FML - one lousy screw...
Remove serpentine belt, use long needle-nose pliers to remove coolant hose clamps attaching the flexible coolant lines to the oil cooler hard lines. Remove oil cooler with one screw an absolute PITA to remove of the four on the cooler.
Install new thermostat, install new flexible lines, install new O-rings on oil cooler, begin the reinstall of the oil cooler. That PITA screw went "tink!" and disappeared into the recesses of the engine.
Full stop until I can drive to the dealer and pick up an M4x8x1.0mm internal torx screw...
There where times when I believed that a black hole some how formed itself and sucked up the bolt into never never land because with multiple guys looking and snake cameras .....it was gone !!
Good times fixing cars !!
Good times.
Anything high-grade with a quality anti-corrosive coating would work.
I had a few spares of the SC fill screw at the ready (found a match at a local store) when changing the oil after gauging how tiny the screw was and how the tight angle to reach it was.
Now I have to cut down a wrench, attach a flexible rubber hose, and then I can install the screw by weaving the tool around the back of the hard lines...
