Help: No radio/sound when bluetooth is connected
Old Oct 14, 2016 | 05:25 PM
arcticfox's Avatar
2020 E63S
Hi all,
I am new to the car, so maybe I am missing something trivial, so bear with me. I searched, but didn't find anything related to my issue.
I leave my iphone bluetooth on all the time....
When I enter the car and start it, the phone bluetooth connects to the car, is recognized, works, etc.
The issue is, I have no radio sound (FM, Sat, etc.), just very faint static. As soon as I turn off the bluetooth on my phone, the radio works perfectly. If I then turn bluetooth back on, everything still works.
Has anybody had a similar issue? It is a pain in the a$$ to have to disable BT and re-enable it each time I enter the car (after command boots).
Any thoughts? Please tell me this is some simply setting I can change and not something I will have to live with. Having to do this every day will start to really **** me off over time. lol
Thanks in advance for your input, Tim
Old Oct 14, 2016 | 07:29 PM
PeterUbers's Avatar
Originally Posted by arcticfox
Hi all,
what year car?
try deleting Benz from iPhone and hard reboot of iPhone and delete iPhone from Benz and re add
Old Oct 14, 2016 | 11:04 PM
2012 CCB E63's Avatar
2012 E63
the MY would help. I am thinking its an earlier 2010ish year with an aftermarket bluetooth that is waiting for the phone to ring. (just shooting in the dark).
What is the bluetooth profile you are connecting to? (what name displays)
Old Oct 15, 2016 | 04:39 PM
arcticfox's Avatar
2020 E63S
Car is a 2014 E63S
When connected it says "connected to Tim's iPhone"
Old Oct 15, 2016 | 09:12 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
I had the same issue on my 14
The phone is connected for cell service.
I think you are looking to stream music? If so you have to go to media and select BT and your phone will start to stream...
Old Oct 16, 2016 | 10:11 PM
arcticfox's Avatar
2020 E63S
Today it worked fine.
To clarify: If my phone's bluetooth is on, it will connect to the car after I start it. The radio (am/fm) or Sat radio will not work, even though I specifically select them in command. As soon as I turn off the bluetooth on m phone, the radio works. If I then turn bluetooth back on from my phone, it connects and everything works normally.
Today it worked normally...radio worked and I did not have to turn off/on my bluetooth. Maybe it was just a freak occurrence. By the reaction I got here, it seems like nobody has encountered this before. Hopefully it was a one time glitch.
Old Oct 18, 2016 | 12:21 PM
Johnny Rad's Avatar
W212 E550 4M P2
I just got a new 5se iphone w/iOS 10.0.2 and had some odd, similar issues that seemingly went away on their own. (Fingers crossed!)
I set up my new iphone from a backup of my old iphone, so it probably inherited a bunch of settings. Per frequent recommendations on this forum, I deleted my car from the new phone and vice versa so I could start fresh.
My first couple of BT connections as a phone (not a media player) to the car were odd. The phone appeared to connect fine, but would disconnect on its own and reconnect when I made a BT call. Rebooting the iphone didn't work, but unpairing the phone and car (again) and reconnecting them from scratch did.
A day or two later, I encountered a similar situation to the one you described above. BT off, the music audio worked. BT back on and the music went silent. My iphone seemingly connected fine, but I lost all music audio regardless of what Command buttons I pushed. In the TEL Command screen, it looked like my phone was somehow connected and/or had dialed itself on its own. I think my iphone freaked out for some reason (as they're apt to do from time to time!). It was a one-time occurrence that hasn't repeated itself. I think that it was resolved by either letting the car sit overnight in the garage and/or restarting the car on the drive home.
It's been a week now and all seems good to go now.
Old Oct 18, 2016 | 02:07 PM
omega_jeff's Avatar
'15 Audi RS7
My '10 E63 glitched the way you described. Only once in the year I've had it, so......
