Achieving max boost 14.5psi (stock)?
Old 03-14-2024, 12:40 AM
  #51
Chevota's Avatar
E550 Coupe 2wd (2016)
bbob; You want 8 more? You can only make that much in the sweet spot, then ~4k it drops. By the time I hit 6K I'm at 12.5psi, but my exhaust is bone stock.
Plus I'm not sure how long the rods can handle that, which is why euro and others draw the line ~17
Send me the tune and a run or two so I can see, and I'll tell you what I think.
Old 03-14-2024, 08:53 AM
  #52
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
It also depends on how the tune is designed, and the outside temps/air density etc.
When it is colder / air more dense you may not see 'max boost' if you are tuned to achieve a specific torque level.
Quick Reply: Achieving max boost 14.5psi (stock)?
