Watermeth location that works for the m157
Old Jul 31, 2022 | 04:37 AM
  #51
Robert AMG's Avatar
Cls63 & C32
I have a question here, is it safe to inject 100% meth or 25/75% water/meth directly at the turbos?
also i see that one nozzle at the intercooler inlet from up is not sufficient cause the inlet pipe has a large diameter so maybe 2 nozzles one on the left and one on right will be more efficient.
thank you guys for all that effort.
Old Jul 31, 2022 | 04:41 AM
  #52
Robert AMG's Avatar
Cls63 & C32
@BillWoeb, your pump location is too high, where is your tank? the pump should be lower than the tank or it will not work.
Old Jul 31, 2022 | 07:43 AM
  #53
BillWoeb's Avatar
2014 E550 4Matic
@Cifdig
Thank you so much for the insights! I will make the changes you suggest!!! Relatively speaking, how much of the power improvements are from the pre-turbo vs post IC WMI?
I have the WMI turning on at 10 psi - is that sufficient?
Thank you again!!
Bill
Old Jul 31, 2022 | 07:46 AM
  #54
BillWoeb's Avatar
2014 E550 4Matic
@Robert AMG
Hi Robert - the reservoir is the washer fluid bottle. The pump indeed works, and holds its prime. I have used this type of location on several of my cars with no issue.
Thank you!
Bill
Old Jul 31, 2022 | 02:27 PM
  #55
Cifdig's Avatar
Top Answer: 1
2007 e350 sport. 2010 350 4matic sport. Worlds first W212 E63R self built.
These are the updated locations and cc amount that should be followed if you are trying to see the best results from pre turbo.
nozzle placement should be either right before the rubber coupler or right after in the grey aluminum inlet pipe . Nozzle size should be start at 500cc per turbo and moved up depending on your needs. . These installs gained 40-50 hp with no revisions at all. Dropping 60-130 from 8.83 to 7.81. Increased trap speed by 1.5 mph sometimes 2mph. Also note where these tunes were dropping in power over the power band after 5k rpm, are now continuing to pull harder due to the compressor being cooled along with intake temps. Quality of your materials and pump are imperative for an efficient set up. Every nozzle should have a check valve as well . @a2d_performance ig name is the only place currently selling direct methanol injection kits for the m157 utilizing a trunk mount system with everything you need for the best install. Not universal. These installs are A2d kits that are made for m157. Using high end materials that they have pre sized .
Old Jul 31, 2022 | 03:33 PM
  #56
BillWoeb's Avatar
2014 E550 4Matic
@Cifdig thank you so much for all the great info.
What should the meth nozzle size be for the single injection point I have in the intake manifold?
Old Jul 31, 2022 | 03:51 PM
  #57
Cifdig's Avatar
Top Answer: 1
if you have pre turbo And are running between 500-700 cc Id set the manifold nozzle at no more then 300-500cc . . But some people do run more because they do not run pre turbo . Just not my preference.
Old Jul 31, 2022 | 04:10 PM
  #58
BillWoeb's Avatar
2014 E550 4Matic
Perfect! I will report back once I make all the recommended changes.
Thank you again!
Bill
Old Jul 31, 2022 | 07:07 PM
  #59
Cifdig's Avatar
Top Answer: 1
Thank you again!
Bill
complete kit are available for anyone who does not want to go through the hassle. Make sure check valves are used or the turbos are going to siphon the meth right through the nozzle even when it's off
Old Aug 3, 2022 | 03:58 PM
  #60
I.T. Guy's Avatar
2023 E63S Wagon
Originally Posted by Cifdig
...Make sure check valves are used or the turbos are going to siphon the meth right through the nozzle even when it's off
I don't know why but I think that's AWESOME.
Old Aug 3, 2022 | 04:12 PM
  #61
Pitbill's Avatar
CLS63 AMG
Thanks! How can we go about getting one of these kits? Actually, I’m only needing from the trunk mount tank forward. So basically just lines, check valves and nozzles.
Old Aug 3, 2022 | 04:20 PM
  #62
Robert AMG's Avatar
Cls63 & C32
i use only solenoid valves cause check valves always failed specially aem.
Old Aug 4, 2022 | 10:17 PM
  #63
S63BenzO's Avatar
2013 CLS63
The manifold location is tapping the manifold right before the throttle body where all the air has already passed threw the charge cooler. So it’s cooling the “cooler” air and going immediately into the manifold so each side doesn’t need tapped.
Old Aug 5, 2022 | 02:39 PM
  #64
Robert AMG's Avatar
Cls63 & C32
Look at the pics attached, the inlet is wide, 2 nozzles from each side is better then one on top, my thought, and relocation of ait sensor after the nozzles is also better.
Old Aug 7, 2022 | 06:53 PM
  #65
BillWoeb's Avatar
2014 E550 4Matic
Big THANK YOU to Cifdig!
Hey,
Wanted to thank Cifdig- I relocated the nozzles as suggested, removed the post IC nozzle for now, and now have 750mL/min per turbo of 90/10 meth/water.
WOW!
My 91 AKI tune with that felt almost as good as my E40 time without WMI!!!
Can’t wait to try it out on the E40 tune and E60 tunes I also have from AMR.
Thanks to Cifdig again for your wisdom!!
Bill
Old Aug 8, 2022 | 12:41 PM
  #66
Robert AMG's Avatar
Cls63 & C32
Nice, so you got those result with only pre turbos injection? can you try it with 500ml each pre turbos and one 500ml post turbo?
thanks guys for all effort.
Old Aug 13, 2022 | 08:55 AM
  #67
Cifdig's Avatar
Top Answer: 1
Hey,
WOW!
Bill
great to hear. As you upgrade the system the more you will get from it as well. There's many more things in a methanol kit that plays a big roll in how the methanol is delivered, how consistent the spray from the pump can deliver your meth, does it have any pulsating pressure drops from line kinks , line collapse and or poor pump . Also keep in mind Are your nozzles good enough to atomize the methanol correctly etc . Anyone trying to install methanol on an m157 has to understand that our engines get very hot, engine radiant heat is insane. So it's imperative that you purchase a quality setup, and if your using nylon lines to figure out how you want your systems setup to deliver your methanol that's fine, just convert to braided lines after your happy with your system and if you are unsure of your systems quality then purchase a good one. I've seen many people drive around with setups that don't even deliver any gains at all, either from poor location, not enough cc's to feed a huge v8 engine, using to much water and not enough methanol etc. if your going to go through all the trouble of this install you might as well get something out of it and safely.
Old Aug 13, 2022 | 05:30 PM
  #68
J888tav's Avatar
E63 w212 Amg
Aem methanol kit
Evening everyone. The information for the methanol kit has been extremely helpful and I’ve fitted a AEM methanol kit with the 5 gallon tank and the v3 injectors.
I’ve used the nylon feed pipe and protect it the best as possible. Using a fuel hose around the nylon to stop it rubbing the car as I’ve run the line under the car in the spare slots with brake line from front to rear of car.
system works well and seems to be good. One issue I have is that I can’t find a stainless braided line I can use which would connect to the aem v3 injectors
you would of thought that a company that makes the kit would have thought about a upgrading kit for them to have braided line options. If anyone has found a braided line and fittings that work with the AEM kits
Old Aug 27, 2022 | 11:31 AM
  #69
Siegmann's Avatar
10-second E550
@Cifdig
Have you seen any change in fuel trims when spraying pre-turbo? I would assume that none of the methanol reaches the cylinders as fuel, but I could be wrong. And fuel demand probably increases as more (denser) air is being delivered.
Old Sep 4, 2022 | 12:53 AM
  #70
Silver06hemic's Avatar
GL550, M157 turbos, VRP BOV, Water/Meth, downpipes, AMG Catback, Custom Weistec Tune, Trans Tune & P
Late to the party!
Hey guys... I'm a little late here but looking for some info!
So I'm running a 13 GL550 with M157 turbos, VRP BOV, 1 stage cooler plugs, filters with spacers, custom intake tubes, full 63 AMG exhaust, Weistec trans pan, Weistec trans tune, custom Weistec ECU tune, snow performance WMI with dual nozzle dash adjusted controller.
So now that's out of the way... I have my WMI installed in the pre-tapped location on the tubes by the BOV just before intercooler... Car runs quicker without WMI on as I feel like it's puddling in the intake and the car is snorting a bit from time to time. Don't get me wrong the girl is quick running low 12's without too much torment I'm Florida 100deg heat but I know thos WMI has more to offer. So if I'm reading right I'm moving my nozzles pre turbo and switching to number 8 nozzles (500ml or cc)... I think I understand the locations, but tapping will be a pain. 🤦 I'm running boost juice right now but should I be spraying 80/20 meth/water or 100 meth? Also any ideas on the on settings or ramp amounts I should be looking at? I'm seeing in close to 30psi right now and the engine is happy by the logs... Just like the extra cooling and added nudge in hp of water meth (I run it on my dodge diesel right now too)... Just want to get it right!
Appreciate your knowledge!
Old Sep 20, 2022 | 05:50 PM
  #71
Pitbill's Avatar
CLS63 AMG
I finally got all of my hoses, tank, switches and fittings ordered from Prometh and pretty much installed other than the nozzles themselves. I have a question, Prometh says the actual nozzles are back ordered six weeks, which is the same thing they told me a month ago. Do any other brands of nozzles work with the Prometh holders (I’m guessing probably so if they are the same size threads but I’m not positive) and if so what would be your recommendations for 700 ml nozzles other than Prometh brand?
Old Sep 21, 2022 | 12:05 AM
  #72
diamondblak05's Avatar
Too many to list
Been thinking about purchasing a WMI kit from Snow Performance. One question that I haven't seen anyone addressed, or maybe I just missed it, is where do you tap to get the boost pressure on these M157 engine, especially one from a '15 ML63?
Old Sep 21, 2022 | 10:52 AM
  #73
Cifdig's Avatar
Top Answer: 1
you got the universal kit? And you have to cut down to size? . You can use other nozzles. Did they have any nozzle for you to use?
Old Sep 21, 2022 | 10:57 AM
  #74
Cifdig's Avatar
Top Answer: 1
2 issues. The location. Switch to pre turbo. Second is boost juice . It's garbage. And you will get way better response from 100% methanol . That said use 700cc . If you have the cheap nylon hoses . Don't use 100% meth until you swap for braided lines . Can you run it with nylon. Absolutely . But safety comes first.
Appreciate your knowledge![/QUOTE]
Old Sep 21, 2022 | 10:58 AM
  #75
Pitbill's Avatar
CLS63 AMG
No, not a universal kit. I measured and ordered the stainless hoses built to size with only the holders included. Nozzles are not available at all right now through them.
