Tuning an E550 to AMG type performance
I figured I'd answer your question here, since there's no mystery in it. You're calculating a 20% driveline loss when a 20% loss isn't present. Not sure why "tuner brand x" that you mentioned is sticking to that 20% number, but the real number on most of today's modern cars is 15% or, in some cases, even less.
Still, convincing people that the decades-old wisdom of "20% loss on converter cars" is still current is one of the ways some shops "fluff" their numbers. I always say: look at the time slip.
brutus_tx (06-23-2020)
Thanks for posting.
Figuring a 15% loss on the stock E550 biturbo you tested, the baseline output of 419hp grew to 482hp and 473tq grew to 544tq?!
sub
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Not at crank.
482 whp / 0.85 = 567HP at Crank
544 wtq / 0.85 = 640 TQ at Crank.
Correct me if i m wrong...
I have also got more info on the Mustang dyno that I did. (Their machine reads really low...)
From comparison, someone's stock FR-S was dyno'ed at 144whp (Stock crank @ 200hp)
That is 28% loss.
If we use same calculation on mine.
then, it will be
417WHP / 0.72 = 579HP at Crank
472WTQ / 0.72 = 655TQ at Crank
I once said, this numbers are too good to be true.
As for time slip
A member here, pretty much same mod as mine. He ran 1/4 mile with 12.2sec @115MHP
https://www.youtube.com/watch?v=Y3gn...ature=youtu.be
Dynojet Dyno Graph http://dragtimes.com/2012-Mercedes-B...phs-28007.html
All these are just a reference, Time slip, track timing are the real deal.
#32
Mustang Dynos while very accurate at reading delta changes are also notorious for fudging numbers. One will read low, the other will read higher than a typical dynojet. All depends on the calibration the operator does. Keep that in mind.
Also I may be missing something but the link you provided showed a dyno of 476rwhp/539rwtq on TonyCPA's E550. I don't see how 482/544 is too good to be true? sounds like either a bit more power or typical dyno variations
#33
Tuning 2014 Mercedes E550 4matic
I have a 2014 Mercedes E550 with the twin turbo 4.6L V8. I have about 75,000 miles and I drive almost 35,000 miles per year. I was wondering if anyone knew about the reliability of tuning my car? I have heard different things, but would love to tune it but worry about reliability. Also, is there any other thing I need to do if I tune it (exhaust, intake, transmission)? Your input if much appreciated!!
#34
#36
Ya, just trying to figure out which tuner company to pay.
Did you upgrade the heat exchanger? Do these engines have issues getting heat soaked with tunes?
I ask because one tuner I talked to recommended a bigger heat exchanger to minimize dampening power, but I am not finding much information about it online.
#37
Heat exchanger for sure will help. But it is not necessary for just a tune from the shelves.
#38
Hi everyone. I am in the process of modding my 2012 e550 ... just ordered down pipes and in the process of choosing a tune(will probably be going with eurocharged) but just like a person above me mentioned, I don’t know what else should be of my concern, that needs to be upgraded. or will I be ok with just the tune and down pipes?
#39
EC tune and (catless)downpipes will net you 12.0 timeslips...ask me how I know! lol
Drivetrain is plenty strong enough. I run 11.3 @ 122 now, shooting for 10's by years end.
Siegmann (06-23-2020)
#40
well I’ve gone down the track and have done 12.5 and that was with a bad launch , so I’m sure I’ll see better numbers than 12.0 lol
#41
So what's the deal? I say there is no way a stock E550 4matic sedan will run a 12.5
Best you(or anyone else) will get out of a stock car is 12.8 Car and Driver
If your car is "stock" and ran a 12.5, it ALREADY has a tune...or you're not being truthful...
On a Eurocharged tune and a muffler delete I was running a 12.4-12.5, and I have MANY time slips to prove that.
#45
Best you(or anyone else) will get out of a stock car is 12.8 Motor Trend
#46
