Spoiler and Sat Radio Combination
http://www.mbwerks.com/osc/catalog/p...f6553fac6e4515
W211 Trunk Spoiler with Integrated SDARS Antenna
[211SPSIR]
$995.00
Click to enlarge
Autowerks is proud to offer a better solution to hide the SDAR (Satellite Digital Audio Receiver) antenna on your 2003-up Mercedes Benz E-Class. This product works with all sedan models, E320, E500 and E55.
Because of popular demand, we have integrated a SIRIUS satellite antenna inside a RENNTech W211 trunk spoiler that fits nicely on the trunk of your E-Class. The concealed SIRIUS antenna achieves excellent signal and reception strength, while the trunk spoiler enhances and completes the look of your E-Class.
The antenna receives signals from overhead satellites as well as terrestrial repeaters, ensuring you continuous reception. This kit comes with a single 20-feet micro-cable that has a curry-colored FAKRA-type SMB connector on the end. The kit is supplied with a SIR-SIP adaptor (SAT/TER) to allow connection to the factory Mercedes Benz SDAR receiver.
Professional installation recommended, and minor drilling required to secure spoiler.
This is a special order product, already will come pre-painted to match the factory color of your vehicle. Please allow up to 10-14 days before delivery.
Specifications: TBA
Pricing breakdown: RENNTech rear trunk spoiler - $395
SDAR Antenna with 20-foot cable - $70
SDAR SIR-SIP Adaptor - $30
Factory painting - $250
Custom fabrication and fitting of antenna module - $250
including connector modifications
The MBWerks option you're looking at is a bit pricey, although I've considered it myself.
Edit: My bad, link doesnt work anymore. Does this product still even exist?
The only problem I can see is that if you've already Sirius installed when you remove that old antenna you're going to have a quarter-sized hole in the middle of your trunk lid.
I'm sure you could do a custom job as the antenna does not need to be MB to work. There are lots of them available for Sirius. The trick will be getting a spoiler that is thick enough to cover the antenna and yet not crack, etc. with time. Make it and Sell IT!!!!
