strut bearing groaning
2014 CLS 63 S AMG / 2004 E55 AMG
I had virtually the same experience with my 218 63S. They had the car off and on for a total of 3 weeks and replaced both struts and both top bearings before solving it. It was very annoying. The solution was silly; greased the top of the struts and the new strut bearings...
I later pulled the struts to install lowering springs and noticed that the dust cover (rubber) fits into a top strut cover (rubber) fairly tightly. That's one spot where they applied the grease. I'm not sure how much (if any) that this contributes to the noise at all, but I added extra grease to make sure.
I found the below info on another post in this same thread, but was not sure if this was the same fix as what you had with your issue. My groaning and clicking noise is left front and very noticeable when driving slow and the car is cold in mornings (Chicago i'm located, very cold now) and when turning to the left.... thx John
"38239 Right front strut upper pivot bearing and mount test drive vehicle in parking lot, find when wheel is turned back and forth there is noise from right front, use the chassis ears and find noise coming from top of strut, follow LI32.25-P-051645, apply grease between upper mount and dust boot, find noise still present, remove right front strut, disassemble the strut and inspect, find the upper pivot bearing is not smooth and leaking grease, install new upper mount and pivot bearing, reassemble strut, install strut in vehicle with new bolts and nuts, find noise no longer present"
