E63S weistec , drag strip , trans died .
Old Apr 21, 2016 | 03:31 PM
PeterUbers's Avatar
Hell yes if I'm paying for a trans repair on a new amg I want a new trans not a reman'd one
Old Apr 21, 2016 | 03:32 PM
dav461's Avatar
GTR
You are not paying. It's inder warranty. It's not their money. HQ pays it. So they can be dodgy, trust me
Old Apr 21, 2016 | 03:41 PM
Fairbird's Avatar
C300
Originally Posted by dav461
You said they will get you NEW transmission , not fix current one.
I am pretty sure this going to happen
I fixing the current one .
Old Apr 21, 2016 | 05:23 PM
PeterUbers's Avatar
The op stated he is paying for this; it is his money; though I can believe it's cheaper to reman a tranny than replace one
Old Apr 21, 2016 | 05:46 PM
Fairbird's Avatar
C300
Originally Posted by gaspam
even a weistec built transmission probably wouldnt of prevented that then as the weistec build uses stock output shaft.... must of been some manufacturing defect in your output shaft for it to break on just a tune
Note: Weistec Engineering thoroughly inspects the entire transmission upon arrival. During the build process it is important to understand that wear and tear items (such as clutches, seals, and gaskets) are replaced. Parts such as input shafts, output shafts, casing, etc. are not replaced in the build process.
edit: i do see weistec cryogenically hardens the shafts and gears so that should give it about 30% more strength..... but still think original shaft on this car must of had some freak defect to break on tune only car when many others have pushed stock 722.9 tranny well past m157 tune only power levels with no issues
Agree to the edit , most likely it was defective from amg
Old Apr 21, 2016 | 08:23 PM
dav461's Avatar
GTR
HE IS PAYING TO do HIMSELF. ( strengthen it )
They did analysis and diagnostic, report which will be send to HQ after shows that they got full right to order new trans from Germany. This the way it works.
p.s. brabus handles 1300+ Nm on completely stock transmission.
Old Apr 21, 2016 | 09:00 PM
  #32
Fairbird's Avatar
C300
Let's clear this up : I'm fixing rebuilding my old trans , dealer was ok with replace my trans under warranty , I said no , I will launch the car all day long I'll snap the shaft again . So I could wait till new oem trans comes from Germany , 2 weeks or so ? And than take the car a part again to do the w3 turbo swap . My original plan is to get w4 when availble , so I'll sleep better with stronger trans . I'm paying for everything and for what ever is bad in my trans
Old Apr 21, 2016 | 09:04 PM
  #33
efiftyfizzle's Avatar
W212 E63 AMG S Model
I don't think launching the car damages the tranny. Does it wear it...? Yes but I don't think your car makes enough power / torque to just go through transmissions like that.
Old Apr 21, 2016 | 09:08 PM
  #34
Fairbird's Avatar
C300
it will make enough , that's the problem , not tomorrow , not in 2 month , next year , but than I would not have to go back to the transmission deal
Old Apr 22, 2016 | 02:56 AM
  #35
PeterUbers's Avatar
Ok bro
