Throttle lag from stop
Old Apr 9, 2018 | 01:15 PM
kponti's Avatar
E63
Just an observation. The lag in my car was so bad I HAD to drive in sport mode not to drive this thing off a cliff. I have had the MCT adapted as recently as last summer so that is not the issue.
Well, about a month ago, I replaced all the cam sensors with the updated part number and cleaned the electrical connectors of the pools of oil in them. Cleaned the cables as far as I could go (CRC electric spray works wonders, and I went through two cans). Reset ECU and it has been quite phenomenal. I can drive in Comfort mode now (not crisp but definitely livable) and I even had to turn down my Pedalbox from Sport due to the much-improved throttle response. I was expecting it to get back to crappy normal a week or two later, but nope, its held on!
Something to keep in mind if you are above 40k miles
Old Apr 9, 2018 | 01:19 PM
PeterUbers's Avatar
Good info
did you test each step in your resolution process to see what of all those three or four measures was most efficacious?
i wonder how effective just resetting the tcu alone would have been but I suspect you did that first
Old Apr 9, 2018 | 01:51 PM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
what year is your car?
Old Apr 9, 2018 | 06:10 PM
kponti's Avatar
E63
2012
Old Apr 9, 2018 | 06:14 PM
kponti's Avatar
E63
Good info
It was the cleaning and replacement of the sensors for sure. The reset, I have done more times than I can count. Reset both ECU and TCU via OBD device from time to time. Never did change the comfort mode lag.
Obviously, the cleaning of the oil and changing the sensors go hand in hand, the leaking sensors caused a pool of oil in the electric connections and has been wicking toward the ECU for a while now. MB dealer replaced one of the sensors before and replugged the dripping oil plug into the new sensor smh. I could not even tell a difference between the new sensor and the old ones so I replaced them all again.
Old Apr 9, 2018 | 07:18 PM
WANTED!!'s Avatar
I was just reading a thread the m157 lag issue. So is this the fix should it rear it's head?
Old Apr 10, 2018 | 02:36 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
SprintBooster? That's one option to get around the lag. If you have a tune though, I wouldn't use the SprintBooster. I tried that once and the car (although its a M156) had a couple of scary episodes. Went into limp mode in the middle of the freeway! Ugh.
Old Apr 10, 2018 | 03:29 PM
kponti's Avatar
E63
I have a tune and no problem on the PedalBox
Old Apr 10, 2018 | 03:30 PM
kponti's Avatar
E63
I will say, it made my car feel very very different with little to no lag
Old Apr 10, 2018 | 05:43 PM
Vrodman's Avatar
I ran both the V5 Eurocharged tune and the SB together for about 3 months. There were only 2 bad events during that time. In both instances the car went into barely able to move right after trying to jump on it at very low speeds to get around someone holding up traffic. It seemed like a combination of sudden steering together with hard SB amplified throttle was the cause. After removing the SB, I have never had the issue reoccur in the last 2 years roughly. I posted this in a prior thread that I don't recall at the moment and there were responses that other people sporadically had issues with the SB. Can't say if they had tunes though.
Old Apr 11, 2018 | 05:53 AM
mickey13's Avatar
1999 AMG C43
wrong thread sorry
Old Apr 11, 2018 | 11:43 AM
Amg63-'s Avatar
CLS63 AMG
the difference is the m157 has a lot more lag from a stop than the m156. I can see it being overly sensitive on a m156 but with m157 the TCU makes the throttle a lot more laggy due to increased torque limiters
Old Jul 17, 2019 | 01:27 AM
TexasBenzBandit's Avatar
2017 AMG C63, 2001 C5 Corvette
i just came here because I thought it was cool Pete used the word, efficacious.
Old Jul 17, 2019 | 12:28 PM
PeterUbers's Avatar
Lol!!!
billvp218's Avatar
m157 SL63
What are the part numbers? What year did they update? My car has a similar issue with lag, and I'm not sure if this will be a fix but would try if it's not too much.
Old Jul 17, 2019 | 03:41 PM
kponti's Avatar
E63
I believe I paid about $35-40 apiece back then. I spent about 45mins cleaning the oil and swapping the 4 sensors (easier than changing the air filters on this car)
Old Jul 17, 2019 | 06:12 PM
Vrodman's Avatar
Probably obvious and perhaps I missed it above somewhere, but you do know that the car takes off in 2nd gear in C mode right?
Old Jul 17, 2019 | 07:18 PM
billvp218's Avatar
m157 SL63
Is this the part: https://www.mbpartscenter.com/oem-pa...UtNWwtdjgtZ2Fz
Old Jul 18, 2019 | 04:02 PM
kponti's Avatar
E63
Yes of course, except I would have crossed a 4 lane hwy before the turbo kicks in and spins the wheels at a time when I no longer need it
