Got new tires today tire pressures???
Old Jul 24, 2012 | 03:48 PM
DriveAMG's Avatar
2019 E63s
All I could get was a new set of pzero. Same as factory. Any ideas on tire pressures? Different numbers on door jamb vs gas cap. Many help would be much appreciated.
Thx.
Old Jul 24, 2012 | 08:37 PM
vdubpower's Avatar
i drive them all, fast and hard
mine came with close to 40
Old Jul 25, 2012 | 02:57 PM
gfish's Avatar
GLC 63 S Coupe
I have the Pzero's and I have been running 35 front and 33 rear. I have about 5k on them and they still look great
Old Jul 25, 2012 | 06:59 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
I set them at 34 psi (cold) all around to minimize picking up road debris, ie nails.
Old Jul 29, 2012 | 01:56 AM
Racing Dad's Avatar
e63 2010 W212
depends on your preference, but all of the above is fine.
I run at 36/39 during winter. summer is 34/37, usually heats up to 37/40 ish.
feel it out and see what you like, but fronts should be -2 less (lower profile tires 30 vs 35).
Old Jul 29, 2012 | 01:10 PM
Count Laszlo's Avatar
'16 GL550, '12 C350
Just make sure you set psi when tires are nice and cold, I set mine in the morning.
Old Jul 29, 2012 | 05:02 PM
NickyBlack's Avatar
E63 AMG, E60 M5
35 all around
Old Jul 29, 2012 | 07:36 PM
otakki's Avatar
Try nitrogen to lessen the temperature increase.
Old Aug 2, 2012 | 06:33 AM
Jspeed's Avatar
E63 biturbo
Recommended tire pressures state that the rears should be lower than the front. Is this correct? All of my previous cars have higher rear pressures, if not same all round.
Old Aug 2, 2012 | 07:20 AM
hyperion667's Avatar
2012 CLS63
yes, try Nitrogen.........if you want to throw your money away
Old Aug 2, 2012 | 10:35 AM
Vic55's Avatar
Administrator
I think this is unique to the CLS--- as I see the same on the inner gas cap on my CLS63TT.
In regards to the E63 (2010) I would follow the lightest load recommendation PSI which shows on the inner side of the gas cap. These are cold temps though.
Old Aug 2, 2012 | 10:48 AM
Jspeed's Avatar
E63 biturbo
I was referring to my E63 TT. I guess it's unique to the M157 cars
Old Aug 2, 2012 | 11:35 PM
otakki's Avatar
That's strange. I thought the curb vehicle weight of the M156 and M157 engined car are quite similar, at around 4200 lbs. The weight distribution for M156 E63 is 54.5% front and 45.5% rear (not sure about M157 E63, though). So why would the tire psi front and back be that much different between the two cars?
Old Aug 3, 2012 | 03:25 AM
Racing Dad's Avatar
e63 2010 W212
which car is 4200 lbs? my plague when i open the door says 6200!
Old Aug 4, 2012 | 11:06 PM
otakki's Avatar
I think you are referring to GVWR (gross vehicle weight rating). I think that means the maximum weight allowed for the entire vehicle. In another word, you can carry another 2000 lbs.
Old Aug 5, 2012 | 12:22 PM
Mockbam5's Avatar
W212 E63
What should the tire pressure be for 19" AMG wheels?
Old Aug 6, 2012 | 12:35 AM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
pressure
glad I found this thread. I was reading the inner door jam and it said 51 PSi. I was shocked and looked at the max psi on Pzero is 51.
Why would there be different PSI ratings on two different places on the car
Thx.
Old Aug 6, 2012 | 05:56 PM
vdubpower's Avatar
its too bad there is no concensus on what the right pressure should be,
granted there are different climates, and driving styles, but there should be something close
