W212 E63 Adaptive Trans ECU Reset (it works!)
Old Mar 17, 2018 | 12:57 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
Many of you guys know this “trick” to reset the Mercedes adaptive transmission or ECU reset as many call it, but I thought would post here the instructions on how to do it for anyone new......
I had done this several times on my e63 holding the pedal down for only 4-5 seconds which never did anything to reset the e63 but was what worked on my c32 so I thought it didn’t work.
I followed these steps exactly with a 10 second pedal press (instead of 4-5 second) and the Trans is definitely much more responsive. I did a few launches using race atart after doing the reset I would got the traction control light to flash from the rears spinning a bit which never happened previously.
Give it a try...have fun
http://www.mercedesmedic.com/reset-m...-instructions/
Old Mar 17, 2018 | 01:24 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
You should try disconnect the battery overnight. That’s a major difference and the only thing outside of Star that resets the adaptations for me.
Old Mar 17, 2018 | 01:30 PM
Boostaddict's Avatar
2016 E63 S AMG
Thanks John!! I'll definitely be giving this a try
Old Mar 17, 2018 | 04:25 PM
jvakos's Avatar
Thx chiromikey will give that a try as well !
Old Mar 17, 2018 | 05:15 PM
baldmike73's Avatar
does it change the hard shift from 2nd to 3rd in S+ ?
Old Mar 18, 2018 | 07:09 AM
PeterUbers's Avatar
it may or may not; there are several reasons why you have a harsh shift ... one of which could be a problem with adaptations
Old Jul 3, 2023 | 12:37 PM
CGally's Avatar
W212 E63s
I was viewing this link and the description shows a key fob and ignition switch. We have push to start. How does this work with push to start?
Old Jul 3, 2023 | 01:45 PM
CZ 75's Avatar
E63 AMG
You can remove the push to start cover and insert your fob and use it as a regular key for this.
Old Jul 3, 2023 | 02:40 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
You don't need to do that. Position 1 is one press (no brake pedal, known to me as accessory mode) and position 2 is a second press (also no brake, and this is otherwise known as ignition on).
