Rear Air Springs
Old Feb 24, 2017 | 12:55 AM
omega_jeff's Avatar
'15 Audi RS7
Rear Air Springs
This article is a few years old, but it's interesting seeing as the rear air spring seems to go out on these cars early on. I've got the tools and know-how to do it, so if it's legitimately a step above OEM, I might just do this preemptively so I don't end up with a saggy rear end!
July 23,2015
"Arnott Inc. has introduced aftermarket right rear and left rear air springs for several Mercedes-Benz E-Class models....Arnott says its new aftermarket rear air springs replace the OE air springs and feature a new multi-ply Continental ContiTech air spring bladder, German-made crimping rings, custom-designed, high-impact resin top mount and bottom piston, a 4 mm air fitting, and an air spring dust boot to protect the assembly from debris."
http://www.autoserviceprofessional.c...e-class-models
Is Arnott the make/model of air spring the dealer would use as a replacement?
Also, at ~$200 per side, that's quite reasonable.
Amazon Amazon
And, is it really this easy to replace them???
http://arnottmanuals.com/Reader/defa...px?part=A-2790
Old Feb 24, 2017 | 01:09 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Replaced the ones on my E55 and those were much improved over OEM.
Old Feb 24, 2017 | 01:19 AM
omega_jeff's Avatar
'15 Audi RS7
You replaced them with the Arnott brand?
And they "were much improved over OEM" how? Air holding capacity? Ride quality? Durability?
Old Feb 24, 2017 | 02:27 AM
chiromikey's Avatar
Yep, the Arnotts. I can't say the ride quality was much different since the rears are just air springs and separate from the struts but the overall quality and design (and warranty) were much better.
Old Feb 24, 2017 | 11:26 AM
KLR CLS's Avatar
CLS63 PP
I've used arnotts on various air suspension cars and quality was always top notch!
Old Feb 24, 2017 | 03:09 PM
arnottdoug's Avatar
Former Vendor of MBWorld
MERCEDES-BENZ CL-CLASS
Arnott Rear W211 E-Class Air Springs
Your dealer will want to replace both of the O.E. rear air springs with MB springs and reservoir which requires about 8 hours of labor (which is why tey repalce both) since they have to remove most of the rear end to get to the reservoir. The Arnott Air Springs use a longer piston so it doesn't need the reservoir but you will need to replace both at the same time. This can save over 90% of the installation time! https://www.arnottindustries.com/par...18_pid134.html
Old Feb 24, 2017 | 04:09 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i did all for corners on my e55 myself with arnotts and never had an issue with my airmatic again
i did the rears at the same time, but the fronts i only did one at a time when the old oem ones failed at different times
Old Feb 25, 2017 | 11:21 AM
belarus27's Avatar
2010 e550 p2
ive used Arnott for my 550 it also was a rear one , if it fits go for it.
my rear drivers side was leaking air ,replaced it like 2 months ago , no problem ever since. cant beat the price too
