Left hip bolster, driver side
You could consider the 'butt drop' seating technique.... easier on the side bolsters than sliding in. Getting out not much you can do really.
1) Set your seat to your preferred driving position. Commit this position to memory (spot 1, 2, or 3).
2) When exiting the car, slide the seat all the way back (the furthest it will go). Commit this position to memory. When exiting the car, rotate your legs to the left (your feet should be hovering over the ground). Lift your legs above the bolster as you're doing this (the extent to which you can do this will depend on your core strength).
Brace your right hand on the steering wheel and push/lift yourself up as you're lifting your left leg up over the bolster and putting your left foot on the ground.
3) When entering the car next, your seat will still be in the "back" position. This will allow you to turn and back into the car (butt-first). You can use your legs to lift your butt over the bolster (and you're now clearing the shortest portion of the bolster with the seat back). Sit down and rotate your legs into the car.
4) Use the memory button to put your seat back into the driving position.
Voila! You will now be making either 1) no contact or 2) very minimal contact with the thigh bolster on entry/exit.
I know the above sounds/seems absolutely ridiculous when you see it typed out like that but it is a surefire way to avoid the dreaded bolster wear.
The seats in my C63 are very heavily bolstered (I absolutely love them) and I have to use this method for entry/exit as well. At first, I'm pretty sure bystanders thought I was doing the robot getting when I was getting in/out of the car but now, it not only looks natural but it feels natural as well.
The best part is that the process has worked.
This is how it looks like after a year and three months: side bolster is worse than seat, time to try zibby43 patent technique....
Considering salads - YouTube
Bobby may not have appreciated it, but it's worked for me.
I should have explained this aspect better initially but I more or less use my right hand on top of the steering wheel to balance myself/give myself a little push as I rotate my legs to the left and pull my left knee to my chest. I always make sure the car is off when I use the steering wheel as bracing point as having the car off entirely "locks up" the wheel.
As soon as I can lift the entirety of my left leg (including my left "cheek") over the bolster, I place my left foot on the ground and use that to pull myself out (together with my hand). The right leg just follows after that; it doesn't come anywhere close to the bolster.
Some of my buddies have really nice Recaro buckets in their track cars. I've seen them using the same method (they have to do it just to get out of those heavily bolstered seats) with a slight variation; they pull themselves up using the door handle on the headliner.
Maybe I'll make a YouTube video with me getting in/out. At the very least, you guys will have some hearty laughs.
Ok, you use the steering wheel to brace your body and rotate left, now you are pushing off the steering wheel with one arm as opposed to the two arms I thought you were using?
I can barely do it with two arms...
And the hindquarter (did I just say hindquarter on MBWorld?) portion of my left leg just barely brushes the top part bolster as I'm getting out. Just having the seat all the way back when exiting helps a lot. And there's far less contact going on when exiting as opposed to entering.
Has moving the seat back and backing into the seat/swinging your legs in helped with the entering part?
