Fitting 18 inch wheels on a 2012 AMG Wagon?
Old May 22, 2017 | 05:30 PM
2012 merc amg's Avatar
2018 S560
Anybody know if these wheels might work on my 2012 e63 amg wagon? They are 18's The car currently has 19's and I keep bending wheels as the roads up here in Rhode Island are so bad. I figure 18's with a higher profile tire might be the answer. http://www.ebay.com/itm/MERCEDES-18-...JX4fUZ&vxp=mtr
Does not say anything about offset on these wheels, but I could call and ask. They are good looking wheels. The same company has 19's listed also that says they will fit my AMG. If I got to the fitment configurator, it says these 18's will fit, but can't always go by that. Just don't want to order them and realize they are not gonna work.
Old May 22, 2017 | 05:43 PM
2018 S560
Or if anybody has got 18 inch wheels, what was the type and the part number? I could look at pictures and see if I liked them and go with those, that way it would be a sure thing. Whether or not the ones I posted sounds kind of iffy, even if I call them and ask they still not be the right ones.
Old May 22, 2017 | 05:51 PM
2012 CCB E63's Avatar
2012 E63
as long as you don't have carbon ceramic brakes 18s will fit.
Old May 23, 2017 | 06:00 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
18" wheels, ie the oem 18" wheels, will definitely fit on the rear of any year W212 E63. The same can be said as well for the front of any non 4-matic W212 E63.
If those ebay 18" wheels don't fit, it will be because of any protrusion from the center-facing surface of the barrel.
Old May 23, 2017 | 06:55 PM
South Ocean1's Avatar
2020 Porsche Taycan Turbo, 2020 GLC 63, 2014 Audi S6, 2014 GL63; past 2019 M5 and 2011 E63
2012 Merc Amg:
I would be very careful purchasing rims like that off of Ebay for two reasons. First, I learned first hand that not all 18 inch aftermarket wheels will clear the brakes (particularly the rear brakes) on an E63. My first set of winter wheels for my 2011 E63 were Forgestar F14 that were ordered using the exact same offsets as the stock wheels. The rears did not clear the brakes and I had to re-order the rears with a different offset from stock to clear.
Second, the Forgestars looked fine and were relatively inexpensive, but they had frequent cracking issues. After repairing two wheels I gave up and purchased OEM Mercedes E63 wheels for my other set. So I would be careful to ensure that any wheels you buy will be quality made, and I would have no way to discern that from the Ebay wheels you flagged (even if they do look good).
I think you can get the same quality as OEM by going with a reputable brand like BBS or other rim that is known to fit on Tirerack's site (for example).
I am also selling my 18 inch OEM AMG wheels from my E63 if they might be appealing to you. See the link below in the classified section. No worries if these do not appeal to you but wanted to give my two cents on what might work better generally from personal experience.
https://mbworld.org/forums/wheels-ti...condition.html
Old May 27, 2017 | 11:02 PM
JoeNobody's Avatar
Mercedes
get one size wider tires, and it'll ride dramatically better over potholes
Old Nov 18, 2020 | 12:01 PM
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
did you get 18s to fit? If so what specs please?
Old Nov 18, 2020 | 01:47 PM
maxusa's Avatar
2013 E63 P30, 2010 GL550
Mercedes used to make an 18-inch version of the 10-spoke AMG wheels natively for W212 E63. Glossy gray with machined front. This was done to accommodate bad road markets. Code 796. However, these wheels are not sold in North America. You can find them used in Europe, but shipping is $100-150/ea + you may get customs/import dues to the tune of $25/ea. Here are the specs:
Front: 18x9.0in, Offset ET37mm, Bolt Pattern 5x112mm, p/n A2124014302 7X21 B66030106
Rear: 18x9.5in, Offset ET52mm, Bolt Pattern 5x112mm, p/n A2124014402 7X21 B66030107
Hope this helps.
Old Nov 19, 2020 | 05:47 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Thanks for this. I’m in the same boat in that I feel like I’d like to try 18s for comfort. I’ve been searching for other oem 18s as well that may look nice on a pfl 212 wagon.
Old Nov 19, 2020 | 08:46 AM
I.T. Guy's Avatar
2023 E63S Wagon
What about 18's for better drag launch? Does it matter vs. 19's?
Old Nov 19, 2020 | 08:55 AM
maxusa's Avatar
Of course, it does. Keeping the OEM look, more confident street driving, and better launch are the reasons I stepped down from 19 to 18 above. If one cares for drag launch in a pre-facelift W212, then having a set of just the rear 18s with grippy tires may be the ticket.
Old Nov 19, 2020 | 10:47 AM
p30amg08's Avatar
Hope this helps.
amazing post!
Edit...Mine is a 2014 e63 amg S 4 matic
Here is the issue, the front rotors look like they will clear, but the dust guard behind rotors are huge! I don't think it will fit
Old Nov 19, 2020 | 10:55 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We used to run 17" wheels with drag race tires but used spacers to clear rotors.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 19, 2020 | 01:49 PM
maxusa's Avatar
Here is the measurement for the default 19" AMG front wheel A2124015002, Option 797. Inner diameter at the hub is 450mm (17-3/4"). In contrast, the 18" AMG front wheel for bad road markets A2124014302, Option 796, has inner diameter at the hub 420mm (16-1/2"). The wheels flare wider towards the vehicle. The front 6-piston fixed AMG caliper measures 200mm (8") from the axis.
The pre-facelift W212 front brake disc cover (front left A2124201544) has an irregular shape and is different from the facelift W212 (front left A2184210120). At its maximum width of 200mm (8") from the axis, it extends to the steering rod ball joint, but then is reduced around. I have no access to the facelifted vehicle. Post your measurement here. If your cover measures up to 200mm (8"), then the 18" AMG wheel will clear.
Hope this helps.
