Post your wheel/tire setup with pictures and information...
Old 01-06-2023, 02:37 AM
  #176
Ed99's Avatar
E63s AMG
Originally Posted by bdubs
I thought about going with the 305 in the back, but those have been consistently on backorder with availability dates as far out as December, which by then I'm back on my stock setup with all-season tires for winter. There appears to be plenty of clearance, though...
Yeah I think 305 would fit!! Are you still planning on putting 305's in the back?
Old 01-06-2023, 07:53 AM
  #177
mweber88's Avatar
2015 E63s S212
I went with the 305s... can't wait for spring to put them on!
Old 01-08-2023, 08:52 PM
  #178
berti_00's Avatar
2016 Cls63s AMG
Currently being built at vossen
20x9.5 deep et25 245 35
20x11 super deep et36 295 30
Current Wheels
vertini rf1.2 FRONT 20x9 ET20 255/30/20REAR 20x10.5 ET35 305/25/20
Decided to go bit smaller tire with more profile. The low 25 profile I hate.
BCP (01-23-2023)
Old 01-09-2023, 02:26 PM
  #179
mweber88's Avatar
2015 E63s S212
Current Wheels
They look great! However, I hope you won't hate the additional stretch of a 295/30 on an 11" rim compared to your 305/25 on a 10.5" rim.
Old 01-09-2023, 03:16 PM
  #180
berti_00's Avatar
2016 Cls63s AMG
You think 295 35 will be streched a lot??
Old 01-09-2023, 04:14 PM
  #181
mweber88's Avatar
2015 E63s S212
That depends on your definition of "a lot." If you look here:
https://www.tirerack.com/tires/Spec....omCompare1=yes
You will see all the specs on the Michelin PS4S. You are going from a tire with its minimum rim width (10.5") being your matched rim to a tire with its maximum rim width (11") being your rim width. You will have at least some stretch on it, but it may not bother you.
I'm not a fan of stretch at all, and just pitched a set of Michelin PS4S which were mildly stretched and suffered splitting around the inside of the tire both inside and out on the front tires. Tread remaining was still more than 50% remaining. Also, stretch puts your gorgeous rims at more risk for curb rash.
I know, it's really more of my opinion, but I'm just offering my opinion and some experience as food for thought. :/
Old 01-18-2023, 09:06 PM
  #182
Ed99's Avatar
E63s AMG
Current Wheels
Wow you fitted 20x10.5 ET35 305/25/20. Any pics to share with us. Would love to see it.
Old 01-19-2023, 01:15 PM
  #183
Rehabguy's Avatar
E63S
Ed99, CLS63 got wider hips than our 212s.
BCP (01-23-2023)
Old 01-19-2023, 07:59 PM
  #184
Ed99's Avatar
E63s AMG
Ah ok its for CLS63s. Yes definitely they have wider hips!!! I was like dam I have to see this if it was on a E63s haha!!!
Old 01-20-2023, 12:30 PM
  #185
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Don't know about those rears.....
Don't know about those rears. with those tires....bette test fit them. Remember later 21's had less room in the fender than earliier ones....And altho I'm not sure it's the right thing, I think you're probabyl going to be better off with a 285/30...depends on the year and the brand of tire...good luck....
Old 01-20-2023, 10:53 PM
  #186
Rehabguy's Avatar
E63S
Yeah, someone w/ a CLS63 just posted 325/25 on a 11 ET30... I am jelly.
Old 01-25-2023, 04:14 PM
  #187
berti_00's Avatar
2016 Cls63s AMG
I currently have 305s perfect fit but profile is 25 and I don't like that. So gonna do 295 30 on the new set up
Its more raised than this though. This isnf the driving mode
NH_E63 (01-26-2023)
Old 03-03-2023, 02:26 AM
  #188
momo a's Avatar
2014 W212 E63 AMG S model
Rim fitment
Will 20x9 ET23 for the front of a w212 E63 sedan work? Or is the ET too low.
Old 03-03-2023, 08:22 PM
  #189
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
20 x 9 with et 23 could work but it would come down to the tire size as the 255 would definitely poke out a little bit.
Old 04-13-2023, 12:43 AM
  #190
momo a's Avatar
Hello again, would 20x10 et 18 for front, and 20x11 et 52 rear work? I’m assuming no but it’s worth asking. Thanks!
Old 04-13-2023, 02:14 AM
  #191
brfatal's Avatar
2014 E63S AMG
No. Front is waaay too aggressive.
Old 04-13-2023, 02:39 AM
  #192
momo a's Avatar
yeah I thought so, just wanted to confirm thanks
Old 04-13-2023, 04:16 AM
  #193
SPONSOR
K-Mac's Avatar
Mercedes-Benz CLK 550
That’s right. Seeing there is no front Camber (or Caster) and no rear Camber OEM to resolve costly, premature excess inner edge tire wear.
We saw the need and manufacture adjustment kits once again similar to what was fitted to 90’s models.
In the situation where you want to retain important “TOP OF TIRE TO OUTER FENDER CLEARENCE” we manufacture a Total System (Upper mount front and rear kits or lower mount).
W212 E63, E65 AMG:
FRONT KIT CAMBER ONLY #503616-1i $345 (Both Sides).
Simply replaces the lower arm inner bushes (retaining top of tire to outer fender). Is precisely (single wrench) adjustable - ultimate on car direct on alignment rack (under load). Also can fit without need for arm removal !
FRONT KIT CAMBER & ALSO CASTER #503616K $480 (Both Sides).
Caster bushes are Mono ball / 2 Axis significantly improving brake and steering response - replacing the OEM soft rubber and air voided bushings.
REAR KIT CAMBER ALSO “EXTRA” TOE #502126K $480 (Both Sides).
Also can fit without need for arm removal.
See website re Front & Rear upper mount adjusters along with uprated bushings for the 6 rear multilink arms.
(Less twitch, flex, loss of traction - especially when applying power to lane change / overtake).
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
NH_E63 (04-13-2023)
Old 04-21-2023, 01:55 PM
  #194
momo a's Avatar
Would 20x10.5 front ET 45, 20x11.5 rear ET 57 with the right tire work on a 14 E63
Old 04-21-2023, 02:47 PM
  #195
I.T. Guy's Avatar
Received 1,146 Likes on 600 Posts
2023 E63S Wagon
10.5 is about the max for the rear
11.5 is crazy
Old 04-21-2023, 02:51 PM
  #196
momo a's Avatar
11.5 is crazy
thank you for the reply
Old 04-21-2023, 09:41 PM
  #197
C2 Turbo's Avatar
Aesthetically what would look better, 295 on an 11" or 305 on a 10.5", me think the later? I always thought go for a wider stance and that's what you get with a meatier tire, no?
Old 04-22-2023, 09:38 AM
  #198
kenneyd's Avatar
poop
I like my sidewall profiles to match front and rear
Back in the day, I used to squish tires on there, but I don't like that look anymore.
I tend to favor a pretty much vertical sidewalk profile to slightly stretched look (which one looking at OEM setups seems to be the ideal for steering response and handling)
Anyway, my 2:55/30/20 fit perfectly on my 9 in front wheels
Because of the aggressive offset of those garbage variant Wheels, I had to run a 285 25 20 on a 10-in wide rear beard it was definitely stretched and looked Way too thin.
My new wheels are 10.5 in the rear and look even worse with the 285 on them.
I put those tires for sale, as soon as somebody buys them, I will go to a 305 25:20 in the rear
Which looking at my calculation should match the front profile as well as the height exactly
Old 04-22-2023, 02:08 PM
  #199
momo a's Avatar
20x8.5 et 35 front, Rears- 20x10.5 ET 38. I believe these should work but funky look without the correct tires. What do you guys think and if so tire size to make the fitment decent?
Old 04-22-2023, 02:19 PM
  #200
kenneyd's Avatar
poop
There's no way those rears are going to fit, they're likely going to stick out about 10 mm past the fenders unless you're running some crazy negative camber
momo a (04-22-2023)
Quick Reply: Post your wheel/tire setup with pictures and information...
