E63 AWD vs RWD: Does it Make a Difference?
Old Jul 8, 2016 | 12:32 PM
MBWorld Editor's Avatar
IB Staff
Haven't we all wondered what the real-world difference is between the older RWD E63 AMG and the newer AWD model of the same name?
Read the rest on the MBWorld homepage. >>
Old Jul 8, 2016 | 01:42 PM
PeterUbers's Avatar
Editor in case you missed yet another discussion on this a week ago
https://mbworld.org/forums/w212-amg/...uned-14-a.html
Always a great discussion
Old Jul 8, 2016 | 06:14 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
The AWD one looks like a non-S due to the caliper color. Maybe the S will bridge the gap to the RWD one with PP.
Old Jul 9, 2016 | 12:07 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
its the non-s but thats the point... to run equal HP on same cars and see
Old Jul 10, 2016 | 02:41 PM
otakki's Avatar
I thought the performance package has more hp and tq than the facelifted non-S.
Old Jul 10, 2016 | 02:49 PM
gaspam's Avatar
i think both the p30 pre-facelift and the post face lift non-s both are rated at 550 to the crank
2012-2013 non p30 = 518
2012-2013 P30 = 550
2014+ non-s = 550
2014+ S-model = 577
Old Jul 10, 2016 | 04:31 PM
PeterUbers's Avatar
2012-2013 P30 = 550
2014+ non-s = 550
2014+ S-model = 640
Old Jul 11, 2016 | 07:06 AM
kponti's Avatar
E63
2012-2013 P30 = 550
2014+ non-s = 550
2014+ S-model = 640
There is certainly some truth to that with these S models dynoing in the mid to low 500s stock.
The P30s typically dyno b/n 480-490 stock
I haven't seen or heard much of the AWD non-S models dyno numbers
Old Jul 11, 2016 | 10:17 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
I've read similiar theories but never saw it put to the test. Great to see the RWD can make up the difference as the race goes on.
Old Jul 11, 2016 | 12:17 PM
gaspam's Avatar
2012-2013 P30 = 550
2014+ non-s = 550
2014+ S-model = 640
before and after S-model (mine) ..stock was 513 whp = about 590 CHP if drivetrain loss = 15%... far cry from 640 chp... maybe on a uncorrected dynojet a sea level in 30F weather could see 640 chp ....
E63 AWD vs RWD: Does it Make a Difference?-e63s-20dyno_zpseoqkphac.jpg
Old Jul 11, 2016 | 12:43 PM
PeterUbers's Avatar
Originally Posted by gaspam
before and after S-model (mine) 513 whp = about 590 CHP if drivetrain loss = 15%... far cry from 640 chp... maybe on a uncorrected dynojet a sea level in 30F weather could see 640 chp ....
I thought I had seen someone dyno a 540whp on a Mustang dyno, stock
Yup-- dynojet on a cold Chicago day (good call) and we are at like 700ft I think; not sure if its corrected or not; maybe AMS can chime in
https://mbworld.org/forums/w212-amg/...3-s-model.html
Old Jul 11, 2016 | 12:48 PM
kponti's Avatar
E63
^^^Yup and found a couple others dynoing around 520-540 stock sae corrected
Old Jul 11, 2016 | 07:35 PM
proxygeek's Avatar
2016 Mercedes Benz E63 S AMG
The 2014+ E63 S AMG 4 Matic cars I have seen on the Internet all dyno in the 520-540 AWHP range. That's approximately between 640 and 675 CHP depending on whether you use a 15% or 20% drivetrain loss. I have heard it's much closer to a 15% loss than a 20% loss. The Motor Trend guys got 676 CHP near where I live in CA. All of the tuners know the M157 E63s are way underrated for HP. I think it's extra power for the AWD drive train and to keep insurance rates lower.
Old Jul 11, 2016 | 07:56 PM
kponti's Avatar
E63
Since 2012 (or earlier in some models) the M157 have had different outputs all from mostly software manipulations. Seems to me they just bumped the power up (P30 vs stock non S awd version) viola rwd and awd have similar performance. Of course in an all put drag, the AWD being more underrated will come out on top.
Remember MB isn't known for high performance AWD cars, theirs is more durability and off road. If anything, I think the MB AWD may not be as efficient as the manufacturers known for such, but a little software manipulation later, MB cars perform similarly or better as compared to their own RWD versions
Old Jul 12, 2016 | 11:55 AM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Trying to derive the crank hp from chassis dynos is an exercise in futility. Is 15% the "right" drivetrain loss on that particular dyno? Who knows. If you use 17% loss, you are looking at 618hp at the crank. if you use 20% loss, you are looking at 641hp at the crank.
For me it is all meaningless anyway (and I have dynoed my cars dozens of times). I now just use my vbox and the same private road and try to test in similar conditions to track my cars' relative performance increases.
Old Jul 12, 2016 | 12:59 PM
gaspam's Avatar
I agree, I really never use CHP as what matters is what you're putting to the ground and even that a lot of times doesn't tell you how fast your car is gonna be on the street as there's a lot of Dyno queens that do great on the Dyno but not so hot on the street
Old Jul 13, 2016 | 12:52 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Is there a weight difference between the rwd vs. awd?
Old Jul 13, 2016 | 01:22 PM
gaspam's Avatar
ive seen varying numbers but most put the AWD at 130-150 lbs heavier... motor trend tested both, when they first came out and they had awd at 164 lbs heavier
http://www.motortrend.com/news/2012-...mg-first-test/
http://www.motortrend.com/news/2014-...ck-comparison/
Old Jul 13, 2016 | 02:53 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Makes sense, RWD less drive train loss and on a roll when traction isn't an issue should pull ahead. AWD for digs, RWD for rolls. Anyone seen what a tuned M157 RWD car does against a tuned AWD M157? RWD should still be a bit faster in the long run 1/2 mile or mile races IMO.
Old Jul 13, 2016 | 03:21 PM
gaspam's Avatar
only one I've seen rwd tuned vs awd tuned is this one, but not exaclty apples to apples as the awd weistec car has its w3 turbo kit which should put it around 650whp (though i have read of a few people on the east coast not getting the advertised results and disappointment with that kit)... vs renntech rwd car has 624whp (e.french's car and seems to be a bit of an outlier as he is the only e63 i've seen trap 130+ on stock turbos)
Old Jul 14, 2016 | 11:39 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
AWD is for people that live on a ice hill, so booring drive a 4 wheel drive car with alot HP , would never buy one, no fun to play . if y have a SUV and need take a boat out of the water, or difficult vinter condition is only reason to have one.
Old Jul 14, 2016 | 06:39 PM
otakki's Avatar
I'm not a fan of MB's fixed tq splitting. I would prefer Nissan's ATTESA ETS-Pro or Ferrari's 4RM, both of which will get the car to be RWD as much as possible while having 4WD for certain challenging situations.
