Baseline drag strip testing - Stock 2013 E63 w/ PP
Old Aug 1, 2014 | 12:44 PM
cnolke's Avatar
'12 E63 Wagon
I need to get better at using race-start -- when I use it and I get the revs up to about 3000 rpm and then let off the brake and slam on the accelerator, the '63 bogs down and jerks forward until it finally starts accelerating aggressively ..
When i tried with the brake torque -- it seemed like a smoother launch. I think the race start just is a matter of getting the technique mastered... not unlike dumping the clutch on a stick shift...
The logistics of having RS ready and working well at the tree, prepared to try and get a good reaction time, are way past what I can handle. I tried a few times to accomplish a good burnout and then race through the process and it was not ideal. Also, it kicks you off in M shifting, which is not optimal in my mind on the strip... I'd rather just be in S+.
I brake-torqued the car to 2200 RPM and then let the brake go at the last yellow.
I have a 2wd car though, so 2200RPM could probably be significantly raised for the 4matic cars.
Im pleased with a 1.93 60-ft for the 2wd wagon on Contis @ 30psi.
Old Aug 1, 2014 | 05:37 PM
ced357's Avatar
C63 BS, 2011 SLS, 2014 CLS63-S
Not sure why people are having trouble with race start? I always use it at the track and have never had trouble Also, all of my cars go into S+, not M after RS. Just make sure the wheels are straight, engine temps are good and traction is in Sport.
Lenny from RENNtech told me the best way to run the 4matics is to do it in dyno mode. I have not had a chance to try it but, he said it helps to alleviate the torque limitation. Worth a shot
Old Aug 2, 2014 | 12:38 AM
cnolke's Avatar
'12 E63 Wagon
I turn traction control off completely. Eliminates the chance a 2wd will pull power.
I can try RS again, but it hasnt been very successful in the past. 1.93 or better 60' on Contis show I'm probably doing OK.
I had the original poster by .1 to the 1/8th. He picked up a tenth on the big end, as is evident in his mph. I think that could be the weight of the wagon vs. the sedan working against me.
