DIY:Spark plug change M157/M278 biturbo
Old Aug 19, 2019 | 06:26 PM
  #76
delirium's Avatar
C350
Originally Posted by E55BOF
It is pretty tight in there; as I recall, I used 1/4-inch drive sockets, with universal joint adapter and extensions when necessary, on the job, and one way or another managed to get everything out. The metric E sockets don't have to be a perfect fit to remove the bolts, so a bit of an angle on them will still work - they don't have to be a totally snug fit.
wow, I'm surprised that you could get it out, that last bolt looks like its blocked by the coil pack itself. I may resort to taking it to a shop
Old Aug 19, 2019 | 11:07 PM
  #77
ItalianJoe1's Avatar
2003 CL 600
I use an 8mm or 5/16" socket usually for those E10 bolts, you can use a wrench on them if needed for those weird ones.
Old Aug 20, 2019 | 06:15 AM
  #78
BiturboSF's Avatar
E63 M157
Does anyone have the part # for the boots? Looking to change the spark plugs soon & guess I will order a few extra
Old Aug 20, 2019 | 11:33 AM
  #79
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I checked my photobucket for the original pictures and they are gone after all this time.
If you email the dealer parts department with your vin, they can order them for you , if not in stock. My hands are huge, so I just gave in to ripping the back couple off but shorter people may be able to finesse them off. It is a pretty easy job but you will need 1/4" drive, 3/8 and all the little swivel and short extensions you can keep next to you. Taping the swivel joint will help keep it from twisting so easy.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 22, 2019 | 03:19 AM
  #80
DalipD's Avatar
2014 W218
Bosch
Originally Posted by skark_burmer
Bumping an old thread because what i read there is still two groups as far as which plugs to use.
Group 1: OEM only.
which apparently is part number 004-159-81-03. Correct?
From my dealer = $38 each
Online = $15 each
Group 2: A plug is a plug, the dealer doesn't install any magic sause.
NGK part number ??
Bosch - ZR6SII3320 = $9 each
and many other vendors.
Since i am not too rich i'll skip the dealer option, but just want to verify the 81-03 part number is what folks are using. My dealer was less than helpful.
thanks guys.
Bosch just like NGK and Mitsuba make ALOT of electronic components for car companies that just get rebranded as their own. Bosch is known for making the majority of electronic components in european vehicles. So chances are very high that the OEM spark plugs could actually just be rebranded Bosch spark plugs. And even if they're not, Bosch makes some really good quality parts.
Old Sep 22, 2019 | 07:58 AM
  #81
byroll01's Avatar
E63s-summer/GLE63s-winter
I believe this was already shown for the Bosch plugs with a side by side and part number shot if the OEM ones.
Old Sep 22, 2019 | 05:03 PM
  #82
E55BOF's Avatar
2014 CLS63 SB, 2014 SLK55, 2008 CLK350 'Vert, 2004 Triumph Sprint 955i
DELETED - I'll start again.
Old Sep 22, 2019 | 05:12 PM
  #83
E55BOF's Avatar
DELETED. Sorry guys; it's late and I'm tired...
Old Sep 22, 2019 | 05:23 PM
  #84
E55BOF's Avatar
Originally Posted by TECHNICIAN
FALSE
Correct
FALSE.
DO NOT listen to this guy or you may cost yourself an engine. The plugs are indeed indexed by torque
If you reread my post, you will see that I stated that if the torque is correct, the indexing will automatically be correct. We're saying the same thing, no?
Old Sep 22, 2019 | 05:27 PM
  #85
E55BOF's Avatar
The Bosch plugs, and the Bosch plugs with the MB logo, are the same plugs. So long as they have the Bosch part number ZR6SII3320 stamped into them, you can be sure they're the right plugs.
Old Sep 23, 2019 | 10:25 PM
  #86
ghlkal's Avatar
2012 E550 v8-Biturbo
Thanks to everyone that contributed to this post. It's very informative. Although I "only" have 52K miles on my M278, it is a 2012 so I'm looking to change these sooner rather than later.
Old Oct 2, 2019 | 07:22 PM
  #87
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
Originally Posted by delirium
I tried replacing the plugs on my M157 (W219) today & I could not figure out how to get that last screw on the passenger side, closest to the firewall, out. It looks like its under part of the coil pack & angled so that you have no room because the side of the engine bay is right next to it. Any tips? TIA
I did this on my M278 and ran down to Autozone to buy a flexible 1/4" extension. That screw was so tight that it cracked loudly when finally loosened. It was a total bear.
I was able to pull the boot off slowly taking my time and twisting it. Switching up hands when one got tired.
The spark plug removal tool from Mercedes is a must IMHO..
Attached Thumbnails DIY:Spark plug change M157/M278 biturbo-photo619.jpg
Old Oct 2, 2019 | 07:23 PM
  #88
chsu74's Avatar
These plugs has 53K miles.
Attached Thumbnails DIY:Spark plug change M157/M278 biturbo-photo511.jpg
Old Oct 2, 2019 | 10:57 PM
  #89
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Just ordered these today, doing my brakes (also ordered from FCP) next week, oil change and might as well change the plugs.
Old Apr 19, 2020 | 03:32 PM
  #90
nj450gl's Avatar
GL450
how do you guys get the broken boots off the plugs that are still in the tubes?
Old Apr 19, 2020 | 04:24 PM
  #91
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Long nose pliers and muscle.
Old Apr 20, 2020 | 04:06 AM
  #92
nj450gl's Avatar
GL450
no room for pliers, I used an old steel fountain pen body, made a slit 1" long and squeezed the tip of the tube slightly smaller than the plug ceramic. jammed the other end into a 15mm socket, twisted and jammed it onto the plug, eventfully broke the boot which come off on top of the tube
Old Oct 15, 2020 | 07:26 PM
  #93
Maduro's Avatar
2012 CLS550 AMG Pkg
Originally Posted by diamondblak05
I'm attempting to change my spark plugs and just can't seem to get these little plugs off. They're the ones that connect to the coil, as indicate by the red circle here. Any special instructions on how to get them off?
So I'm having a hell of a time doing the opposite now, getting these back in and to snap/lock in place. I can't for the life of me figure it out! Any suggestions please? I have the grey tabs all the way out, I slide the connector/harness back onto the top of the coil but I can't get them to lock back into place. Either the gray tab won't slide back in or it does actually slide back but the harness doesn't lock in any way I can still simply pull them off!
Old Dec 9, 2022 | 06:57 PM
  #94
san40's Avatar
2015 e63 wagon
Originally Posted by amgggg...
Once you get the first connector off you'll see what the story is. There are little plastic nubs on the connector which the clips need to get past to release. The gray clips need to be pushed down very very firmly to release the connector. Although you need to be careful, I slid a small flathead screwdriver underneath the clip as far as it could go and just pressed up with it a little. Then I was able to pull the connector off.
Had to do that as well on some of coil packs, some released with just finger pressure - a few were quite frustrating to remove
Old Dec 11, 2022 | 11:40 PM
  #95
san40's Avatar
2015 e63 wagon
Changed spark plugs on my 50K M157 engine, no idea on their mileage. Took me 3 evenings, longer than I expected even with all the reading and preparation.
Used my burgertuning magnetic socket with extensions that I already had.
Used a bike wheel spoke to pull coils, was a perfect combination of strong and pliable. Unfortunately I didn't read the advice of warming up the engine. There were 3 distinct types of coils: 2 Mercedes and Beru. Put 4 newer identical Mercedes ones closer to firewall, perhaps will change the other 4. How to troubleshoot a degraded/bad coil without obvious codes or misfires?
The worst plugs by far were 4 and 8 (farthest against firewall). Cylinder 1 plug had some oil on the threads. Googling got me somewhat worried - any idea how to monitor and test possible causes?
Discovered that both camshaft position sensors on the left side leak oil into harnesses - ordered to replace all 4, no brainier after
Old Mar 28, 2023 | 12:28 AM
  #96
MercWyo's Avatar
W211 E55 AMG
Originally Posted by CCOOK
Just did this on my SL550 yesterday - the above tools are the ones you need.
I am not sure why any of you are using wrenches to pull the connectors; there isn't enough room for anything - I even bought a fancy set of BERU pliers from Baum tools that ended up being totally worthless; here is what you need:
You take this and do a crimp loop and then a loop-to-loop connection over the connector; make sure you slide the loop UNDER the plastic tab so you don't damage the coil pack connection:
Job went perfectly smooth and easy without destroying any connectors - don't waste time with stupid wrenches in such a tight space, and be sure to put dielectric grease on the ends of the connectors before re-inserting them.
You deserve a keg of beer for this recommendation. I ended up using paracord, but I was able to get all (8) off of my GL450-2014 with this method. I am not sure how I would have done it without this. Thank you!
