Need help with w212 e63 jerk
Old Dec 29, 2015 | 02:02 PM
xheamgbenz's Avatar
W203 C32 AMG...W221 S63...SOLD...W212 E63 CURRENT
I have a 2010 e63 and when it's on c mode it's jerks and when is in s it's fine when I have it in s+ it also jerks.... I read all the threads In here and no solution any idea or help....
Old Dec 29, 2015 | 02:39 PM
PeterUbers's Avatar
First
Reset the tcu and drive normally (normal for you) for 100 miles and report back
Search "reset tcu" on this site
Old Dec 29, 2015 | 03:14 PM
xheamgbenz's Avatar
Ok I will do it and let u know thank u
Old Dec 29, 2015 | 03:55 PM
PeterUbers's Avatar
No problem, I have more ideas for you if that doesn't work
Old Dec 30, 2015 | 02:30 PM
xheamgbenz's Avatar
I reset the tcu and still the same. I'm try and update the tcu software next wed and see what's gonna happen
Old Dec 30, 2015 | 04:07 PM
PeterUbers's Avatar
You've already put 100+ miles on it?
Is it a downshift clunk or up shifting
Was the car driving well for a while and then recently started doing this?
How many miles on the car?
May be a bad valve body or clutch pack
Old Dec 30, 2015 | 04:09 PM
xheamgbenz's Avatar
It only does it in the beginning and the u can see the rpm go up and down
Old Dec 30, 2015 | 04:16 PM
PeterUbers's Avatar
Like when the car is cold and you first start driving?
Old Dec 30, 2015 | 08:35 PM
xheamgbenz's Avatar
Yes and hot at the same time it weird
Old Dec 30, 2015 | 11:05 PM
astolfor's Avatar
2015 AMG 63S wagon
mine does the same thing, and the dealer has not answer... I guess all do that
Old Dec 31, 2015 | 12:01 AM
PeterUbers's Avatar
When did this start
Was it ever smooth shifting
Anything else not right about the car and its drivability
Are the first owner?
Old Dec 31, 2015 | 12:15 AM
astolfor's Avatar
2015 AMG 63S wagon
in my case since I took the car out of the dealership. I have 4k now and although some software upgrades fixed some glitches the transmission still jerks and lags. Probably the worse drive of all my performance cars including a Morgan as old as me.
My girlfriend can start and shift my F458 smother than the AMG...pretty bad. Placed a complaint with MBUSA and pretty much got blown off. About to pull the plug and buy another brand.
Old Dec 31, 2015 | 12:56 AM
xheamgbenz's Avatar
When did this start
The car has 48xxx miles and it just start doing it like 1 month ago...
Old Dec 31, 2015 | 12:58 AM
xheamgbenz's Avatar
I read over here and lot of people said they have it but no buddy has a answer
I'm try and do a software update and see what happens
Old Dec 31, 2015 | 02:12 AM
astolfor's Avatar
2015 AMG 63S wagon
software update did not do it for me...and the car is 2015. To be honest I just do not get it how MB can get away with all these issues.
What year is yours?
Old Dec 31, 2015 | 10:13 AM
xheamgbenz's Avatar
Damn mine it's a 2011 last year of 6.2s
I hope it's not a torque converter...
Old Jan 2, 2016 | 02:57 PM
screw991le's Avatar
2010 E63 AMG
There is no torque converter, BTW
My 10' has done it since day one, and have been looked at and reset more than once.
Old Jan 2, 2016 | 03:01 PM
xheamgbenz's Avatar
This one has a MCT.... Did u figure it out anything and one guy one here on the other post it can be a leak from the intake I'm check it on wed or Thursday and hopefully I get something bc it's annoying lol
Old Jan 3, 2016 | 11:52 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Right you could have a vacuum leak. Any CEL codes thrown?
The fact you have rough idle (rpm going up and down) is a sign of probable leak (common on M156 engines). Could be dirty MAFs also. Try clean them.
I don't think it is a transmission issue.
Old Jan 3, 2016 | 11:56 AM
PeterUbers's Avatar
I'm going to guess valve body
Old Jan 3, 2016 | 12:49 PM
xheamgbenz's Avatar
I don't think it's a trany issue too I think a leak or valve buddy I'm look at it wed and hopefully I get something and I don't have no check engine light or any other codes
Old Jan 3, 2016 | 01:11 PM
PeterUbers's Avatar
Just re read your first post
Totally normal in s mode?
That would rule out valve body and clutch packs I would think
Let us know please what they come up with as this will help someone else in the future
Old Jan 3, 2016 | 01:27 PM
xheamgbenz's Avatar
Of course I will lot of people have this issue
xheamgbenz's Avatar
Thanks for your time
Old Jan 3, 2016 | 02:38 PM
Celicasaur's Avatar
W212 - E63 AMG
For what it's worth, I'll chime in too.
My car does this. Took it to Eurocharged UK (very nice people there btw) and they diagnosed the solenoids to be at fault. Not majorly, but one in particular wasn't putting out the correct pressure or something.
Anyway, they replaced all 8 solenoids in the transmission and.....
...it still does it. I find it particularly annoying because it's most noticeable on the 2nd-3rd upshift and the 3rd-2nd downshift. It also does it a little on the 3rd-4th upshift.
It used to be really really bad going down into 1st gear, but now it's a lot better, although sometimes it still does do it, but just not that badly.
All references to upshifts and downshifts above are in C or S mode, not M.
I'm told it will adapt and improve through time (I don't buy that) but I've also been told that it's just a characteristic of this transmission...which I kinda don't buy either, because I'm sure Mercedes would have a hard time justifying this jerk to new car buyers on test drives.
