CTEK Charger left unattended
Old 12-13-2016, 06:32 AM
robl45's Avatar
2011 AMG E63
I just got a CTEK charger MUS 4.3 as my car has turned into a weekend vehicle while I'm stuck commuting in a Prius during the week. I just wanted to see if anyone leaves these plugged in 24/7 without issues. I believe you are supposed to be able to do this but it still makes me nervous.
Old 12-13-2016, 09:33 AM
PeterUbers's Avatar
Received 2,108 Likes on 1,472 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I leave it plugged in for four months every year with the ctek... four months in a row totally unattended
Old 12-13-2016, 09:43 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Same here. I use it for my C32 since I drive it now less and less.
Old 12-13-2016, 09:56 AM
AG6
AG6's Avatar
13 GL550
I posted in another thread, but what is the best way to connect this charger with hood, doors and trunk closed?
Old 12-13-2016, 04:18 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
You will probably need to set up a connection of some sort and route it to a convenient location in the car. I don't think anyone has done it any other ways other than popping up the hood.
Old 12-13-2016, 08:02 PM
PeterUbers's Avatar
Yeah I just pop the hood...
youll need to setup waterproof disconnects for postive and negative terminals and be able to stow them somewhere under the front bumper
why not not just pop the trunk?
Old 12-14-2016, 12:09 PM
omega_jeff's Avatar
'15 Audi RS7
Connect this to the battery, and leave the business-end hanging in a spot that's easy to access and suites your needs.
(and as a side note, I've been using a Battery Tender for the last 15+ years on my motorcycle and leave it on for a few months at a time..no problems. I've also used it on all my vehicles at different times, for weeks at a time...no problems.)
Old 12-14-2016, 05:41 PM
AG6
AG6's Avatar
13 GL550
Does it connect to hood or trunk battery?
I have a tight fitting cover on the car over winter which doesn't leave room to have the trunk or hood open.
Old 12-14-2016, 09:22 PM
PeterUbers's Avatar
it connects to the engine battery under the hood
well connect it and then put your cover over the car
the ctek gives you tha status of The battery
unplug it from the wall if you want to give it a break but I always leave it plugged in ... it's a smart trickle charger
Old 12-16-2016, 03:53 PM
E63 Tony's Avatar
e63s
what setting you leave it on? i have a c tek 3300.
Old 12-16-2016, 04:07 PM
PeterUbers's Avatar
snowflake (its 35F in my garage), car (to the left) if it's warmer
Old 12-19-2016, 01:12 PM
Nacelle's Avatar
'19 AMG C43 Wagon
As do I, I had a quick connect hooked in to the car at the Dealership, just plug it in and I'm gone... works great.
Old 12-19-2016, 01:55 PM
otakki's Avatar
What does the set-up look like and where on the car does the plug come out?
Old 12-19-2016, 04:03 PM
Nacelle's Avatar
'19 AMG C43 Wagon
(see pic in post 7) and plug is attached by clips to a convenient the spot in the engine bay where can be attached to cord leading to wall outlet.
Old 12-20-2016, 01:28 PM
otakki's Avatar
Do you still need to open the hood to access the plug?
Old 12-20-2016, 02:03 PM
Nacelle's Avatar
'19 AMG C43 Wagon
Yes....
Old 12-20-2016, 03:12 PM
PeterUbers's Avatar
I don't see how you can get around not opening the hood, the quick connect in a very convenient location would invariably be exposed to some moisture at some point, be at at the windshield Cowl, or the undercarriage. The safest thing to do is open the hood to connect
Old 12-21-2016, 06:17 PM
otakki's Avatar
Some cars now have the receptacle built on the outside, ie Ferrari locates it facing down along that ledge above and to the side of the rear license plate location. Still, it will get lots of moisture, dirt, debris, etc due to the airflow there of any car.
Old 12-21-2016, 06:18 PM
PeterUbers's Avatar
the rubber cover to the receptacle seems like it would last a while ... but I would worry it would short the entire system if it fell off
Old 12-22-2016, 03:48 PM
otakki's Avatar
Good point. Or one of those haters intentionally doing so to the car...scary. It's a double edge sword.
Old 12-28-2016, 01:20 AM
omega_jeff's Avatar
'15 Audi RS7
I don't know about the Ctek charger, but for the Battery Tender charger I use, if the rubber cover came off the quick disconnect, the only exposed metal is for the ground lead. There's no way it would short out. And in the unlikely event something evil does happen, the hot line is fused and, in theory, would blow the fuse if anything bad happened.
I was inspired by this topic, so I took the plunge and purchased/installed a quick disconnect to my battery. (I've had one on my streetbike forever...I don't know why I've never hooked one up to my car or truck!). After hooking it up to the batter, I ran it out of the back-right side of the hood near the right windshield wiper. It works fabulously! When it's not in use, it tucks under the plastic wind deflector on the side of the window, out of harms way. When I need it, I just whip it out and plug it in!
Old 12-28-2016, 11:10 AM
PeterUbers's Avatar
Good info ... nice setup ...:
Old 12-28-2016, 01:17 PM
otakki's Avatar
Great, helpful pictorial guide there, omega_jeff! A picture is definitely worth a thousand words! So no problem with rain and with snow getting piled up near the external plug location, right?
Old 12-29-2016, 12:32 AM
omega_jeff's Avatar
'15 Audi RS7
Rain: I'm not worried about the rain water as (a) the quick-disconnect is capped up, (b) it won't be laying in standing water and (c) if a worst-case scenario does happen with water and a short circuit, the fuse will/should blow.
Snow: I'm not worried about snow because (a) I live in California. But I can see how this setup wouldn't be an ideal solution if your car is covered in snow. Come to think of it, methinks you'd have other things to worry about if your car is covered in so much snow that you can't get to the connector, or open your hood to get to the battery terminals!
Old 02-16-2017, 02:32 AM
wongman1's Avatar
2009 ML350
So i have the same exact model -CTEK MUS 4.3 Battery Charger.
Will the cigarette adapter work for 09 ML350?
So i used this model ctek on my 03 bmw 530i. I just clamped it onto the battery in the trunk for a few days. When i turned on the car, the needles in all the gauges on the dash went crazy, back and forth really fast for a few minutes then slammed down past the 0 mark. I was bummed for days as I thought i needed a new cluster. A simple disconnect of the battery for a few minutes fixed the problem. I may have went into maintenance mode on the ctek when i first put it on, not sure. Regardless it scared the bejesus outa me. I was reluctant to use it again, but I got the cigarette lighter adapter, had it on for weeks before i checked again, and glad to report that it worked great.
Bimmer just sold an hour ago and the ML went into the garage for the first time tonite. But afraid to hook it up to the CTEK until I hear good reports.
Quick Reply: CTEK Charger left unattended
