Bummer dealer won't replace my v burned headlights
. Anybody get headlights replaced under extended MB Warrantee? Maybe I should check other dealers.?
Good luck.
Best of lucky. I know it can be annoying.
report back if it works
its interesting with my first set i think it was after 2 yrs is when the Vs got burned in . I think ichanged teh lights about a yr ago now, and so far its ok, but im sure eventually it will happen
when i was in europe i noticed the pattern on all E class there, some had burned in, some hadnt
Since OP's car is CPO(I believe) headlights are NOT covered under CPO for replacement. This is a fact. I do not know weather this cleaning procedure is covered or not.
My SA says they'll replace the headlight lenses if the "v" becomes visible with the lights off.
Good luck.
If doing it a couple times per year keeps the lenses from being ruined, maybe it should be part of the spring and fall detailing job...
