[help needed] e63 NA not starting, electrical
Old Feb 18, 2016 | 08:18 PM
Pufftrees's Avatar
e63 NA
Went to start this afternoon with the push start and just hear a single "Click" when it would normally start up. The rest of the electronics seem to be fine. I changed my keyfob battery and still same. I then removed the push start and tried to start manually, still the same.
Right when the ignition would normally kick in there is just a single click. Also, the clock does a full spin backwards and then forwards.
Any ideas for trouble shooting? Just a weak battery?
THanks
Old Feb 18, 2016 | 08:38 PM
Davidkuo0330's Avatar
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
It sure sounds like your car battery. Are you on factory warranty ? If so, call your road side assistance and have your battery replaced.
Good luck.
THanks
Old Feb 18, 2016 | 08:59 PM
chris.bachman's Avatar
a car.
Voltage regulator or the alternator. Do you have a battery charger?
Old Feb 18, 2016 | 09:14 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Good luck.
+1
Old Feb 18, 2016 | 09:22 PM
Pufftrees's Avatar
e63 NA
I'll try to charge battery tomorrow and go from there. Not under factory warranty just aftermarket. Thanks
Old Feb 18, 2016 | 10:30 PM
nynd's Avatar
2018 E63S
When the clock starts doing that - most likely a sign of a dead battery (or dying). There is sometimes the AUX battery as well, check them and replace main AGM battery if need be. You could try to charge the one you have and then once it cranks up, put a voltmeter on the battery and see if you're 13 or 14V... indicating alternator is charging. If it's 12V and decaying, then alternator is shot (which usually should be charging your battery).
Old Feb 19, 2016 | 06:55 AM
robl45's Avatar
2011 AMG E63
Mine did the exact same thing, charge the battery, jump start it and you will probably be fine, my battery appears fine.
Old Feb 19, 2016 | 12:37 PM
Pufftrees's Avatar
e63 NA
Great guys, thanks for the help.
I ended up jumping the battery and it worked fine...
Not sure if I somehow hit my ignition button again by accident (therefore leaving the lights on or something)... or perhaps it's my giant subwoofer. I can't get around to replace battery today anyways so hopefully it has enough charge now.
Old Feb 20, 2016 | 09:03 AM
robl45's Avatar
2011 AMG E63
I don't know if the giant subwoofer comment was a joke or not, but that could definately kill the battery. I'm thinking of getting the Ctek 4.3 charger so I can throw it on there once in awhile to keep the battery charged up.
Old Feb 20, 2016 | 01:46 PM
It's not the giant subwoofer that drains the battery, it's the giant amplifier that kills the battery. Lol.
