Upgrade spark plugs for tune Mercedes
Old Aug 5, 2015 | 06:20 PM
LFC09's Avatar
E63 AMG S Diamond White Saloon
pre-gap means that they have the specified gap out of the box, without you needing feeler gauges to check (still worth checking though). The gap is measured between the ground electrode (L shaped bent 'probe') and centre electrode.
Old Aug 5, 2015 | 08:09 PM
Davidkuo0330's Avatar
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
Thanks. Yes, Renntech plugs came pre gaped.
Old Oct 13, 2015 | 07:00 PM
TopGun32's Avatar
Originally Posted by TTA850
Plugs I've seen from RennTech are NGK part # SIZKBR8A8HS they are Alpina B7 plugs available from Amazon for $19.59/ea.
Amazon.com: NGK SIZKBR8A8HS Laser Iridium Spark Plug: Automotive
I've had them with my AMS tune for 11k miles so far no issues. Put down 590hp/726tq back in cool spring weather and most recently 562hp/685tq in 90* heat last week. Best dyno was 605hp/733tq but I don't have the graph
Press release on the plugs-
http://www.ngk.de/fileadmin/Dokument...oad_PDF_EN.pdf
Reasons to run a cooler plug-
https://www.ngk.com/learning-center/...or---do-i-need
Really a no brainier to go colder plugs, adding this much hp/tq anyone with knowledge modifying engines would suggest a colder plug. Same as putting a small shot of nitrous on an n/a engine, you could get away with stock plugs but a cooler plug will lessen the chances of issues.
I was getting CEL and misfire on Cyl #3 for the past 2 months. Dealer replaced coil pack and 1 spark plug but would still misfire at around 5k rpms.
I knew it was spark plugs... so after reading this post. I learned a few things.
*M157/M28 share plugs
*Gong 1 step colder in heat range is great for tuned cars and I have noticed the difference MPG is better than ever and power band is more responsive.
If you have a drop off in power, mpgs are down and have a misfire those are signs your plugs need replacement.
My car has 47k miles and 30k of them tuned.
I think overall.. tuners ask to replace spark plugs to avoid using a tune with worn plugs.
In my case.. on my next boosted benz (preowned) plugs would be my first mod along with a tune.
Old Oct 15, 2015 | 12:07 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
The general rule of thumb with adding more HP, is to go one heat range colder on your plugs per about 75hp increase. One reason why some tuners ask that you use their colder plugs or install colder plugs.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 15, 2015 | 01:18 PM
Tonycpa's Avatar
2012 Mercedes Benz E550 4Matic Sport Sedan
Originally Posted by sdg1871
I was told that I did not need upgraded plugs but would need to change my plugs every 10-15 miles which my MB dealer who is a Renntech dealer confirmed.
Old Oct 15, 2015 | 01:23 PM
Tonycpa's Avatar
Originally Posted by OrientBlue3
I did the Weistec plugs when I had my tune installed just to be safe. Thinking about adding the AMS heat exchanger just to add another level of safety with the Texas heat.
Bosch Silver
Old Dec 15, 2015 | 03:38 AM
  #32
medici78's Avatar
'03 G500, '13 G63, '17 GLS63,
For those who installed the Renntech/NGK plugs themselves, did you need a special tool? What does it look like?
Old Dec 15, 2015 | 11:57 PM
  #33
pali63wagon's Avatar
2012 e63 wagon
I did the updated NGk plugs and I just got it back
From having two plugs replaced for broken or worn diodes. I was having a rough idol.
Is there anything different from the updated plugs from NGk or the wiestec or Renntech plugs? I'm plug confused. I did the OE tune and had the plugs done at the same time.
5k miles later the two plugs are shot ?
What's the best plug period? Tell me I will buy them.
Old Dec 16, 2015 | 08:46 AM
  #34
Fairbird's Avatar
C300
1 step colder , 1st page ngk iridium would work , make sure to gap them to 0.026–0.028 depends how much boost you running
Old Dec 16, 2015 | 02:58 PM
  #35
kponti's Avatar
E63
Ok so part numbers for NGK, Denso and co? All the ones I have seen say they do not work for the E63
I think if it is not that difficult to replace, I will go back to copper plugs and swap out once a year (10-15k miles)
Old Dec 16, 2015 | 03:59 PM
  #36
medici78's Avatar
SIZKBR8A8HS was mentioned earlier in the thread. It is specified for BMW Alpina B7 but has been shown to work on the E63.
So nobody has replaced their own? I keep hearing a special tool is required. Anybody know about this?
Old Dec 16, 2015 | 07:50 PM
  #37
I don't know if a special tool was needed as my Renntech plugs was installed by my Mercedes dealer. I'm no mechanic, but back in the days I remember there is a certain torque you need to tighten the plugs so it's not too loose or tight.
I costed around $200 if I remember correctly to have the dealer install them, but would imagine it would cost less at your local Indy shop.
Good luck.
Old Dec 16, 2015 | 09:19 PM
  #38
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
Special socket needed if I recall
Old Dec 21, 2015 | 01:57 PM
  #39
kponti's Avatar
E63
What's the M28?
Old Dec 21, 2015 | 02:02 PM
  #40
kponti's Avatar
E63
Just got off the phone with NGK.
The SIZKBR8A8HS:
-8 heat range from NGK's heat range charts
-23.7mm reach on the threaded part
-It will handle up to 24lbs of boost without a problem assuming the stock starts out at 14psi
That 23.7mm reach is why there is NO other NGK plug that can be substituted for it. I wish someone could measure the stock and see if it matches this one.
I called Oreilly just to see what they had for stock replacement. They had Denso and Champion plugs.... for factory replacement
Denso (3444-Oreilly stock number) SC20HR11
-20 heat range on Denso charts
-26.5mm reach on the threaded part
Interesting to note, the Champion plug also had a 26.075mm reach. So for stock replacements (I am going to buy a stock plug and measure later today), it seems the range is 26-26.5mm. The RennTech and NGK substitutes are over 3mm shorter than stock
Old Dec 21, 2015 | 04:04 PM
  #41
TonyC's Avatar
e63 p30 estate
are the colder plugs recommended for stock cars at all?
Old Dec 21, 2015 | 04:13 PM
  #42
kponti's Avatar
E63
My guess is no. The car has been optimized for the stock plugs
Old Dec 22, 2015 | 11:49 AM
  #43
TopGun32's Avatar
What's the M28?
M278 4.7 v8 biturbo
Old Dec 22, 2015 | 02:03 PM
  #44
kponti's Avatar
E63
Factory plug for 2012 E63 (verified via vin number) which should be the same for all M157s is " A 004 159 64 03 "
Specs on direct measurements are as follows:
-Z6S113320 was the part number written on the plug itself
-26.45mm (threaded portion) Reach
So yep the RennTech plugs are 3mm shorter than stock and the Denso plugs are the right sized plugs for this car. I am going to use the Denso part numbers to find some colder range plugs and post that here too.
About the special tool needed, yes there will be a special plug socket needed cos this has a Torx shaped nut section of the plug. That is the only "weird" part of the plug. I will post a pic so you can see soon enough
Old Dec 22, 2015 | 02:58 PM
  #45
kponti's Avatar
E63
Stock plug
Old Dec 22, 2015 | 03:44 PM
  #46
KLR CLS's Avatar
CLS63 PP
Is it a 14 mm socket?
Old Dec 22, 2015 | 04:03 PM
  #47
kponti's Avatar
E63
I will try on some sockets tonight
Old Dec 23, 2015 | 09:20 AM
  #48
kponti's Avatar
E63
Yes 14mm deep socket like the one depicted here. What I do not know is if it needs to be thin or something like that (like one I used for a BMW in the past). But it seems there is nothing special about the socket needed to remove the stock plugs. The replacement plug however is probably a regular sparkplug socket
Old Jan 5, 2016 | 01:23 PM
  #49
zulumerc's Avatar
ECS Supercharged C6 Corvette& 2012 E550 Coupe
So what is the verdict on this? I have a 12 e550 m278 coupe with a tune that is now showing some misfires, it could be the plugs I am not sure. Is a colder plug necessary I have had the tune for 15k miles with no problems. If I should run a colder plug what should i buy what should the gap be? or just replace with stock and change out every 15k miles?
Old Jan 5, 2016 | 11:00 PM
  #50
kponti's Avatar
E63
Seems 10 to 15k miles with a tune or go colder
