"Stock'' M157 vs M157 pp ?
What are the differences between the "regular" m157 engine versus the m157 engine with the power package? Is it only the turbo bars increased the 1.3 on the pp?
If i recall, the m157 pp had forged internals, is that true?
Thanks a lot in advance, guys and girls
I know the 6.3 (M156) had different internals in the PP version (forged vs cast) but I don't know about the M157... good question! I'm sure somebody will know.
On some models its even more- whats interesting is the S car gets 590 lb/ft tq in the CLS and E but my SL gets 664 tq yet I get less hp at 557---- and you guys get 570+ right? (2014 models)
i look at it that the flagship models (S/SL/CL) always get the more hp/tq over everything, although the new S63 has the same hp as my 63, but a lot more tq. your SL has more hp than the 2013 E63, i dont think they will give it a power bump until the refresh body.
The rods and crank I will assume are forged.
I would imagine the S-class has a different power curve than the E-class because of exhaust backpressure, which is probably different between the cars. More back pressure would mean more torque and less HP if it was otherwise optimized.
When you install the iron sleeves you need forged pistons and special rings that will work with iron deck and I'm looking for those special parts in order to rebuild the engine.
There are other ways too but I think your method is best. The other methods are to bore your engine slightly, have it honed with a Sunnen machine, and custom tin/ferro cote pistons from Mahle or Kolbenschmidt. You can also have your bore coated in Nikasil and use a regular uncoated aluminum piston.
MB is either understating the torque numbers for the E and CLS or the HP numbers for the SL - unless the power REALLY starts to fall off fast after the torque peak on the SL.
FWIW Mahle, if i had to guess, made the pistons for Mercedes stock. They have been making all of Ford and Chevy's forced induction pistons for some time and I know the also supply many other OEM's. They have much experience with the coated piston and bore technology. If indeed they supply the OEM M157 pistons they would be my first call. Hard to say as MB has kept a pretty tight lip on the M157 internals. I can't find much anywhere about them online. Mahle makes a very good piston.
Diamond can make pretty much any piston you need and has an excellent choice of coatings and ring packages available. We have used them in our high boost (35+) and high RPM (9000+) Ford GT race engines with both sleeves and coated bores. Expect to wait a good 6-10 weeks though.
Good luck getting it sorted.
Eric
