Front license plate solution for facelift e63. Tow hook plate?
I am looking for a good tow hook license plate kit that works well with 2014+ e63s and will not trigger front parking sensor. (I did search, no much info for the facelift models)
I was thinking to get usmillworks, which works well on bimmers with various positioning options that can clear parking sensor, however after called them, they said it will not work on Benz due to different tow hook design. Anyone has any ideas or share your experience if you have already got one? Thanks, guys.
http://www.gominigo.com/MB.html
Part #'s
'NO HOLES' LPB Kit - MB3-100 GMG-0002S-MB3-100
'NO HOLES' BRACKET - OFFSET3 GMG-0002S-BRKT OFF3
They seem to be good quality parts, but it's only been on the car for about a month. Quite solid.
I think I have a single flat washer stacked with the collet between the bracket and the bolt which threads into the car. That's the combination which provided the proper standoff. It would be a better install without the extra washer, but I couldn't tighten that one nut that fastens the plate backer to the bracket without the extra space.
Edit: looks like I've used too much bandwidth on my photos. They should be back up soon.
$0.02
Part #'s
Thanks for the useful info, ace10.
Suprisingly it does nor trigger the sensor as the edge of the license plate is right beside one of the sensor. Nice setup up, but personally I woule put it a bit lower, not sure if it is possible to do that.
There's precious little space to put a plate on the front of the car, other than drilling the bumper and using the OE mount.
I order to go lower, you'd need different brackets on both the horizontal and vertical planes. The gomini go plate plate mount isn't large enough, nor is the bracket wide enough. I think you'd need something custom to go lower.
Where I have it seemed to be the a happiest spot. You're dealing with three car functions you simply cannot block (lighting, cooling and parking beeper).
After some research, I came across The Platypus, with the pic of a regular 2014 E class with sport pkg shown on their website, it seems like it will work on our E63 without blocking the sensors. Just placed an order and will update you guys once it is mounted on the car.
The plate on your car looks good, but I would prefer to get one with more clearance to the sensor, just like how the pic shows on a regular E with sports pkg.
I had the sticker made identical to the personalised plate on the rear.
I am going to try it without the black mount to see which way I prefer.
slimline personalised plate in sealed plate protector. The size of the metal backing plate wasn't suited to the 4 holes already drilled into the boot, so some heavy duty double sided tape was employed. It's a great reservoir for water/dust to drip out after the chamois.
I know what you mean. I live where we have to have front plates. I've just resolved myself to accept the factory plate mount for all my cars. I actually think the E63S factory mount looks better than most. I also think that tow hook mounted plates look jerry-rigged. Unless you buy a car in a jurisdiction that requires a front plate and plan on moving to a jurisdiction that does not while you still own the car, I don't really see a point to avoiding the OEM mount. My $0.02.
