Spray or tint to darken the rear lights?
Old Aug 17, 2011 | 03:45 PM
Centurion's Avatar
a car that gets very poor gas mileage.
I'd like to darken my rear lights but not sure which way to go about doing it.
I've met some who like the tint method and have had no issues, while others tell me it can peel along the edges or fade. I've personally seen quite a few that have either faded or turned into a matte (flat) look.
Some have also suggested spraying the outside to give the lights the same effect and that washing will not affect the spray. It's not permanent because the spray can be removed with thinner or gas, but that sounds like it might cause a haze on the lens surface.
Anyway, I don't even know what materials/formula of spray people are using to do this.
Any feedback would be helpful.
Thanks.
Old Aug 17, 2011 | 06:02 PM
EmE247's Avatar
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Mine were done w/ spray then buffed out for a gloss shine.
Check out my link in my sig to get close ups.
Old Aug 17, 2011 | 06:09 PM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
make sure dont let no half as$es spray your tints if you decide to spray and buffed out , most ppl use that vht nightshades
Old Aug 17, 2011 | 06:56 PM
Centurion's Avatar
Thank you both for the replies.
EmE427, that's what I'm looking to do. Came out perfectly on your lights.
I can still see that there's a gloss on the surface.
Now, how did you keep from spraying the white portion of the lens so that the entire light assembly is not darkened? Painter's tape?
MBFLO, thanks. I see this product at Amazon bundled with a can of clear coat for $20. Not bad.
I guess the real trick is how to spray in even coats so that the lens are not completely black.
Old Aug 18, 2011 | 10:33 AM
Vic55's Avatar
Administrator
Go to HMS in Orange County they will do a light coat of paint... they did this to my 997TT.
714 379 7770
Its cheap and they do an excellent job so you dont have to do it.
Old Aug 18, 2011 | 10:55 AM
MBFLO's Avatar
Would go with what he said if you close to them ...
Old Aug 18, 2011 | 11:02 AM
EmE247's Avatar
714 379 7770
Yes to the above as well. They did the tint on taillights on my car as well as all my other mods. Trust them like no other.
Old Aug 18, 2011 | 04:37 PM
Centurion's Avatar
Thanks everyone for the input.
Sounds like spraying is the way to go.
Not one recommended tinting.
Definitely need someone who's done it many times before with proper gear to do this right as there's no way to control output from a spray can.
Old Aug 21, 2011 | 09:23 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
1 for the Tint. Lol.
I had the red portion on my last 2 E's tinted, and the white portion on my newest one tinted.
I personally like the tint for the "cleanliness", as to not having to remove my tails to get them painted, or worse yet, having people paint them while on the car (anyone who would do that, run the hell away). I also like it because it can be removed easily, and seems more durable than paint, which needs to be waxed, and upkept just like regular paint.
I've never experienced peeling on any Tint, and any good shop with good materials will Warranty the tint for life, in regards to peeling or fading, etc. One negative of tint is that you can see the thick film around the edges of the tails, but it never bothered me and is hard to notice.
Old Aug 22, 2011 | 01:24 AM
princealidds's Avatar
2013 C63 AMG
I tinted mine......... looks clean..........
Attached Thumbnails Spray or tint to darken the rear lights?-mail.google.com.jpg
Old Aug 22, 2011 | 04:01 AM
_AMG_'s Avatar
C63
Like Vi55 said,
Go to HMS, they do great work.
