Down pipe exhaust
Old Dec 31, 2017 | 09:49 AM
e55joe's Avatar
2014 E63s,2004 E55, 2006 STS-V, 1969 Camaro RS/SS 396, 2012 Centennial GS Corvette
Down pipe exhaust
Looking into down pipes and i see that alpha and weistec show 2 different down pipe setup can anyone tell me the difference between two. Weistec looks like theirs comes off the turbo flandge and alpha Looks like theirs comes after the front pipes.
if this is the case wouldnt the weistec be a better choice. And if so where could i get the turbo flanges.
Old Dec 31, 2017 | 10:01 AM
e55joe's Avatar
Heres the deal my best friend ownes a fab shop he builds race cars. I am going to mock up a set for me and i want the best available option for power. After we make a set for my car we can make more at a fraction of the price and would be glad to help out fellow board members. I can setup a group buy if anyone is interested. I want to get this started in next couple weeks and can post pic
Old Dec 31, 2017 | 12:16 PM
CarHopper's Avatar
E63S | X5
The reason you see two different types is because one set truly goes to the turbos, however, the motor has to come out to install. Hence, the other set, which stop short of the turbos but the motor doesn't have to come out to install making them far cheaper to get in. Minimal to no differences in power gains between the two.
Old Dec 31, 2017 | 02:38 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
We can supply you with a set of turbo back down pipes for $2000
I may also have a used.
Old Dec 31, 2017 | 02:43 PM
e55joe's Avatar
Is there any power numbers between the 2 turbo back and front pipes back?
Old Dec 31, 2017 | 02:52 PM
shardul's Avatar
There are a few threads posted by customers.
We don't make any dyno numbers claims since results will vary from dyno to dyno.
Old Dec 31, 2017 | 03:50 PM
Mikeki7's Avatar
CLS63, S55
The weistec knock offs are a great value and fit with no issues on a rwd car without having to remove the engine. But I dont know how well they fit on 4matic because the real weistec turbo pipes come with different engine mounts/brackets. Biggest difference with the turbo pipes vs just the downpipe is a huge increase in turbo spool sound.
Old Dec 31, 2017 | 07:27 PM
CarHopper's Avatar
E63S | X5
Long story short, you don't want full turboback dps.
Unless you're about to upgrade the turbos and use some kind of magical sorcery on the tranny / TCU then there is truly no point.
Old Dec 31, 2017 | 08:49 PM
e55joe's Avatar
Thumbs up
👍🏼thanks for summing it up.
So what should i know about these trans. Would i be ok with just down pipes no cats and a tune coming from kevin baldi after exhaust is done.
also what do u guys think as far as X or H pipe.
Im gonna run 3inch all the way back to mufflers.
Old Dec 31, 2017 | 09:56 PM
CarHopper's Avatar
E63S | X5
All you really need to know is that the TCU nannies tq in 1st and 2nd so even though the car is fully capable of making some good power it is limited for launching. And no, nobody has a TCU solution except for maybe GAD who has an absolutely ridiculous E63 but if you're going to spend that kind of money you're better off in another car.
Then, for roll racing / pulls, once you get up around 750/800awtq you can run into slipping which clutch packs can help with. But again, that does nothing for the launch / drags and only really benefits in rolls.
Hell, guys have blown trannys launching on stock cars.. Mine makes 620awhp/763awtq and I won't launch it. Just pulls.
I'm running EC tune on catless downpipes and the car is a monster. I slap basically everything on the road mostly because people don't expect it and the things that do beat me I expect to and are really fast cars. But I also know it's at the limit and if I want more or to be faster then I'm in the wrong car. Example, mod for mod M5's and RS7's are faster all because of the tranny. That's just life.
There will always be something bigger, badder, faster, stronger out there.
Old Jan 1, 2018 | 01:33 AM
e55joe's Avatar
Thanks for the info.
is there anything else i should do other than tune and down pipes.
Old Jan 1, 2018 | 09:43 AM
shardul's Avatar
Yes get our intake spacer and filter kit
https://mbworld.org/forums/w212-amg/...boost-kit.html
Old Jan 1, 2018 | 12:08 PM
CarHopper's Avatar
E63S | X5
I've just gone tune, dps, and new filters for performance. I am lowered with CF bits and such as well if you're into cosmetic stuff. When I did the tune and dps I also did new plugs and packs. If you're really hard on the car maybe some cooling upgrades which are key for turbo longevity but I mean you'd really have to be on the car a lot... I've seen meth added to the list too but I don't mess around with it really.
Other than that, I would just enjoy the car for what it is. Keep it well maintained and it'll give you a lot of fast, fun, miles.
There are other options, like turbo's, but you're starting to shell out some real cash at that point.
