMG
You know now that you mentioned that, i think thats what my issue was and it totally flew over my head!!
Old Jul 8, 2025 | 01:32 PM
al00sh's Avatar
2004 W211 E55 AMG
On a side note, anyone know why my front parking sensors go off whenever i come to a stop, showing 2 red lights on both sides of the sensor? Car is lowered but not slammed
