Anyone jump from C63 to E63?
Specific questions are more about stopping power (same brake set up as PP C63 but more weight to stop). I'm wondering if carbon ceramic options are worth the 13000$! I know driving dynamics are a bit less aggressive on the E.
I considered cls63 but since its 4 seat configuration did not suit me well. Back to the diferences. C63 has slightly better steering. It is a lot more harsher on the road. E63 is more refined. Adjustuble suspentions 3 modes...even in S+ mode it does not feel as hardh as c63 did.
Bottom line is if you track the car C63 is the way to go... If you want a sedan with A LOT of power, refined etc then E63 is the way to go.
I also picked up 2013 E63. Good luck
I actually was impressed with the E's steering. Moreso than the M5. It was more nimble than I was expecting it to be.
As previously stated, the C63 is more of a hooligan, lighter and nimbler. I had an 09 and the interior quality was not on par with its price tag. The newer models are better.
I loved the NA engine but the ability to tune the M157 makes an E/CLS a clear winner performance wise (other than the track).
It depends where you live and if you can spend the $$$. In FL, it is mostly straight roads so the extra weight disappears with the higher hp. $$$ wise, if you can swing it, I think it is a no brainer.
Especially, now that the reports are the 2015 C63 will be getting the M157 and 4matic.
If that's true, I want the next C63.
The C is much more tight, and rides much firmer than the E. There is no doubt that the E is larger and that is the way I like it.
After a while I get a bit tired of getting in and out of the C. The seats are significantly bolstered and can be tough to negotiate. The feature to move the steering column out of the way on entry and exit should also move the seat back. It did in my old 300C SRT8 and I really miss that feature.
The C handles and sticks like a slot car. It is blazingly fast with huge torque. I am still messing around with the E, and while it is bigger, it's amazing how fast it gets from, say, 65 to 95. I did run out to the desert a week ago and got mileage in the 20's.
I promise more reports to come.
