E63 engine ticking
Old Aug 25, 2015 | 10:59 AM
e63estate's Avatar
e63 wagon
E63 engine ticking
have a new e63 wagon. i've been dealing with a lot of little issues (mostly interior noise).
there is a rattle that occurs when the car hasn't been driven awhile and is only noticeable at ~30MPH. i swore it was coming from somewhere inside the car, but now am convinced it is from the engine.
of course i can't recreate at the dealer, because by the time i get there the car is warm.
is this most likely the camshaft issue??
thanks!
Old Aug 25, 2015 | 01:45 PM
AMGJAY's Avatar
Ford Pinto
thanks!
What motor do you have?
My M156 was ticking and dealer ended up replacing the lifters and the intermittent sound is apparently gone now. Take it in for service.
Old Aug 25, 2015 | 01:52 PM
PeterUbers's Avatar
Does is vary with speed, or Rpms?
Is it a ticking or rattle?
Have you checked the tires for stones embedded in tread!
Old Aug 25, 2015 | 01:59 PM
e63estate's Avatar
e63 wagon
it is brand new...'16
e63estate's Avatar
e63 wagon
varies with speed...happens at ~30MPH
it is a ticking...sounds like a diesel engine
Old Aug 25, 2015 | 03:37 PM
PeterUbers's Avatar
Could be an axle
Take it in
Old Aug 25, 2015 | 03:38 PM
e63estate's Avatar
e63 wagon
Could be an axle
Take it in
going in tomorrow...just looking for any insight
Old Aug 25, 2015 | 04:21 PM
2012 merc amg's Avatar
2018 S560
Be aware, these engines are not the most quiet engines, can you shoot a video or sound track of the noise. My engine makes some noise but it's normal, I was concerned at first too. There are other strange noises right after starting to drive the car, pumps going on and off and that sort of thing. Not the most quiet car around, my Cadillac engine was more quiet than this engine for sure, but the Caddy was junk, these cars are awesome. Very unlikely you have a issue, these engines are inspected and re-inspected when they are built.
Old Aug 25, 2015 | 04:33 PM
e63estate's Avatar
e63 wagon
i'll try to record it...perhaps get my 11 year old son to press the gas pedal!
i'm not worried so much...but annoyed
Old Aug 25, 2015 | 04:45 PM
2018 S560
My engine ticks a lot, sounds like a sewing machine, two dealers said it was normal unless yours is worse. One of the most noisy engines I've had, but a great motor none the less, nothing like Lexus quiet though, if your coming from a Lexus or Honda can see why you'd be nervous.
Old Aug 25, 2015 | 04:49 PM
e63estate's Avatar
e63 wagon
nah...coming from a 911 turbo which also had its idiosyncrasies too
this doesnt seem like "normal" engine noise
we'll see what the dealer says
i havent been thrilled with the service dept so i wanted to arm myself with at least some knowledge
thanks for the replies so far folks!
Old Aug 25, 2015 | 05:19 PM
PeterUbers's Avatar
So over the past year a 2014 e63 member who had ticking had some gravel get caught in the front axles, some have reported tensioner pulley excessive noise and of fixed by dealer seems to come back, some have had stones in tires, there are shudders and vibes in the driveline that is normal particularly in Eco but only at low speeds ... Hope you get it sorted out.
Old Aug 25, 2015 | 06:43 PM
e63estate's Avatar
e63 wagon
thanks!
am i right to be disappointed with the build quality or is this the new normal?
Old Aug 25, 2015 | 10:04 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
The following will narrow down what the problem is:
You say it happens around 30 mph. Well, you have paddles to change gears while remaing at 30 mph. Down shift for higher rpms while holding the same 30mph. If sound does not change in pitch you can pretty much rule out the engine and lifters and such.
If the sound remains the same when shifting gears it is something else that is not likely engine or trans. Could be gravel in an axle as was mentioned, but this sounds a bit more rare than likely. I would then look at a bad wheel balance somehere first that "excites" the resonance that creates the sound, or it will be drive shaft or differential related.
The really good news is that it is brand new. You will get it fixed at no cost to you for sure.
Best of luck!
Old Aug 26, 2015 | 09:50 AM
e63estate's Avatar
e63 wagon
so i tried driving in manual mode this am on the way to the dealer. couldnt hear any ticking in 1st because the overall engine noise was very loud. could hear it in 2nd and 3rd.
when i dropped it off, i spoke to the shop foreman. he said the ticking might be the purge valve? not sure this makes much sense since i only hear it when the engine isn't warm and at 30MPH.
i have 2 sets of wheels and i can hear the ticking on both sets so i don't think is the tire balance.
Best of luck!
Old Aug 26, 2015 | 10:46 AM
beegee227's Avatar
2012 E63 P30 Wagon
might be something in the suspension. I would have them look at:
Control arms
Ball joints
Upper/lower tie rods
Sway bar bushings
End links
given your car is brand new, it shouldn't be these issues, since they are wear and tear items...
Old Aug 26, 2015 | 03:58 PM
e63estate's Avatar
e63 wagon
picked up the car...said it was purge valve and that it is "normal"
Old Aug 27, 2015 | 12:09 AM
2018 S560
That was kinda what I thought, the purge valves in these motors do make some noise that is different sounding from most other cars. If it really bothers you request that they replace it, they could verify the noise in infact the purge valve by simply disconnecting it and then listening, although this should be done at the dealer as it will trip a check engine light with a code 443. Sometimes replacing the valve does the trick as you get some valves that are louder than others due to varying tolerances when produced. I have heard of people putting a/c insulation around the purge valve and having that helping, but you should try to work with the dealer first on this issue, after all you paid big bucks for the car.
Old Aug 27, 2015 | 06:08 AM
PeterUbers's Avatar
Weird conclusion
I don't have this ticking
Old Aug 27, 2015 | 09:15 AM
e63estate's Avatar
e63 wagon
Weird conclusion
not sure i buy it...i haven't had the best experience with this dealer's service dept (long story, but they managed to scratch 8 rims...2 sets of wheels!)
this was the dealer i purchased from so i assumed i would get better service. there is a dealer right down the street from my office. thinking of giving them a shot.
this is all quite annoying!
Old Aug 27, 2015 | 09:17 AM
e63estate's Avatar
e63 wagon
i'm not convinced. driving to work this am, i pulled over after i heard the ticking. popped the hood and the valve wasn't even engaged.
i can't seem to recreate it at the dealer either. really frustrating.
Old Aug 27, 2015 | 10:12 AM
2018 S560
I'd give it some time, you have a warrantee for 4 years.
Old Aug 27, 2015 | 10:17 AM
e63estate's Avatar
e63 wagon
i'm the first to admit that i'm OCD...such a pleasure to drive, but the random noises are getting to me!
Old Feb 22, 2016 | 11:52 PM
Keiththecop's Avatar
2019 E63s AMG
Just jumping in on this thread. I've had my 14 E63 since June 15. Since I got it it has also had the ticking. Seems to be in the 25-40mph range. They originally did the chain tensioner which just did the start up tick. Then they replaced pads and rotors. The car has been in a total of 54 days in 7 months.
Their last suggest was they were submitting it to AMG for a response. I'm submitting the car for lemon law. Besides the ticking, the panoramic roof shade was an issue 4 times as well as the drivers side front window. Love the car, but at $100k I find all these issues to be unacceptable.
Old Feb 23, 2016 | 10:17 PM
PeterUbers's Avatar
I feel your pain but I don't think they make a $100k in any skin that doesn't have these issues
Cars just aren't perfect
