E55 mystery
Old Feb 24, 2026 | 06:50 PM
danil_karmiev's Avatar
E55 AMG
E55 mystery
Hey guys, I picked up this 2005 E55 AMG from an owner who gave up on it—now I see why. Cold start - Smooth. Once RPM drops, though, it shakes and misfires—always Bank 2 (cylinders 5-8).
I’ve replaced coils, plugs, injector wiring, MAF, MAP sensors, resealed the supercharger and throttle body. Vtech tuned it. Compression’s solid, valves inspected, smoke test clean.
Odd part: O2 sensors disconnected = better. Closing the throttle = smoother. It’s lean at idle—my AFR gauge shows about 15-16 instead of 14.7. At higher RPM it’s smoother, and richer afr. I suspect mixture or timing. Anyone seen this M113K weirdness? Help!
Old Feb 24, 2026 | 08:46 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ALMOST GREAT M113k
I’ve replaced coils, plugs, injector wiring, MAF, MAP sensors, resealed the supercharger and throttle body. Vetch tuned it. Compression’s solid, valves inspected, smoke test clean.
Good job covering A to Y... what else can it be?
Now your engine is 99% in great shape.
The story reads like this: your M113K runs well while in open loop. In closed loop it is forced off the rail.
  1. What s your fuel rail pressure?
  2. Scrutinize your upstream sensors!
  3. How old are they ?
  4. What live numbers ?
  5. How much new Bosch ?
Old Feb 24, 2026 | 09:29 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Not timing. CPS sensor is hard mounted in the bell housing. If you suspect the CPS is intermittent, replace it. PITA, but doable. Yet this would not result in cylinders 5-8 misfiring, it would result in all cylinders misfiring.
Fuel rail pressure could be a suspect.
When coolant temperature is low the Motor Electronics add additional fuel to aid cold start/idle. The extra fuel is removed when coolant comes up to temp. That is where you indicate the AFR goes lean. So, verify fuel pressure with a gauge taped to the windshield if necessary. 5.1 Bar pressure regulator on the filter/regulator; usually see in the area of 5.3 Bar on the fuel rail.
When you pulled the supercharger, I assume you replaced the injector o-rings? Unlikely but something in the realm of possibility are air leaks around the injectors.
I am not familiar with Vetch. Have you reinstalled the stock programming? Personally, I don't think it will matter as the misfire is on cylinders 5-8 versus all yet I would place it in the basket for consideration.
Have you tried swapping O2 sensors side-to-side and see if the issue follows the O2 sensors?
From your description, I lean towards fuel pressure or O2 sensors or a combination of both. Fuel pressure is easy; O2 sensors can be a female dog so go for good ones. Genuine Bosch or Denso.
Be advised counterfeit products can be mixed in with Internet sellers so purchase from a trustworthy supplier. I once tried to save a few bucks and it bit me in the posterior when I ended up with a set of counterfeit spark plugs...my car made it a whole 23,000 miles while the spark plug gaps opened from 0.028" to ~0.060"...with an E55, don't skimp.
Let us know what your solution is.
Old Feb 24, 2026 | 09:49 PM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Don't waste your money on Bosch O2 sensors. Go with Denso.
Old Feb 25, 2026 | 10:36 AM
brsilves's Avatar
E550
Change the O2 sensors. Fact that it runs well cold - before the O2 sensors kick in - point to the sensors. I had a similar (maddening) "one bank miss" that was cured by replacing the O2 sensors...and no diagnostic tools (including STAR) picked up the bad sensors. Agree with the Denso sensor comment, just make sure you get the Denso with the right connector. Good luck. Let us know how it turns out.
Old Feb 25, 2026 | 10:55 AM
E55 AMG
Forgot to mention
O2 changed same issue
fuel pressure 80 psi at idle
injector seals re used but even though it still only affects cylinders 5-6-7-8
Old Feb 25, 2026 | 02:15 PM
CROSSING THE T'S
> So far you have :
  • good fuel rail pressure
  • new upstream O2 sensors
  • new ignition (coil+plugs)
  • clean MAF/MAP
  • good compressions
Now what's interesting is "closing throttle helps"...
This LEAN perhaps from significant "unaccounted air" bypassing MAF ??
Then let's check on possible vacuum leak nearest to Bk2.
You did smoke testing already...
Passed all right!
> What Gives...?
It's not fuel
It's not ignition
It acts like small air leak
-- Something specific to "Bk2 air" is overlooked.
-- This is significant enough to misfire your base fuel trim.
-- Nearly all right!
The PCV system has a clean air inlet with a large one-way check valve... is it failed and blowing back crankcase pressure into the plenum??
Spray carb cleaner carefully around Bk2 on cold engine to help locate leak source... (keep a fire extinguisher handy).
Old Feb 25, 2026 | 02:17 PM
E55 AMG
You have
clean MAF/MAP
yes
Old Feb 25, 2026 | 07:45 PM
from post #7
yes
Passed all right!
> What Gives...?
It's not fuel
It's not ignition
Old Feb 25, 2026 | 07:54 PM
E55 AMG
Passed all right!
> What Gives...?
It's not fuel
It's not ignition
thank you.
same thoughts here
Old Feb 26, 2026 | 08:38 AM
brsilves's Avatar
E550
Did you swap both the O2 sensors (upstream and downstream?) If you say it only affects one bank, I would CERTAINLY focus on the O2 sensors. Swap them side to side....
Old Feb 26, 2026 | 09:57 AM
E55 AMG
Replaced two upstream
Old Feb 26, 2026 | 12:00 PM
cdk4219's Avatar
95 SL600
> So far you have :
  • clean MAF/MAP
  • good compressions
Passed all right!
> What Gives...?
It's not fuel
It's not ignition
The 113k doesn’t have a MAF, so vacuum leaks will not look like unmetered air.
Old Feb 26, 2026 | 02:54 PM
Yes, true - Good catch: pressure vs. volume.
> FUEL/IGN... trims!
What are the LTFT Bk1 / Bk2 ?
What does that mean here ... ??
can one of the new coil/boit/plug/connector may actually be marginal calling a lean trim.
Old Feb 27, 2026 | 08:00 AM
brsilves's Avatar
E550
Since you replaced both the upstream O2 sensors, try swapping the downstream ones. And wait a while. May take the ECU a while to adjust.
Old Feb 27, 2026 | 11:36 AM
JohnLane's Avatar
222 S-65
OP reset adaptations. Light it up. Watch O2 sensors come online. Compare 1-4 with 5-8. Swap upstream O2 sensors between banks. Same after doing so? The O2 sensor is ruled out.
Pull spark plugs. How do they read? All lean for 5-8 where 1-4 look normal?
Watch adaptations. What is % of difference side to side?
The fuel is in a fuel rail. Pressure will be the same for all cylinders; esp at idle.
What do you have for misfire counts? An O2 sensor doesn't know a misfire from being lean if the charge doesn't light off in the exhaust manifold.
Old Feb 27, 2026 | 12:01 PM
E55 AMG
I checked my last data saved
Misfires are only on cylinders 5–8. 1–4 stay clean. Cylinder 7 is usually the worst one. When RPM goes up a little above idle, the misfires calm down.
Injection time is different side to side. Left bank is around 2.4 ms and right bank is around 2.7 ms, so it looks like the ECU is adding fuel to the 5–8 side.
Smooth running values are also worse on 5–8 compared to 1–4.
So right now all I know is the issue is definitely isolated to bank 2 and the ECU seems to think that side is lean.
It’s winter here so I can’t really tear into the car yet, but when weather allows I’ll start checking for possible air leaks on that side.
Old Feb 28, 2026 | 12:17 AM
JohnLane's Avatar
222 S-65
Rule out leaks with smoke. Keeping in mind with Speed-Density for engine management a vacuum leak will make for the throttle body being more tightly closed at idle than normal.
Swap injectors #7 & #8.
Misfire moves? Buy a set of eight injectors and enjoy smooth running.
Misfire still in #7? Cue scary music.
Unplug electrical connectors to both throttle bodies. Wet with crankcase vapors? They always are. A can of flammable brake cleaner will wash all that ick off. Clean up both throttle plates. Brake cleaner on a rag.
I solved many issues doing so.
Whomever it is who whined about replacing a crank position sensor.... don’t be such a baby. 1/4” drive ratchet, extensions and correct size socket + a new CPS should live in every 211 owners glove box. Only really unpleasant to do with a hot engine. Practice doing it enough to get good at doing it. You’ll be replacing it in the dark with rain.
Old Feb 28, 2026 | 06:04 AM
E55 AMG
new injectors, why swap ???
both throttle bodies???
cps is new
Old Feb 28, 2026 | 07:18 AM
JohnLane's Avatar
222 S-65
Swap injectors to see if misfire moves. If it does you have a dead injector. All injectors are the same age. One fails; we don’t want to play whack a mole with injectors annually. Injectors are also able to fail to ‘firehose’ Such that the engine ends up hydro-locked. That can make for a bent connecting rod. Or worse.
Two throttle bodies. One regulates power... the other is superdupercharger bypass.
Report back with findings.
Old Feb 28, 2026 | 08:51 AM
brsilves's Avatar
E550
As someone who had the same problem, and after doing (most) everything you have done, remember....there are few systems that affect only one bank. The MAIN one is the O2 sensors. I would suggest you get TWO new sensors (upstream and downstream - yes, BOTH) and replace them in the bank you are having issues with. I had similar issues with ONLY 5 and 6.... and why would the O2 sensor ONLY affect those two cylinders (who know?). I tell you...I had the IDENTICAL symptoms. I spent weeks looking for the cause. I even replaced the injectors (all 8). BTW, I assume you have the stock exhaust system. If you have headers, it's a different ballgame.
Old Feb 28, 2026 | 09:25 AM
E55 AMG
Thanks for the suggestions. I agree swapping injectors is a valid test, but since all four cylinders on that bank are misfiring, it seems unlikely they all failed together.
Also, they are new. unplugging the upstream O2 improves how it runs, which makes me think it’s a lean correction issue rather than mechanical injector failure. Smoke test didn’t show anything obvious, so I’m looking into something that would affect the entire bank.
Old Feb 28, 2026 | 09:27 AM
E55 AMG
Appreciate the input. Just to clarify — I replaced the upstream O2 sensors only. The rear sensors are coded out since I don’t have cats. What’s interesting is unplugging the upstream on that bank actually smooths it out, which makes me think the ECU is reacting to a lean signal rather than the sensor itself being bad.
Old Feb 28, 2026 | 10:23 AM
JohnLane's Avatar
222 S-65
OP what brand of spark plugs?
I have encountered counterfeit NGK plugs. Didn’t pay real close attention when replacing plugs. Had an intermittent rough idle after replacement that never set a check engine light (V-12 cars need something really wrong to set a misfire check engine light). Pulled all plugs and looked at them closely... sure enough plugs that are supposed to be iridium on center electrode and on ground side... some lack iridium in one spot, some on both. Look closely at plugs whilst comparing with information found on the web and yup! A decades long source of parts (obviously) unknowingly sold me eight (two boxes) of counterfeit NGK plugs. Another thing to watch for.
Old Feb 28, 2026 | 03:03 PM
brsilves's Avatar
E550
Hi. The reason that it smooths out is that in the absence of an oxygen sensor, the ECU makes some assumptions and gives you what it thinks is the best air fuel ratio. I don’t mean to be insistent, but that is another clue that the oxygen sensor is the issue. I’ll stop now, but having gone through the identical issue and researching I would really look at the oxygen sensor.
