E55 mystery
Old Feb 28, 2026 | 03:25 PM
danil_karmiev's Avatar
E55 AMG
Originally Posted by JohnLane
OP what brand of spark plugs?
I have encountered counterfeit NGK plugs. Didn’t pay real close attention when replacing plugs. Had an intermittent rough idle after replacement that never set a check engine light (V-12 cars need something really wrong to set a misfire check engine light). Pulled all plugs and looked at them closely... sure enough plugs that are supposed to be iridium on center electrode and on ground side... some lack iridium in one spot, some on both. Look closely at plugs whilst comparing with information found on the web and yup! A decades long source of parts (obviously) unknowingly sold me eight (two boxes) of counterfeit NGK plugs. Another thing to watch for.
sparks are good
Old Feb 28, 2026 | 03:30 PM
E55 AMG
Originally Posted by brsilves
Hi. The reason that it smooths out is that in the absence of an oxygen sensor, the ECU makes some assumptions and gives you what it thinks is the best air fuel ratio. I don’t mean to be insistent, but that is another clue that the oxygen sensor is the issue. I’ll stop now, but having gone through the identical issue and researching I would really look at the oxygen sensor.
I replaced them
Old Feb 28, 2026 | 03:36 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by danil_karmiev
Appreciate the input. Just to clarify — I replaced the upstream O2 sensors only. The rear sensors are coded out since I don’t have cats. What’s interesting is unplugging the upstream on that bank actually smooths it out, which makes me think the ECU is reacting to a lean signal rather than the sensor itself being bad.
Can you scrutinize/plot/compare the sensor data as the ECU sees it using scanner?
Sensor may be good on a bad harness connections...
You have a perfect setup for comparison bank 1 reference vs. Bk2.
New sensor can be affected by oily harness to cause ECU to lean Bk2 mixture.
Old Feb 28, 2026 | 03:37 PM
E55 AMG
thank you will look into to it
Old Feb 28, 2026 | 06:39 PM
A bit overwhelming...
We keep walking right passed evidence we assume are okay - New upstream O2 may not mean good data.
The best way to go pass that is by looking at live data to understand : " Why is ECU leaning Bk2 ?"
Some odd looking ECU data may help you understand why it's acting up.
Compare your Bk1 vs. Bk2: something will float up.
Old Feb 28, 2026 | 08:06 PM
JohnLane's Avatar
222 S-65
OP one injector that delivers too much fuel to 5-8 will make exhaust for that bank smell rich to the O2 sensor and make ME lean it out.
Old Mar 28, 2026 | 05:32 AM
  #32
brsilves's Avatar
E550
Curious minds want to know….
Did you solve it? What was the cause? I’m still sticking to the O2 sensor, although certainly the O2 wiring/harness/connector could be the cause. Let us know! Inquiring minds want to know (and learn). Thanks.
Old Apr 21, 2026 | 07:33 AM
  #33
E55 AMG
Solved
We finally resolved the misfire on my E55. Turns out the timing on the misfiring bank was off by one tooth. The head had been removed at some point, and during reassembly, they missed it slightly. I bought timing tools on Amazon and set the crank pulley to 40 degrees. One bank lined up perfectly with the tool, but the other didn’t. We repositioned the cam gear on the problem side by one tooth. Once it all aligned, we reassembled, and now it runs perfectly—misfire is gone!
