Vibrations after lowering kit install.
Old Apr 24, 2017 | 10:00 AM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
For those of you who had their cars lowered, have you noticed any rough idle or vibrations coming into the cabin when the car is in Drive and idling? This issue has popped up after my install, and there are vibrations in the cabin only when the car is in drive and at a stop. If I shift into Neutral the vibrations go away, while driving there are no vibrations. Only when idling at a stop. A search came back with possible Axle shaft/ drive shaft misalignment in the joint as a possible cause. This could be due to a improper install by the shop I used, but I'm not sure. Car is going to the dealer today to figure out what the issue is, but has anyone had this issue? 2014 E63 4matic
Old Apr 24, 2017 | 01:50 PM
silvers2k's Avatar
2012 E63 AMG, 2013 E350 4matic (SOLD), 2006 C55 AMG (SOLD)
I'm lowered on Renntech HAS and no noticeable vibration in Drive/Idle. Hope the dealer can find the issue.
Old Apr 24, 2017 | 01:52 PM
CarHopper's Avatar
E63S | X5
No vibration here either. Sounds like trans/motor mounts to me.
Old Apr 24, 2017 | 02:28 PM
raudiace4's Avatar
My car had both motor mounts replaced in February last year, so I doubt it's the motor mounts. Maybe the trans mount, we'll find out today.
Old Nov 7, 2020 | 07:27 PM
flyboyusa's Avatar
C400
i have exact same issue after lowering....did you ever find a solution?
Old Nov 9, 2020 | 12:58 AM
jonii's Avatar
Alpha 9 E63s AMG Biturbo
sometimes the exhaust piping may be touching on the center aluminum brace, causing vibration.
Old Nov 9, 2020 | 07:28 PM
dustinN's Avatar
09E350, 07E63, 13CLS63
I got some vibration at the exhaust tips after resonator delete and lowering so I don't know exactly which one has caused the vibration.
Old Nov 10, 2020 | 07:13 PM
Mixalis Panayi's Avatar
E63 2014
check near the middle end of your car maybe your pipes are touching the aluminium bridge.
Old Nov 10, 2020 | 07:40 PM
dustinN's Avatar
pipes are touching the aluminium bridge ? do you have a picture? I am not sure what you are talking about...
Old Nov 10, 2020 | 07:56 PM
dustinN's Avatar
Is this the aluminum bridge you are talking abt?
Old Nov 10, 2020 | 09:23 PM
jonii's Avatar
yes that brace right there, if the pipes are rubbing on it, that will cause the in cabin vibrations, or else retorque the strut tower or the strut to the spindle.
Old Nov 10, 2020 | 09:48 PM
dustinN's Avatar
no I don't have that problem, thanks
Old Jan 18, 2026 | 11:08 AM
slobo's Avatar
X218 CLS500 4-Matic 9G-Tronic / X204 GLK250 CDI 4-Matic 7G-Tronic
Did you find out? I have the same issue. 😥
