Weistec water-methanol and blow-off valve kit
#76
thank you!
#77
I think this will be a fun project while I also add meth to the car.
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/1600x1200/6c74e1f9_b07a_4c17_9863_03929c9682fa_26620_000018f7af775137_6853ded5b9c6f9d470b9901760613c77cd50832e.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/799x450/img_4727_542e1f517ed8d47173ff6121c76170fecbb3fa27.jpg)
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/799x455/img_4728_e6cbca35fc28907355508fea169740a2bffc5572.jpg)
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/798x439/img_4729_dfdd6930113f74d7e7c6549715e67c71cee1d41f.jpg)
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/799x468/img_4730_97fd6512ba3ba4b098fd6b1fd1ff2105b5a54886.jpg)
#79
I installed my custom meth kit and I logged my IAT. it seems like my Inatke air temp sensor doesn't see the meth all , very small drop in Inatke air temp by the time the car is on the end 5th gear 155 mph my intake temps are 170 f..... nozzles are placed in the charge pipes right before intercooler.
#80
In the middle right where the 2 charge pipes are going into the intercooler there is a plug that's right in the middle . To remove turn and pull. Then just tap into it and reinstall. Atleast that's what I used and it's perfect
#81
#82
Read my post, in pre turbo injection. Basically nip the issue right in the butt. Remember it's the turbo that's causing this heat do to the air being compressed, throw some methanol and it sucks the heat out while. Wing compressed and makes the turbo behave more efficient. There are pros and cons so please do your research
I for example also installed a killerchiller, which cols the charge air through the AC, but also noticed through obd IAT sensor I was not able to notice temp changes any lower really at all
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#84
I have my car at the tuner right now, will pick it up today, we also chose charge pipes as position of the noozles. The Meth kit seller Alkycontrol who has been doing this for 20 years told me pre turbo is only if you cannot place noozles elsewhere, he would not recommend it...
I for example also installed a killerchiller, which cols the charge air through the AC, but also noticed through obd IAT sensor I was not able to notice temp changes any lower really at all![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#85
Cifdig, is right 100% installing the nozzles on charge pipes is Before the intercooler! is a bad idea it can even hurt the perfomance as the intercooler will lose the efficient to cool. I believe my car lost perfomance. best thing to do is after the intercooler on the manifold in our case so the intake air temp sensor can get hit and reduce the temp , or easy way pre turbo.
#86
#87
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/1797x1092/meth_nozzle_placement_8c25ef033a1b1fb0e2be1ec2ac2bcbb505113239.jpg)
This is where I would ideally place the nozzles for meth. IAT will still pickup the temp drop, and nearly direct port to the left and right IM runners. the only downside is that is right under the ECU! might work with some spacers and 90 degree nozzles. I suppose you could go further back in the intake manifold near the brake booster port, but I have my BOV plumbed in there.
Thats not the intake air temp sensor, thats the MAP sensor. Intake temp sensor sit close to the throttle body.
Siegmann (01-29-2022)
#88
I agree pre I/C isn’t optimal but I wouldn’t go as far as to say it’s a bad idea. Post I/C is optimal but it’s also a significantly more difficult job. While my results would no doubt be better with the nozzles that location, I am seeing better IATs with the nozzles in the charge pipes. I don’t know if I’m actually gaining any hp but lower IATs are always a good thing.
#89
What size nozzle do you plan on spraying. Also what rpm /boost level are you going to activate it? Activation time is crucial, you want it to activate while the turbo is about to hit peak that way when they slow down it's not dramatic . The turbo will spin slightly slower not much then pick up and hold the power longer. Look at my graph so you can see when it starts . Every car will behave differently so just play with it until your car feels right. Also remember don't go by butt dyno. To me it felt the same , which I was ok with I simply wanted a cooler charge but I actually gained a bit without tuning for it.
#90
#91
I have the same car and haven’t done the split cooling either. I started with the AEM medium jets and couldn’t see any differences in IATs. Went to the smaller jets and saw a 20*f drop on 60-130 pulls.
#92
I have two big nozzles. They were set to start at 8 PSI I turned it down to 2 PSI. Gradually turned the peak flow from 25 to 15 meaning the flow is 100% at 15 psi. This resulted in tremendous Improvement in wide open throttle iat. Also improved my quarter mile
#93
Congrats on achieving your 60hp back and getting great results on your pre turbo injection. Glad you gave it a try . Some are afraid due to the lack of info they have on it. Maybe this will start a path that will lead us to better IAT and More power
#94
on cars deff is better pre turbo, charge pipe did not work on my car I lost 60 whp!
#96
From reading through this thread, it seems best location for effect is post IC and pre IAT sensor. However this is a harder job to do. Seems also effective and much easier install is pre turbo location. Regarding size nozzle I think this will depend on what mix you going to run.. If you going more water than meth mix then you need a smaller nozzle versus if you going 100% meth mix then you can go bigger nozzle.
