renntech experience
Old Feb 1, 2014 | 02:59 PM
sebc63's Avatar
2015 ML63
Originally Posted by m0v30v3r
Nope, dealer will upload all the files that are associated with your VIN and thats it. They cant do more. Every ecu is programmed based on what comes up on your VIN number..
Like said, everything according to the vin of the car. Dealer will not change anything!!!
Old Feb 1, 2014 | 09:44 PM
cnolke's Avatar
'12 E63 Wagon
Originally Posted by sebc63
With the programing by the dealer of the eCu and new ecu it came out to about 2k
Damn... the dealer sold you a second stock ECU and also a Renntech programmed ECU?... for 2k$?
This sounds amazing.
Old Feb 1, 2014 | 09:48 PM
sebc63's Avatar
2015 ML63
Originally Posted by cnolke
Damn... the dealer sold you a second stock ECU and also a Renntech programmed ECU?... for 2k$? This sounds amazing.
No,,, I wish!!!! The tune was 3k and change on the original Ecu that car came with and then i got a separate brand new Ecu which had to be programmed with the original stock tune and that cost additional 2k.
Old Feb 2, 2014 | 01:32 AM
vdubpower's Avatar
i drive them all, fast and hard
is that little dab of paint where they drilled??? or is it just my eyes
Old Feb 2, 2014 | 06:02 AM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
They ere all drilled at Renntech
Old Feb 2, 2014 | 10:25 AM
sebc63's Avatar
2015 ML63
I cant find or see and drilling marks on my ecu. Everything looks untouched.
Old Feb 2, 2014 | 11:09 AM
  #32
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
No there's nothing there.If they did it's darn good
Old Feb 2, 2014 | 11:38 AM
  #33
cnolke's Avatar
'12 E63 Wagon
OK, that's more in-line with my expectation
I was pulling out the CC and thinking "warranty be damned, who is this dealer?!?!"
Old Feb 2, 2014 | 12:22 PM
  #34
Vic55's Avatar
Administrator
Nice makeup on that ECU---- its stupid NOT to drill as flexing the board is far more risky. The drill occurs right where the programming occurs and the cover up is basically impossible to locate via the human eye. I have seen it with others and then lined up two ecus (one drilled and one not) and its impossible to find if the cover up is done well.
Id much rather have mine drilled than flexed out....
Old Feb 2, 2014 | 01:01 PM
  #35
Nanook's Avatar
Please elaborate..flexing / drilling ? why ? Is there a physical procedure involved to complete the tune ? I suspect so or it cannot be completed electronically through the connection port ? I suspect not otherwise the tune could be completed in the vehicle....so what exactly is performed...just curious
Old Feb 2, 2014 | 03:42 PM
  #36
Karl901's Avatar
Ok,
This why they are drilled.
Instead of cracking open the whole box they drill a access hole for a button/ switch on ECU board to be depressed.
Old Feb 2, 2014 | 04:21 PM
  #37
vdubpower's Avatar
what does that button switch do, ? all the data is plugged in thru there and sent??
whats these piggyback tunes people talk about?? how do they work
Old Feb 2, 2014 | 04:55 PM
  #38
Nanook's Avatar
Originally Posted by Karl901
Ok,
Interesting...thanks for this. So the button switch is already there and they are just accessing it ?. If indeed they did drill mine they concealed it very well..although I was not looking for it specifically I did not pick up on it..
Old Feb 3, 2014 | 12:53 PM
  #39
E63AMG's Avatar
Authorized Renntech Dealer Necessary?
Please help me understand something: I am unclear on whether or not it is necessary, or best, to go to a Renntech "authorized dealer" to get a Renntech ECU installed. It sounds like replacing the ECU is pretty much a "plug and play" operation, so can any capable Mercedes shop do this upgrade?
Old Feb 3, 2014 | 01:00 PM
  #40
Nanook's Avatar
It is a simple task task to remove...send to RT and re-install..but if you think your dealer may offer warranty based on them selling you the tune and if their take is reasonable then why not buy it through them...but yes is is easy to do yourself..5 mins
Old Feb 4, 2014 | 10:51 AM
  #41
grocery getter's Avatar
2016 AMG GTS Edition 1 Renntech
I was going to do the removal and install myself but I know how much of a hater the local MB dealer is about mods so the fact that their is a local Renntech MB dealer was a bonus...especially considering I still have 2 years left on my warranty. Hope this helps
Old Feb 4, 2014 | 12:23 PM
  #42
Vic55's Avatar
Administrator
The ECU is basically a myriad of chips on the board glued to the outer shell. The early adopters had their ECU's tuned via the removal of the glue from the board. This would yield a naked board (I had my CLS63TT in Nov 2011 done this way) but it was very hard to remove the glue and I "heard" that several tuners flexed the board due to force causing the electronics to fail (chips). This renedered the car dead. Subsequently the tuners found where they need to update the ECU and just drilled the hole; no glue removal or board flex or chance of frying the board.
Old Feb 4, 2014 | 01:40 PM
  #43
E63AMG's Avatar
Sorry, but I did not post my question clearly. I was not saying my local MB dealer would install a Renntech ECU. I was thinking of taking the car to a nearby independent repair shop that specializes in Mercedes.
The reason I would do this instead of going to an "authorized Renntech Dealer", is that the closest authorized Renntech Dealer is about an hour away from me. Also, it seems that the closest Renntech Dealer to me is more of a wheel/tire installer, not expert MB mechanic. If there are problems with the ECU that need fixing (like a plug swap), I would think my local independent Mercedes repair shop would be better equipped to do it.
So I guess I am asking did you Renntech ECU purchasers go thru one of the authorized Renntech dealers, or thru an independent repair shop, or through a Mercedes dealer? Thx!
Old Feb 4, 2014 | 02:05 PM
  #44
sebc63's Avatar
2015 ML63
Sorry, but I did not post my question clearly. I was not saying my local MB dealer would install a Renntech ECU. I was thinking of taking the car to a nearby independent repair shop that specializes in Mercedes. The reason I would do this instead of going to an "authorized Renntech Dealer", is that the closest authorized Renntech Dealer is about an hour away from me. Also, it seems that the closest Renntech Dealer to me is more of a wheel/tire installer, not expert MB mechanic. If there are problems with the ECU that need fixing (like a plug swap), I would think my local independent Mercedes repair shop would be better equipped to do it. So I guess I am asking did you Renntech ECU purchasers go thru one of the authorized Renntech dealers, or thru an independent repair shop, or through a Mercedes dealer? Thx!
Save yourself time and headache. Do it yourself. Call up Renntech and they will instruct you with everything.
Old Feb 4, 2014 | 02:11 PM
  #45
Agree going directly through renntech is the better cost option especially if you don't mind possibly risking the dealer finding out you modded your AMG
Old Feb 4, 2014 | 02:36 PM
  #46
sebc63's Avatar
2015 ML63
I didnt go thru my MB dealer and they do Renntech and I have no issues with the dealer.
Old Feb 4, 2014 | 06:33 PM
  #47
vdubpower's Avatar
still amazing that they can do a tune thru a teeny hole.... but then again i can do an acl recon thru 2 tiny holes
Old Feb 4, 2014 | 09:17 PM
  #48
335X-ray's Avatar
2021 GLS63
Yeah, but I can see the ACL tear with magic
Old Feb 5, 2014 | 02:33 AM
  #49
vdubpower's Avatar
i can diagnosis by listening to the patient first, and confirming when i took 75cc of blood from his knee....sent it to your field so insurance would be satisfied
Old Feb 8, 2014 | 02:49 AM
  #50
dubseven's Avatar
Benzos
Renntech is good stuff
