Looking for a perfect fit Heat Range 8 Spark Plug? Look inside!
Looking for a perfect fit Colder Spark Plug? Look inside!
EDITED WITH ADDITIONAL INFO FROM 1ForcedBenz to correct my screw up on Bosch Heat Scale
I've tried a couple plugs now with mixed results, and needed to try something new. I came across a great reverse lookup based on specs here:
https://www.boschsparkplugs.net/Sear...ptn=Spark+Plug
Using OEM Specs of:
Thread:12mm
Seat: Gasket
Resistor: Yes
Reach:26.4
Hex Size: 14mm Bi-Hex
This returns a range of options, but what we most care about for big power and safety is Heat range 7 or 8 on /NKG scale ( OEM is 6), or in this case a 5 or a 4 on bosch scale ( thanks 1forcedbenz). In my case I was looking for an 7-8 NGK due to turbo upgrades, so a 5 on bosch is a good start. Found this perfect physical match! Hope this helps others out there, since vendors have been ripping people off on plugs for some time now.
https://www.boschsparkplugs.net/product.aspx?zpid=40028
SKU: #ZR5TPP33S
ITEM : # BOSZR5TPP33S
BRAND : Bosch
Shell
Thread Size: 12mm
Thread Pitch: 1.25mm
Seat Type: Gasket
Resistor: Yes
Reach: 26.5mm (1.04")
Terminal Type: Solid
Gap: .028" (0.7mm)
Center Electrode
Material: Platinum
Type: Fine Wire
Projection: Extended Projection
Ground Electrode
Material: Platinum
Type: Standard
Shape: Taper Cut
Quantity: 1
Specifications
Torque Specs: Cast Iron: 11-18 lb. ft. Aluminum: 11-15 lb. ft.
Brand: Bosch
Heat Range: 5
Longevity: 80k
Features: Extended Metal Shell
Using OEM Specs of:
Thread:12mm
Seat: Gasket
Resistor: Yes
Reach:26.4
SKU: #ZR5TPP33S
BRAND : Bosch
Shell
Thread Size: 12mm
Seat Type: Gasket
Resistor: Yes
Gap: .028" (0.7mm)
Center Electrode
Material: Platinum
Type: Fine Wire
Ground Electrode
Material: Platinum
Type: Standard
Shape: Taper Cut
Quantity: 1
Specifications
Brand: Bosch
Heat Range: 5
Longevity: 80k
This plug is identical to OEM spec in every way. I've used brisk mr12 and was going to go with ngk dilkar8a8. Both of those have the right thread reach and heat range but different tip configuration, hex size and insulator size too small compared to oem. If the insulator is not the right size, the boot it loose, and I don't like that. The mr12s idle like **** since DI doesn't seem to like non projected tip. This plug is identical to OEM fitment and will behave just like OEM, but give you the heat range you need to pull heat away from tip and into the head. If you are making big power this is the one you want.
On 705whp I never experienced any problems. And my tuner also advices to use oem plugs for some reason.
Cool...you can trust your tuner...I prefer research. Heat range 6 on greater than 650 whp is asking for trouble. Going to a colder heat range is cheap insurance against detonation and burning tips off under high boost and heat conditions. You can use this info however you choose 😘
Your comment of "you can trust your tuner" and "I prefer research" just goes to show how pompous and blissful your ignorance makes you.
Most of me wants to not tell you this so you learn the hard way, but what would be the point if I talk ***** and wasn't helpful. So self righteous parts guru, Bosch's heat range numbers aren't the same as NGK or most everyone else's heat ranges, the higher numerically a Bosch plug is the higher the heat range, so a 8 Bosch plug is equivalent to a 6 NGK heat range. MIC DROP
Stick with maple syrup, Canada at least has that market cornered
Disclaimer - Don't take this to seriously...lol... I mean no insult
Good catch...THANKS! I must have been drunk on Drake's maple szzrup drank at the time because I did know that at one point. Happy to eat moose ( that's the canadian equivalent of eating crow) and correct the info. In that case the colder plug is indeed:
https://www.boschsparkplugs.net/product.aspx?zpid=27998
That is a 5 on the bosch heat scale, so in between 7 and 8 from what I can tell on the conversion matrix. I will update info accordingly. I'll order a set and report back.
Information sharing, thats what this is all about.
C218 CLS63TT PP Edition1, W213 E63S
Using OEM Specs of:
Thread:12mm
Seat: Gasket
Resistor: Yes
Reach:26.4
SKU: #ZR5TPP33S
BRAND : Bosch
Shell
Thread Size: 12mm
Seat Type: Gasket
Resistor: Yes
Gap: .028" (0.7mm)
Center Electrode
Material: Platinum
Type: Fine Wire
Ground Electrode
Material: Platinum
Type: Standard
Shape: Taper Cut
Quantity: 1
Specifications
Brand: Bosch
Heat Range: 5
Longevity: 80k
Using OEM Specs of:
Thread:12mm
Seat: Gasket
Resistor: Yes
Reach:26.4
SKU: #ZR5TPP33S
BRAND : Bosch
Shell
Thread Size: 12mm
Seat Type: Gasket
Resistor: Yes
Gap: .028" (0.7mm)
Center Electrode
Material: Platinum
Type: Fine Wire
Ground Electrode
Material: Platinum
Type: Standard
Shape: Taper Cut
Quantity: 1
Specifications
Brand: Bosch
Heat Range: 5
Longevity: 80k
stock plug
its better to get colder NGK rating 8
Thanks not a stock plug actually, clearly you can read the specs. However I did find the correct fitment NGK IR Range 8 plug:
NGK 97506 SILZKBR8D8S Laser Iridium Spark Plug
SKU: #SILZKBR8D8S
ITEM : # NGK97506
BRAND : NGK
Shell
Thread Size: 12mm
Seat Type: Gasket
Resistor: Yes
Overall Height: ISO
Gap: .031" (0.8mm)
Center Electrode
Material: Iridium
Type: Fine Wire
Ground Electrode
Material: Platinum
Type: Standard
Shape: Taper Cut
Quantity: 1
Specifications
Torque Specs: Cast Iron: 10.8-18 lb. ft. Aluminum: 10.8-14.5 lb. ft.
Brand: NGK
Heat Range: 8
Even has the correct Copper gasket which should allow for proper indexing following OEM torque specs. I've order a set of these as well and will be trying those first. Will report back.
SKU: #SILZKBR8D8S
ITEM : # NGK97506
BRAND : NGK
Shell
Thread Size: 12mm
Seat Type: Gasket
Resistor: Yes
Overall Height: ISO
Gap: .031" (0.8mm)
Center Electrode
Material: Iridium
Type: Fine Wire
Ground Electrode
Material: Platinum
Type: Standard
Shape: Taper Cut
Quantity: 1
Specifications
Brand: NGK
Heat Range: 8
The following 2 users liked this post by KLR CLS:
CerBErusM113 (10-03-2017),
chiromikey (06-23-2017)
Just to close the loop. I received and installed the NGK Iridium plugs, and I'm happy to report they were a perfect fit. I removed non projected brisk Silver mr12s plugs, which sucked. They had a dead miss at idle, and would stumble on quick throttle application. DI and non projected tip plugs just do not work! The new NGK's idle dead smooth with excellent throttle response and and no hint of misfire. Exactly what I was looking for with the Extra protection of a heat range 8 plug. This is the one is recommend if you are doing a big power build.
Comparison pic with OEM plug on right
Did you monitor the plug for indexing when installed? I recently installed oem replacement bosch plugs and they didn't index as well as the mercedes branded ones. They ended up about 30° off from the oem ones that I removed. I want to try oem plugs next to see if the extra money gets the proper indexing. Hahaha
Only way to truly index the plugs is with the head off and shims. Indexing is not an exact science. You have about 45 degrees of coverage where it's not materially different. That said I just followed OEM torque spec of 14.75ft/lbs WITH NO THREAD LUBRICANT. That should put it in the range of similarity to the stock index
According to my research, this would be the heat range 7 (1 step colder than OEM) equivalent of the NGK heat range 8 plug above:
NGK 95770 ILZKBR7B8DG
Anyone have any reasons for reservations before I try these?
Pretty sure this is the only legit way to do it.
