M157 Bucking/Idle Issues...Help Needed
M157 Bucking/Idle/Plug Tune-Related Issues...Help Needed
Hi all,
Just wanted to get your feedback on a few issues I've been having with the car. Also posting this in the E forum since you guys are so much more after than our CLS area.
Current performance mods are as follows:
Eurocharged Tune Stage 2 (24lbs. boost)
Weistec Bosch Silver Plugs
K&N Filters
Straight Pipes
93 octane
I've been getting pretty significant "bucking" that I've seen described here on initial throttle-tip in when the motor is below operating temp. Especially on colder or low humidity days. Has anyone figured out a resolution to this? I've also tried fuel system cleaner and that helped but only for a week or so before it came back.
I've also seen my engine rev ever so slightly on it's own here and there. Just a little jump off idle. It happens very rarely and thus very difficult to capture on video. Always while in drive, usually with my foot on the brake stopped at a light or something.
Also, does anyone have any throttle tip-in lag when the car is up to operating temp? My car is Jeckle and Hyde when the engine is cold versus warm. Super sensitive throttle when cold and laggy when warm. I do TCU resets pretty often because most of my driving is city driving on cold motor which is obviously terrible for responsive, quick shifts.
Last question, does anyone notice that their car seems to choke for air upon WOT? During highway WOT, I feel like the car is struggling to redline almost like their is resistance, perhaps not getting enough air or something along those lines?
I'm sending my ECU back to Eurocharged to have them look at the A/F ratios any other data logged in the next 2 weeks. I'm hoping they can help diagnose these issues.
Appreciate anyone's feedback, advice or questions.
Thanks!
K&N Filters
Straight Pipes
93 octane
Thanks!
I brought my 2012 bi turbo into the dealer for this exact problem (REALLY bad when the engine temp is cold).
They were able to reproduce it and said the ECU and TRANS had an updated firmware/software that they installed/flashed and that dramatically improved the bucking. I can still get it to happen, but it is so much better now.
The rest of your questions I don't know, don't happen to me.
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Hi all,
Oh man, I hope that's not the problem. Just had the Weistec plugs installed 5k miles ago! I was able to get a tech to do it off the clock at the dealership but they shut that down immediately after they did my work.
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
There's a bulletin on this... Get the tcu upgrade but make them keep the car overnight to replicate the issue and plan on meeting them in morning to demonstrate issue
Thanks Peter. Any idea on where I could locate the bulletin to show my SA?
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
Aside from the software upgrades that your dealer should be doing. My guess is either the spark plugs that needs replacing or depending on where you live. The gas you put into you AMG will also affect the way your car drives. I've always use Mobile or Shell 91. Not sure what kind of gas you use, but you might give them a try if your not using it already.
Good luck.
Good luck.
Good luck.
Good luck.
Thanks for the response. I was just re-reading your spark plug thread. In regards to the plugs, I'm not getting any CEL's. Does that mean I can still have bad plugs? Can the dealer check from this?
I use 93 octane Shell from the same station every week. Perhaps I can change brands and see what that does.
Thanks,
Hey. I have been fortune that that I have not seen a misfire from my E63 even with the extensive of my upgrades, but from what I have learned from this forum. Misfires from the spark plugs will produce Cels poppy up.
If your not getting cel warnings, I would ask your dealer do a software upgrade check and at the same time give Mobile 93 gas a try.
On a side note. If you find that you need to replace your spark plugs, remember to gap it at 0.022 as a value member advised.
Good luck man.
Good luck man.
Hey David,
Thanks,
Thanks,
If your not getting cel warnings, I would ask your dealer do a software upgrade check and at the same time give Mobile 91 gas a try.
Good luck man.
Good luck man.
Hey David,
Thanks,
Thanks,
if you have a scan tool, plug it in and look for misfires as the car should be storing the fault codes... on misfires, it will only show a CEL when it logs enough misfires in certain amount of time = the car ecu sees it as an ongoing problem and not a random issue like bad tank of gas
CEL can take a while to popup.... i was getting the idle rpm stumbles you were mentioning, for about 2-3 weeks before i got CEL.... it depends on how often you drive.
Service Campaign 2014050002 JUN14 – 2014 212 & 218 transmission control module (TCM) does not correspond to current product configuration low transmission oil temperatures combined with certain driving patterns may affect engine running characteristics, dealer will update TCM software. Approximately 640 vehicles affected.
When you bring your car to your dealer for software upgrades, tell your SA of what you are experiencing and ask them to do a cel scan for any defaults stored and the dealer should be able to find the problem your experiencing.
Your the man Peter.
https://jet.com/product/detail/ebc00...t4gaAjuY8P8HAQ
buy a scanner as you will use it many many times on a benz
unless you prefer going to dealer each time (not very convenient) and pay 150 each time
If the car in question is still under factory warranty and the fault is not related to any tune. I doubt dealers will charge a fee. If it's out of factory warranty or the issues is related to tunes will be another story.
i used this one...will pay for itself on the first use as cost is cheaper than one dealer diagnostic scan
I second the iCarsoft 980. Great tool for diagnosis, gives you the scanning and code clearing capabilities of an Star Diagnostic tool, just without the ability to modify anything in the modules. Great for clearing module fault codes that a generic OBD 2 scanner cannot.
also original post states its eurocharged stage 2 tune, so its tuned and has straight pipes... that one will be kinda hard for dealer to miss
regardless, if you have a tuned car you need a scanner.... its a no-brainer.... ive used mine well over a hundred times between my e55 to c63 to e63
its 2012 so is either out of factory warranty or will be soon
Thanks for advice on the scanner. I'll pick one up!
