Girodisc Rotors,
https://www.amsperformance.com/cart/girodisc-mercedes-e63-amg-2-piece-330mm-rear-brake-rotors-a2-022.html
https://www.amsperformance.com/cart/girodisc-10-14-mercedes-e63-amg-2-piece-360mm-front-brake-rotors-a1-022.html
https://mbworld.org/forums/w212-amg/...ad-review.html
RacingBrake two piece rotors are of patented center mount design, not only it runs cooler (admits cool air both from inboard and outboard), but the hardware, after rotor is assembled is set below the rotor surface, so you will NEVER have the same issue like Girodisc (or any other two piece rotors like OE or other aftermarket two piece rotors with conventional surface mount design.)
A superior brake by design.
Old thread but you are the only person I ahve seen that has had both giro and RB... which do you like better and why?
-Nigel
