No Start Help - 2010 E63
Old Dec 15, 2016 | 12:20 PM
6speeddave's Avatar
MB
Question No Start Help - 2010 E63
Guys,
Car is a 2010 and has 68k. Main battery is 5 months old. OEM Auxiliary Battery replaced two weeks ago.
Went to go run errands this morning and the car wouldn't start. In fact the horn sounded for a bit and then denied any sort of start procedure. All lighting and interior electronics work fine. I even hear a start click, or relay click that you would normally hear just before a startup, but in this case, nothing happens after that click.
I checked the battery, its fine at 100% power via my battery charger. I even unplugged the battery and still the same problem.
I wont be able to scan the car, or try and jump it, until this evening when my roommate brings over his generic OBDII scanner and truck. I am currently awaiting calls back from my MB service writer and my independent technician facility.
Thoughts? Any things to check? I checked the "Starter" fuses in the engine bay, and they all seemed to be fine. I am a little weary that this may be related to a bad ignition module of some sort, something I guess the W204 cars have issues with from my quick research online.
Any input or help on this would be greatly appreciated. I head overseas on Tuesday and would like to get this resolved before then, without having to tow the car to the dealer if at all possible.
Old Dec 15, 2016 | 01:04 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
check CPS (cam position sensor)
Old Dec 15, 2016 | 01:24 PM
6speeddave's Avatar
MB
Crank or camshaft position sensor?
I need to look up a part number.
Old Dec 15, 2016 | 01:42 PM
omega_jeff's Avatar
'15 Audi RS7
What ever happened to the good ol' diagnosis of "starter motor"??
http://www.oemautopartsandaccessorie...4c41c34b55dca/
Old Dec 15, 2016 | 02:09 PM
gaspam's Avatar
camshaft
Old Dec 15, 2016 | 06:19 PM
6speeddave's Avatar
MB
Hmmmm, interesting about the camshaft position sensor.
With that said, Im towing the car to my Indy tomorrow.
Anyone know how to release the shifter so I can put the car into reverse?
Here is my findings on the CPS, and CAS.
Old Dec 15, 2016 | 07:14 PM
gaspam's Avatar
either could cause car to not start... starter would of most likely had symptoms in advance that it was getting ready to die, so that is why i think it is probably a sensor
Old Dec 15, 2016 | 07:30 PM
xheamgbenz's Avatar
W203 C32 AMG...W221 S63...SOLD...W212 E63 CURRENT
Get an oem part so u don't have to go do it again in couple of months
Old Dec 15, 2016 | 07:39 PM
6speeddave's Avatar
MB
I absolutely believe its a sensor however more anti-theft related than an engine sensor.
This is a common problem with the W204 cars, and all mercedes share the same system.
https://mbworld.org/forums/c-class-w...epair-diy.html
I'll know more tomorrow. Appreciate everyones input. Wont be ordering anything until diagnosis is done.
Old Dec 15, 2016 | 07:50 PM
omega_jeff's Avatar
'15 Audi RS7
Do we get a prize if we guessed right???
I absolutely believe its a sensor however more anti-theft related than an engine issue.
Old Dec 15, 2016 | 08:14 PM
6speeddave's Avatar
MB
Im also not getting that "click" from the steering column after putting the key in the ignition before turning from position 0.
Generic scanner is throwing the following codes.
P1614 - Electronic Control Unit Reset / Recovery Occured
P2158 - Vehicle Speed Sensor B
P0607 - Control Module Performance
Old Dec 15, 2016 | 08:35 PM
6speeddave's Avatar
MB
The starter? I think that anyone could have suggested that... but i'm not crossing it out either.
Old Dec 15, 2016 | 09:08 PM
6speeddave's Avatar
MB
Here is the current start sequence...
https://www.youtube.com/watch?v=Vvuk...ature=youtu.be
Old Dec 15, 2016 | 09:11 PM
6speeddave's Avatar
MB
Anyone know how to manually put these cars into neutral for towing purposes?
Old Dec 16, 2016 | 10:24 AM
Celicasaur's Avatar
W212 - E63 AMG
Ewwwwww, the crankshaft sensor is in the bellhousing?? What, of the transmission?? How is that even possible....?
OP, I saw the video and could hear the engine turning over which probably implies it's not the starter to a large degree. Normally a crankshaft sensor can be diagnosed by pulling out a coilpack & connecting it to a spark plug + then turning the ignition key. If you see/hear sparks at the plug tip, then the crank sensor is ok. I dunno, on a lot of cars that I know of, the crank sensor governs the spark. I'm guessing the camshaft sensors work in the same way if they have failed too.
That being said, I'm pretty sure a quick scan on Xentry will pull up which sensor has failed.
I wish i knew how to get the car into neutral. If you find out, please share with us.
Old Dec 16, 2016 | 10:51 AM
gaspam's Avatar
P0607 is ecu loosing power/connection... could be alternator or battery cables, or worst case scenario a failed ecu
P1614 is Control module voltage error
P2158 can also be caused by faulty pcm (or no/low voltage to it)
those 3 errors together seem to be pointing to voltage issue or ecu issue
as for putting into neutral this worked on my c63 M156 but not sure if same for your e63 M156
Old Dec 16, 2016 | 12:10 PM
6speeddave's Avatar
MB
I did the CPS on my E55 but am not 100% sure where it is on this car.
I dont believe you can put the car in neutral. Merc has an adapter that attaches to the rear hub, like a bearing, so that the car can be rolled around.
Old Dec 16, 2016 | 12:12 PM
6speeddave's Avatar
MB
Unfortunately the W212 isn't the same as your old W204.
Thanks for al the input on those codes. You are in Delray right? Do you have a good tech or service writer there I could call and discuss this with? I heard they are much better than Mercedes North Palm up by me, which I have used in the past and was not that happy with.
Old Dec 16, 2016 | 12:24 PM
6speeddave's Avatar
MB
I just pulled the green starter relay in the main fuse box, and the click heard right when trying to start went away. So, Im assuming that means the starter relay is working.
Old Dec 16, 2016 | 12:29 PM
gaspam's Avatar
ive used MB of coconut creek just because of my CPO and free... otherwise i would use an indy shop like JS benz in miami
as for neutral i still think the same unlocking mechanism is under the shifter assembly ... i will see if i can find the diagram (edit: i think there's a flap just under the "P" on the gear selector. You insert an object like the end of a ball point pen in it and push down and that allows the gear selector to be taken out of Park.
Old Dec 16, 2016 | 12:46 PM
Celicasaur's Avatar
W212 - E63 AMG
oooh....so does this mean I would need to call a Mercedes breakdown service to pick me up if i needed it? I never knew this....I thought it was something like the W204 procedure. My old W211 had a similar procedure.
Old Dec 16, 2016 | 12:49 PM
xheamgbenz's Avatar
Check the prefuse box
Old Dec 16, 2016 | 01:48 PM
6speeddave's Avatar
MB
I would imagine the car wouldn't receive any sort of power if the prefuse was blown, no?
Do I have to yank out the entire assembly to access the inside to check if its functional or blown?
Old Dec 16, 2016 | 04:52 PM
6speeddave's Avatar
MB
Lets say its worse case scenario....fried ECU. What am I up against? Any idea? Any ECU specialists to talk too?
Old Dec 16, 2016 | 06:44 PM
gaspam's Avatar
new ecu about 900- 1000
