E350 W212 Estate Drops Low Overnight
Hi, just wondering if anyone has any advice on my W212 E350 estate 2010.
If I leave it for say, 4~5 hrs parked up the rear suspension drops considerably so that the wheels are inside the arches. I would say it it drops a min of 2~3".
Do they have air suspension?
Any help would be greatly appreciated.
MBE350RA (12-02-2017)
Thanks ItalianJoe1, I'll check it out. As both sides are dropping are they interconnected in some way or is it more likely I've got a leak on both corners?
W203 C32 AMG...W221 S63...SOLD...W212 E63 CURRENT
In the cold weather it’s normal that it drops checked the links if they stuck and if they are good one of the bags it’s leaking go to arnott and get them both for like 600
Not familiar with the wagon rears in particular, but I know there's only one rear height sensor on most of the cars, so I believe they are somewhat connected. Often, if one leaks, the added weight will collapse the other side, maybe not as much but it will look very low also. Not worth replacing one at a time, just do the pair if one is leaking. Do test the valve first though, as it can be stuck and leaking.
The rears are generally pretty simple, you can see them without removing anything normally. Removal is usually very simple also but I haven't done a 212 in a while so I don't recall if there's any trick to it. Most airmatic rears are just bags and they can be squeezed down and removed, new ones installed the same way.
