Looking for a perfect fit Heat Range 8 Spark Plug? Look inside!
Old 01-05-2019, 04:03 PM
  #51
CLS63Matt's Avatar
CLS63AMG W218 • CM7 Accord • '13 Yamaha R1
Originally Posted by kangal63
hey guys I am driving a upgrade turbo E63 780whp (860hp crank) with the BOSCH ZR5TPP33-S plugs and I have misfires after 4th gear pulling.
The bosch plugs have now a range of 5. Better to upgrade to the ngk 8´s?
Not to be rude.. but you’ve invested the money to get the car tuned so why would you downgrade the heat range from 6/7 (OEM) to BOSCH 5?!
Also the person who turned your car should have told you to upgrade your plus to a colder range.
Old 01-05-2019, 07:45 PM
  #52
kangal63's Avatar
Mercedes Benz E63 AMG
yes but they discussed here now that Bosch heat Range scala 5 is like ngk 7-8????
Old 01-05-2019, 08:38 PM
  #53
CLS63Matt's Avatar
Perhaps they rating is measured higher but I personally would switch to the NGK especially since you’re misfiring.
Old 01-05-2019, 11:17 PM
  #54
kangal63's Avatar
https://mbworld.org/forums/attachmen...g-indexing.pdf
what do you say to this? Heard now that oem plugs with stock gapping should be the best...
Old 01-06-2019, 04:05 PM
  #55
CLS63Matt's Avatar
I couldn’t say as I’m not an expert, but I do recommend going back to OEM and seeing if that fixes your problem or try the NGK since you’re already willing to use the Bosch
Old 01-06-2019, 05:16 PM
  #56
kponti's Avatar
E63
is the Bosch 5 a hotter heat range or colder?
Old 01-06-2019, 05:23 PM
  #57
CLS63Matt's Avatar
I would assume hotter but they may have a different scale on how they rate their plugs.
Old 02-12-2019, 01:57 AM
  #58
CLS63Matt's Avatar
I actually had the chance to view that PDF. That NGK spark plug caused failure because it was not the right size or thread length which did not allow the plug to index properly. The NGK 97506 is the correct thread length and same size as the OEM Bosch plugs.
Old 02-18-2019, 04:33 AM
  #59
mjec515's Avatar
2014 e550 4matic
nice! Thanks for the all the info!
been wanting to run colder plugs for a while now..but couldn’t find one that is the same exact dimensions as the oem one...ngk 97506 it is! I Noticed different gap specs on these depending on the site...ngk.com has it spec’d @ 0.8 and autozone @0.7...I believe oem is 0.7?...I really don’t want to gap these as the oem ones are perfectly fine for me with no misfires etc...
rockauto seems to be the cheapest place to get em so I might be ordering it there
do u remember the gap of the 97506 set when u got em?
thanks!
Old 02-18-2019, 03:33 PM
  #60
CLS63Matt's Avatar
thanks!
I have yet to install mine. But after speaking with a few people they suggested .22-.25 for gapping
Quick Reply: Looking for a perfect fit Heat Range 8 Spark Plug? Look inside!
