Optimum tire size for 20x9 and 20x10
Less than 2 months ago I bought a set of Vorsteiner V-FF103's from a member here that came off his W212 to put on my BMW I8 (they work out pretty well actually) Now 2 months later I'm thinking of buying an E63 and these wheels would obviously work out perfectly. Only problem is that on the i8 I had to put on 245/40-20 and 285/35-20. I'm not 100% sure if the sidewall size would work with the E63, and if it doesn't what size should I get, maybe 255/35-20 and 285/30-20? Thank you in advance.
spoke to them at great length, many times before ordering (pictured here ... not to imply this is my car, my vff-102 on fedexing their way to me now as are Michelins)
https: //www.instagram.com/p/045GhUMNBo/ ... (space added)
spoke to them at great length, many times before ordering (pictured here)
https://www.instagram.com/p/045GhUMNBo/
If you drop to 235/35 in front, you drop to 90Y I think it is. Thats even worse. It starts to get REALY sketch then.
265/30-20 have a 94Y ... just for comparison.
A 4250# car, with 55% (roughly) of its weight on the front axle has in total 2340# on the front axle (1170# per side ... Assuming equal distribution).
A 92 can hold 1389# meaning you have left yourself a mere 219# of weight shifting (PHYSICS) when you hard corner, brake hard, avoid an accident, deer, lean on your car at a meet and greet (not to imply the tire will suddenly rupture), etc at MAX PSI. The rule of thumb lies. The laws of Physics don't.
The factory rating is a 96 which carries 1596# per corner up front (rear is different) leaving 417# at max inflation for Physics.
This is what leads to lawsuits in accidents.
44psi on a 92 has a carrying capacity of 1198# (20# for physics ... I sure hope you air gauge is dead on accurate and you never lose air !!!)
41psi on a 96 has a carrying capacity of 1283# (113# for physics)
You have reduced carrying capacity by 100# (roughly) per corner using "the rule of thumb". Physics will kick your *** when given the chance in that configuration!
*tire ratings based on w212 e63
Now, I'm going to 20's and running 265/295 as they are the recommended size. AFAIK that's our best load rating options in 20s.
