How to make the kickdown from 7th --> 3rd in S mode?
Say, when I am at about 60 mph, if I floor it (holding the left paddle)==> it would go down only to 4th gear.
I tried few times to cruise at 60 either @ D6 or D5 and floor it from there with left paddle firmly held, and it still only downshift only to 4th.
I thought the tranny would go down to the lowest possible gear. 3rd gear @ 60 mph should still be within red line.
Can anyone give me suggestion on where I might have missed?
Many thanks in advance!!
Mitch
Then, I switched back to S mode and get to speed above 50 mph. Now I do get the tranny to downshift all the way to 3rd once I floored it.
Now I am a lot more satisfied about the accleration from cruising speed......
I found this also works in C mode. The only difference is that the down shift seems to have a bit more delay when it is in C mode.
I am wondering if the tranny is controlled by a system which would adjust how aggressive the downshift. If I don't drive the car as aggressive for few days, will it adjust back to default setting?
S is my daily driving mode and I was trying to find the best way to do acceleration on express or free way from cruising speed (just in case that I need it......
). I am now happy to find out how to get the ECU engaging in aggressive mode. I hope to make it stay that way.
Downshift in M is pretty fast; however, lazyness will have me in S/S+ mostly in daily driving. That's why I was a bit confused why my tranny would only get down to 4th before I realized it needs to be trained.
I noticed that, in M mode, I have to click on each downshift. Is there a way I can do by just holding the paddle and get to lowest gear?
I doubt they would problem the downshift button to continually down shift while holding onto it. imagine accelerating while pulling on the paddle, i'm sure some people don't know how to let go. :-)
But that's interesting what you're trying to do there, 7 -> 3rd gear.
I think the computer does a calculation which allows you to only downshift to a gear that is below 6K RPM or something along those lines. It would make sense that it does. Just a thought
But I could not make it act the same way in M. It just moves one gear with sigle click of paddle.
Do you know the trick in M?
Before flooring the gas, I need to wait for the auto downshift to take place first. This may casue the overall acceleration performance slower than just flooring the gas and quick clicking the downshift paddle.
I will play around some more and see which way is better.
Maybe I give a bit too much expectation in regard of acceleration from higher cruising speed. Given this is a N/A engine and with total weight over 4200 lbs, it is still a very powerful 4-door sedan with pretty impressive handling from this W212 frame!!
I am just trying to squeez a little bit our from it......
Must be the tune/map... ???
